× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
RN104 - BTRFS Read-Only after failed snapshot
polofson
After installing latest OS, snapshot failed and now filesystems are mounted readonly.
How to prceed with btrfs check. How to boot in support mode so that filesystem is not mounted and try btrfs check/repair.
Model: RN10400|ReadyNAS 100 Series 4- Bay (Diskless)
Message 1 of 9
Accepted Solutions
polofson
Re: RN104 - BTRFS Read-Only after failed snapshot
A reboot did help !!! It seems to be working normal and files are accessible ... snapshot created as usual. ... Lets hope for the best ...
Message 8 of 9
All Replies
polofson
Message 2 of 9
Guru
This was upgrading to 6.10.0?  (I've learned it's always wise to confirm "latest" ).  Also, did you have a full root partition when you attempted the upgrade?  You might want to wait a bit and see if @JohnCM_S or other Netgear folks want to take a look.
BTW, do you have any idea on what triggered the ethernet overruns?
Obviously make a backup if you haven't got a current one, since btrfs repair is uncertain.
To gain access you'd boot the NAS into tech support mode using the boot menu (pages 28-29 here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf )
Then access with telnet (I generally use putty).  Log in as root; the password is infr8ntdebug.
You then chroot and start raid by entering
# rnutil chroot
Although you don't want to do this in your case, the data volume for a healthy array can be mounted using
# btrfs device scan
# btrfs fi show
# mount /dev/md127 /volume-name
But if you expanded your storage vertically in xraid or have multiple RAID groups in flexraid, you might need to do the device scan before you attempt repair.
Message 3 of 9
polofson
I'm sorry if I was unclear, its was after updating to 6.10.0 not during. This happened aprox 10 days after upgrade. During the nightly snapshot it got some error as shown in the previus log. I want to try repair the file system if possible. So thanks for all tips tricks to try ...
I can not access the data so doing a backup is not possible
Message 4 of 9
Guru
The volume is no longer mounted read-only?
You can atttempt to mount it using the procedure above, though you should probably add -o ro to the mount command (mounting it read only).  If that works, you can make a local backup (connecting a USB drive to the NAS, and backing up from the linux CLI).
Message 5 of 9
polofson
Screen Shot 2019-05-22 at 22.43.03 .pngScreen Shot 2019-05-22 at 22.44.19 .png
Message 6 of 9
Guru
Did you try remounting the data volume? (a reboot should do it).
No idea if that will help, but it's worth a try.
Message 7 of 9
polofson
Message 8 of 9
Guru
Great Smiley Happy
It would be a good time to make a backup.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 4651 views
  • 1 kudo
  • 2 in conversation
Announcements
