× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
ReadyNASOS 6.10.0-RC2
OOM-9
NETGEAR Expert
Latest beta: ReadyNASOS 6.10.0-RC2
• ARM
  • Supported devices: 102 / 104 / 2120 / 202 / 204 / 212 / 214
• x86_64
  • Supported devices: 312 / 314 / 316 / 422 / 424 / 426 / 428 / 516 / 524 / 526 / 528 / 626 / 628 / 716 / 2304 / 2312 / 3130 / 3138 / 3220 / 3312 / 4220 / 4312 / 4360
To install: Click on appropriate link above for your system to download firmware image.
Then upload that image from the management UI's System->Settings->Update->Install Firmware section.
Changelog
  1. [Beta 1] ReadyTIER supports data tiering
  2. [Beta 1] Updated Apache to version 2.4
  3. [Beta 1] Updated ReadyNAS Vault agent
  4. [Beta 1] ReadyDR history sorting done chronologically
  5. [Beta 1] Volume Performance charts now provide volume information with multiple RAID Groups
  6. [Beta 1] Per share case insensitive option under SMB (This will improve performance on file listing over smb for macOS users that do not depend on case)
  7. [Beta 1] Apps connects to the app server securely
  8. [Beta 1] Various ReadyNAS 100 and 2120 series stability fixes
  9. [Beta 2] Now able to enable services
  10. [Beta 3] Added Audit logging
  11. [Beta 3] Added Established connections
  12. [Beta 3] Improved the current logging and searching capability
  13. [Beta 3] Improved the Amazon Drive and allow users to migrate configurations to newer cloud sync options
  14. [Beta 3] Fixed the networking graphs
  15. [Beta 3] Fixed the apps' repo, so app installs should go smoother now
  16. [Beta 3] Added Maintanence and Updates options that allow you to configure to allow hot fixes or email notifications
  17. [Beta 3] Security fix CVE-2018-1160
  18. [Beta 3] Updates to AV software
  19. [RC1] Removed Anti Virus For 100 Series (RN102 / RN104)
  20. [RC1] Removed disk spin down for 12+ rackmount units (RR2312 / RN3220 / RR3312 / RN4220 RR4312 / RR4360)
  21. [RC1] Added USB labels are now displayed and editable
  22. [RC1] Updated USB share names are now editable
  23. [RC1] Fixed SMB Spotlight optimization for cases of large number of files
  24. [RC1] Fixed ReadyTIER migration then reboot causes tier migration failure messages
  25. [RC1] Fixed ReadyTIER data allocation for existing volumes changed to use the higher tier correctly
  26. [RC1] Added Audit messaging when audit is no configured.
  27. [RC1] Added iSCSI Audit information
  28. [RC1] Updated the Audit file names to be similar to the system logs (aduit_log-<hostname>-yyyyMMdd-HHmmss)
  29. [RC1] Added ADS Import Timeout (sec) setting
  30. [RC1] Updated the labeling for the (established) Connections
  31. [RC2] Admin password change is required through the setup wizard.
  32. [RC2] Multiple failed admin logins will lock the account for 5 minutes.
  33. [RC2] CVE-2019-8912 - Kernel level security fix
  34. [RC2] CVE-2016-2148 - DHCP client security fix
  35. [RC2] CVE-2018-1000517 - wget security fix
WARNINGS:
  • Unless you are advised by NETGEAR Support in a support case to update to beta software, NETGEAR Support may deny support if you are running beta software. You can seek help here on the NETGEAR Community for issues encountered on the beta.
  • Devices updated with 6.10.0 firmware should not be downgraded to firmware versions before 6.10.0.
  • ReadyNAS 102, 104, and 2120 must not be updated directly to 6.10.x from 6.3.x or older firmware.  They must first be updated to either 6.2.5 or 6.3.5 then to 6.5.2 and then onto 6.10.x.
  • ReadyNAS 202, 204, 212 and 212 must not be updated directly to 6.10.x from 6.3.x. They must first be updated to 6.3.5 then 6.5.2 and then onto 6.10.x.
KNOWN ISSUES:
  • None
Message 1 of 5
OOM-9
NETGEAR Expert
Re: ReadyNASOS 6.10.0-T184 (Beta 2)
Updated with Beta 2.
Message 2 of 5
OOM-9
NETGEAR Expert
Updated with Beta 3.
Message 3 of 5
OOM-9
NETGEAR Expert
Updated with RC1.
Message 4 of 5
OOM-9
NETGEAR Expert
Updated with RC2.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 14447 views
  • 10 kudos
  • 1 in conversation
Announcements
