Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNASOS 6.10.2-T49 (Beta 1)
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-08-27
02:53 PM
2019-08-27
02:53 PM
Latest beta: ReadyNASOS 6.10.2-T49 (Beta 1)
• ARM
- Supported devices: 102 / 104 / 2120 / 202 / 204 / 212 / 214
• x86_64
- Supported devices: 312 / 314 / 316 / 422 / 424 / 426 / 428 / 516 / 524 / 526 / 528 / 626 / 628 / 716 / 2304 / 2312 / 3130 / 3138 / 3220 / 3312 / 4220 / 4312 / 4360
To install: Click on appropriate link above for your system to download firmware image.
Then upload that image from the management UI's System->Settings->Update->Install Firmware section.
Changelog
- [Beta 1] Added iSCSI 512 and 4k block size options
- [Beta 1] Added automatic firmware updates based on a schedule
- [Beta 1] Re-added disk spin down for the 4 bay rackmount units (2120/2304/3130/3138)
- [Beta 1] Improved BTRFS stability on ARM units (102/104/2120/202/204/212/214)
- [Beta 1] Updated Gmail notifications to follow Google's security requirements
- [Beta 1] Changed the admin file/folder search/browse to support pages to improve memory
- [Beta 1] USB Label can be set when formatting USB
- [Beta 1] Fixed ReadyDR's specified port for backups to remote locations
- [Beta 1] Updated kernel
Attention Gmail Users:
Gmail customers using the Google integration for email alerts will require a re-authenticating with the newer email authentication by September 15, 2019.
WARNINGS:
- Unless you are advised by NETGEAR Support in a support case to update to beta software, NETGEAR Support may deny support if you are running beta software. You can seek help here on the NETGEAR Community for issues encountered on the beta.
- Devices updated with 6.10.2 firmware should not be downgraded to firmware versions before 6.10.0.
- ReadyNAS 102, 104, and 2120 must not be updated directly to 6.10.x from 6.3.x or older firmware. They must first be updated to either 6.2.5 or 6.3.5 then to 6.5.2 and then onto 6.10.x.
- ReadyNAS 202, 204, 212 and 212 must not be updated directly to 6.10.x from 6.3.x. They must first be updated to 6.3.5 then 6.5.2 and then onto 6.10.x.
KNOWN ISSUES:
- None
Message 1 of 1
