- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNASOS 6.4.0-T140 (Beta 5) - RN104
- Mark as New
- Bookmark
- Subscribe
- Permalink
Unable to update from Beta 4 to latest beta. Receive error - file is missing or corrupt. Attempted on multiple web browsers with same error. File size equals previous betas.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNASOS 6.4.0-T140 (Beta 5) - RN104
Perhaps reboot the NAS and try again?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Rebooted.... same error
MD5 hash of image file = 2c7077ab6e563f18952bbd497ac042a4
- Mark as New
- Bookmark
- Subscribe
- Permalink
The firmware image you downloaded is fine.
Have you checked how full the OS partition is?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Cleaned up boot partition and firmware updated.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just thought it was worth to note:
On my RN312 I can always replicate this issue if I am trying to Upgrade over 'eth1'
Needs to be over 'eth0'
I have my NAS going across 2 subnets:
eth0 - 192.168.1.2 Static IP 192.168.1.1 GW and DNS
eth1 - 192.168.0.2 Static IP 192.168.0.1 GW and DNS
Likewise, I cannot set up an FTP Server in the ReadyNAS over 'eth1'
I am not sure if this is related to 6.3.5 and has been inherited to 6.4.0 or whether it is the normal NAS behaviour. I had never tried it on 6.2.4 and first noticed it in 6.3.5.
It's definitely related to 'eth1' as everything runs as it normally should over 'eth0'
Cheers
- Mark as New
- Bookmark
- Subscribe
- Permalink
@vinniemac wrote:
... I cannot set up an FTP Server in the ReadyNAS over 'eth1'
I suspect this happened before (assuming you are using the usual passive ports configuration).
Is masquerading off or on?
If masquerading is off, then the FTP server would need to be smart enough to signal passive ports using 192.168.1.2 when the control connection comes over eth0, but 192.168.0.2 for eth1. It can be set up that way, but it would be pretty tricky code to configure that automatically.
Of course if masquerading is on, there can only be one masquerade entered in the GUI. So you'd need to choose the ddns name/public IP for one of the networks, and the other couldn't be used. If you forward ports in both routers, the control connection would use either network, but the data transfers would always go over the same network.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for your detailed comments, much appreciated.
Yes masquerading is off.
I guessed it would be something of a tricky configuration. I never intended to configure, it was just by accident I configured up port forwarding on my router to the wrong IP and curiosity got the better of me. So decided to access the FTP via internal IP.
(Crazy when you are running 2 identical routers just on different subnets)
Sure enough, one connected and the other didnt even though FTP in the NAS doesnt allow to specify an IP.
That being said:
The main one was not being able to upgrade the firmware over 'eth1'. Now that was an interesting one...
Cheers
- Mark as New
- Bookmark
- Subscribe
- Permalink
Rear USB (3.0) ports work properly now with APC UPS connection.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Upgraded my RN104 via Webinterface from Beta 4 -> Beta 5 without any problems.
My problem:
USB 3.0 Storage Devices are regonized by system (Logs) but
will not automatically been mountet (NTFS)
Sandisk USB 3.0 64GB Stick & external USB 3.0 128GB SSD
USB Devices with native USB 2.0 (old USB Stick) are working fine.
Greetings
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am also unable to update with the same error - how do I clear the os\boot files?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is what I get when using ssh:
root@NAS:~# df -h
Filesystem Size Used Avail Use% Mounted on
tmpfs 10M 4.0K 10M 1% /dev
/dev/md0 3.7G 768M 2.8G 22% /
tmpfs 249M 0 249M 0% /dev/shm
tmpfs 249M 1.6M 247M 1% /run
tmpfs 249M 0 249M 0% /sys/fs/cgroup
tmpfs 249M 0 249M 0% /media
/dev/md127 8.2T 4.3T 3.9T 53% /Hitachi
/dev/md127 8.2T 4.3T 3.9T 53% /home
/dev/md127 8.2T 4.3T 3.9T 53% /apps
/dev/md127 8.2T 4.3T 3.9T 53% /var/ftp/Films
/dev/md127 8.2T 4.3T 3.9T 53% /var/ftp/Music
/dev/md127 8.2T 4.3T 3.9T 53% /var/ftp/TVShows
/dev/md127 8.2T 4.3T 3.9T 53% /run/nfs4/Hitachi/3D_Films
/dev/md127 8.2T 4.3T 3.9T 53% /run/nfs4/Hitachi/Films
/dev/md127 8.2T 4.3T 3.9T 53% /run/nfs4/Hitachi/Music
/dev/md127 8.2T 4.3T 3.9T 53% /run/nfs4/Hitachi/Pictures
/dev/md127 8.2T 4.3T 3.9T 53% /run/nfs4/Hitachi/TVShows
/dev/md127 8.2T 4.3T 3.9T 53% /run/nfs4/home
- Mark as New
- Bookmark
- Subscribe
- Permalink
root@NAS:~# df -h
Your OS partition is not full, so you have a different issue than the original poster. Perhaps PM skywalker?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks - I will try and PM.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
How do you clean up the boot partition by the way?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
1. The NAS is unstable and crashes all the time, especially during copy job. When It crashes I have to unplug the power and power it on again. And then it resyncs the volume. All over again.
2. It is on firmware 6.2.5 and it won't upgrade to beta firmwares or downgrade to older firmwares.
The instability started with upgrading to firmware 6.2.5.
I've tried factory default booting and OS booting without any other positive results.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Check /var/log/readynasd/fwbroker.log after attempting a firmware update. The log should provide useful information why the update is failing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Tried to update the ReadyNAS 104 from 6.2.5 to 6.4.0 because of the unstability, but it's still on 6.2.5 Tried both automatic (remote) and local update with no positive result. Tried with an another browser (IE, Chrome) and same result. Factory reset MANY times without any help.
Here's the log:
INFO: request method POST
INFO: dpv_=dpv_1444328426000, njl_id_=njl_id_308, type=FirmwareProgress
INFO: dpv_=dpv_1444328426000, njl_id_=njl_id_315, type=FirmwareImage
INFO:AAGET_LOCAL_INFO: sinfo .model=ReadyNAS, model_num=104, .serial=3EP335EW002DF, .firmware_name=(null), .firmware_version=6.2.5
INFO:AAGET_REMOTE_INFO(STEP 1 URL:) http://update.readynas.com/download/ReadyNASOS-arm/index?key=d4cd51e5cc36bb0736f67eb9123ae453&model=...
answer=info::name=ReadyNASOS,version=6.4.0,time=1443207354,size=63391744,md5sum=7d47463d9c9014d7dc3a1cd8b88d33a7,arch=arm,descr=ReadyNASOS Update,release_notes=http://kb.netgear.com/app/answers/detail/a_id/29938
INFO:AAGET_REMOTE_INFO: version:6.4.0 size:63391744 descr:ReadyNASOS Update release_notes:http://kb.netgear.com/app/answers/detail/a_id/29938 md5sum:7d47463d9c9014d7dc3a1cd8b88d33a7 time:1443207354
INFO: dpv_=dpv_1444328426000, njl_id_=njl_id_1131, type=FirmwareUpdate
argv[1] = getfw
argv[2] = dpv_1444328426000
child pid=2370
INFO: dpv_=dpv_1444328426000, njl_id_=njl_id_1135, type=FirmwareProgress
ERROR:fwbroker.c:853:aaGetFileArray::No such file or directory
INFO:PROGRESS: PENDING: progress=0
INFO: dpv_=dpv_1444328426000, njl_id_=njl_id_1133, type=FirmwareProgress
INFO:DOWNLOAD_PROCESS:(STEP 2 URL:) http://update.readynas.com/download/ReadyNASOS-arm/verify_license?serial_number=3EP335EW002DF&model=...
INFO:START_DOWNLOAD_DEMON:(STEP 3 URL:) http://update.readynas.com/download/ReadyNASOS-arm/verify_license?serial_number=3EP335EW002DF&reques...
INFO: dpv_=dpv_1444328426000, njl_id_=njl_id_1215, type=FirmwareProgress
INFO:PROGRESS: PENDING: progress=3
INFO: dpv_=dpv_1444328426000, njl_id_=njl_id_1217, type=FirmwareProgress
INFO:PROGRESS: PENDING: progress=11
INFO: dpv_=dpv_1444328426000, njl_id_=njl_id_1255, type=FirmwareProgress
WARNING:fwbroker.c:864:aaGetFileArray::Success
WARNING:fwbroker.c:868:aaGetFileArray::Success
INFO: dpv_=dpv_1444328426000, njl_id_=njl_id_1257, type=FirmwareProgress
INFO:PROGRESS: PENDING: progress=27
INFO: dpv_=dpv_1444328426000, njl_id_=njl_id_1265, type=FirmwareProgress
INFO:PROGRESS: PENDING: progress=35
INFO: dpv_=dpv_1444328426000, njl_id_=njl_id_1267, type=FirmwareProgress
INFO:PROGRESS: PENDING: progress=42
INFO: dpv_=dpv_1444328426000, njl_id_=njl_id_1305, type=FirmwareProgress
INFO:PROGRESS: PENDING: progress=50
INFO: dpv_=dpv_1444328426000, njl_id_=njl_id_1307, type=FirmwareProgress
INFO:PROGRESS: PENDING: progress=58
INFO: dpv_=dpv_1444328426000, njl_id_=njl_id_1311, type=FirmwareProgress
INFO:PROGRESS: PENDING: progress=66
INFO: dpv_=dpv_1444328426000, njl_id_=njl_id_1313, type=FirmwareProgress
INFO:PROGRESS: PENDING: progress=73
INFO: dpv_=dpv_1444328426000, njl_id_=njl_id_1351, type=FirmwareProgress
INFO:PROGRESS: PENDING: progress=81
INFO: dpv_=dpv_1444328426000, njl_id_=njl_id_1353, type=FirmwareProgress
INFO:PROGRESS: PENDING: progress=89
INFO: dpv_=dpv_1444328426000, njl_id_=njl_id_1355, type=FirmwareProgress
INFO:START_DOWNLOAD_DEMON: complete=63391744
INFO:START_DOWNLOAD_DEMON: write firmware file to the disk bytes=63391744
INFO:START_DOWNLOAD_DEMON: Checking file for md5...
INFO:CHECK_MD5_SUM: local=7d47463d9c9014d7dc3a1cd8b88d33a7 remote=7d47463d9c9014d7dc3a1cd8b88d33a7
INFO:CHECK_MD5_SUM: MD5 OK! Create link in /etc/.flash_update -> .flash_update_file
INFO:retrieve update information: version=6.4.0, size=63391744, descr=ReadyNASOS Update, url=http://kb.netgear.com/app/answers/detail/a_id/29938
INFO: GETFW: READY, REBOOT IN TIMEOUT
INFO: dpv_=dpv_1444328426000, njl_id_=njl_id_1357, type=FirmwareProgress
INFO:PROGRESS: SUCCESS
INFO: dpv_=dpv_1444328594000, njl_id_=njl_id_307, type=FirmwareProgress
INFO: dpv_=dpv_1444328594000, njl_id_=njl_id_377, type=FirmwareImage
INFO: dpv_=dpv_1444328611000, njl_id_=njl_id_307, type=FirmwareProgress
INFO: dpv_=dpv_1444328611000, njl_id_=njl_id_382, type=FirmwareImage
INFO: dpv_=dpv_1444328611000, njl_id_=njl_id_2638, type=FirmwareProgress
cgi_log: DEBUG:UPLOAD_IMAGE: Write image .flash_update_file...
cgi_log: DEBUG:UPLOAD_IMAGE: Write 63391744 bytes... MD5=7d47463d9c9014d7dc3a1cd8b88d33a7
NOTICE:fwbroker.c:1802:safe_errno::No such file or directory
INFO:UPLOAD_IMAGE: _filename_=ReadyNASOS-6.4.0-arm.img _filesize_=63391744
INFO:GET_REMOTE_INFO: name=ReadyNASOS version=6.4.0 size=63391744 md5=7d47463d9c9014d7dc3a1cd8b88d33a7 arch=arm
INFO: arch=arm personality= sysinfo->personality=1
INFO:UPLOAD_IMAGE: Checking file for md5...
INFO:UPLOAD_IMAGE: Write info to .flash_update_info...
INFO:UPLOAD_IMAGE: SUCCESS
INFO: dpv_=dpv_1444328611000, njl_id_=njl_id_2818, type=FirmwareProgress
INFO:retrieve update information: version=6.4.0, size=63391744, descr=arm, url=local image
INFO: dpv_=dpv_1444329550000, njl_id_=njl_id_307, type=FirmwareProgress
INFO: dpv_=dpv_1444329550000, njl_id_=njl_id_382, type=FirmwareImage
INFO: dpv_=dpv_1444329552000, njl_id_=njl_id_307, type=FirmwareProgress
INFO: dpv_=dpv_1444329552000, njl_id_=njl_id_382, type=FirmwareImage
INFO: dpv_=dpv_1444329550000, njl_id_=njl_id_1793, type=FirmwareUpdate
argv[1] = getfw
argv[2] = dpv_1444329550000
child pid=1696
INFO: dpv_=dpv_1444329550000, njl_id_=njl_id_1797, type=FirmwareProgress
ERROR:fwbroker.c:868:aaGetFileArray::No such file or directory
INFO: dpv_=dpv_1444329550000, njl_id_=njl_id_1795, type=FirmwareProgress
INFO: dpv_=dpv_1444329550000, njl_id_=njl_id_1800, type=FirmwareProgress
INFO: dpv_=dpv_1444329550000, njl_id_=njl_id_1802, type=FirmwareProgress
INFO:PROGRESS: PENDING: progress=15
INFO: dpv_=dpv_1444329550000, njl_id_=njl_id_1812, type=FirmwareProgress
INFO:PROGRESS: PENDING: progress=26
INFO: dpv_=dpv_1444329550000, njl_id_=njl_id_1848, type=FirmwareProgress
INFO:PROGRESS: PENDING: progress=36
INFO: dpv_=dpv_1444329550000, njl_id_=njl_id_1850, type=FirmwareProgress
INFO:PROGRESS: PENDING: progress=47
INFO: dpv_=dpv_1444329550000, njl_id_=njl_id_1852, type=FirmwareProgress
INFO: dpv_=dpv_1444329550000, njl_id_=njl_id_1892, type=FirmwareProgress
INFO:PROGRESS: PENDING: progress=69
INFO: dpv_=dpv_1444329550000, njl_id_=njl_id_1894, type=FirmwareProgress
INFO:PROGRESS: PENDING: progress=79
INFO: dpv_=dpv_1444329550000, njl_id_=njl_id_1896, type=FirmwareProgress
INFO: dpv_=dpv_1444329550000, njl_id_=njl_id_1934, type=FirmwareProgress
INFO: dpv_=dpv_1444330393000, njl_id_=njl_id_307, type=FirmwareProgress
INFO: dpv_=dpv_1444330393000, njl_id_=njl_id_382, type=FirmwareImage
INFO: dpv_=dpv_1444330502000, njl_id_=njl_id_307, type=FirmwareProgress
INFO: dpv_=dpv_1444330502000, njl_id_=njl_id_382, type=FirmwareImage
INFO: dpv_=dpv_1444330393000, njl_id_=njl_id_8820, type=FirmwareProgress
- Mark as New
- Bookmark
- Subscribe
- Permalink
argv[1] = getfw
child pid=2370
argv[1] = getfw
child pid=1696
