× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNASOS 6.9.3-RC1 RN516 front display not working
rybackisback
The front display and touchpad stopped working with 6.9.3 RC1
Message 1 of 11
mdgm-ntgr
NETGEAR Employee Retired
Re: ReadyNASOS 6.9.3-RC1 RN516 front display not working
Can you send in your logs (see the Sending Logs link in my sig)?
Message 2 of 11
rybackisback
Logs sent.
Model: RN51600|ReadyNAS 516 6-Bay
Message 3 of 11
mdgm-ntgr
Your system is complaining about not being able to write to the root volume. If you disable the anti-virus service (just for testing) do you still have problems?
Message 4 of 11
rybackisback
Which log would indicate that I am having trouble writing to the root volume?
I have now disabled the anti-virus service. Should I resend the logs?
Message 5 of 11
mdgm-ntgr
I saw errors in dmesg.log
Have you tried a reboot?
You can send a fresh set of logs if you like.
Message 6 of 11
rybackisback
logs sent after switching off the antivirus and a reboot.
Message 7 of 11
Iridahonda
The display works just fine on my 516 but are you running a custom kernel configuration?  I have seen the problem you describe when the display module is not matched with the kernel build.
Message 8 of 11
OOM-9
NETGEAR Expert
Is the front pannel working better after disabling AV and reboot the RN516?
If you were still having issues after that case, can you enable secure diagnostics mode and PM me the 5-digit number?
Message 9 of 11
rybackisback
Thanks. It works now. Does that mean I should keep the anitvirus turned off for the front display to work?
Message 10 of 11
OOM-9
NETGEAR Expert
I would suggest to keep the AV off for now on the beta release. It appears that the front pannel might be a side effort of other possible issues with AV. Example: We have observed some issues with installing apps when AV is enabled.
We are currently working on resolving this issue.
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 3025 views
  • 1 kudo
  • 4 in conversation
Announcements
