× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNASOS 6.9.3-RC1 on PRO 6
Supertramp11
Luminary
Installed ReadyNASOS 6.9.3-RC1 on my PRO 6 this morning. No issues so far. Just discovered when shutting down the PRO 6 using the power button, it says Powering Off and goes off, where previous versions went from Powering Off to Shutting Down and then switched off.
Non-issue for me, but thought I share it.
Message 1 of 4
Labdoc1
Luminary
Re: ReadyNASOS 6.9.3-RC1 on PRO 6
MeToo 😉
Message 2 of 4
Sandshark
Sensei
Does the log show a "Shutting down" entry and does it appear to take the right amount of time?  My Pro2, which is the only one I run beta software on, has no display.  But the power-down process still seems to be the right length and has the same log entry as before.
Message 3 of 4
Supertramp11
Luminary
Re: ReadyNASOS 6.9.3-RC2 on PRO 6
Installed ReadyNASOS 6.9.3-RC2 on my PRO 6 this morning. No issues so far. Just discovered when shutting down the PRO 6 using the power button, it says Powering Off and goes off, where previous versions went from Powering Off to Shutting Down and then switched off.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1621 views
  • 1 kudo
  • 3 in conversation
Announcements
