× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNASOS 6.9.3-RC2 ReadDr not worrking on Pro 6 and Pro4
Nr4
Hi everybody!
This is the first time I report this (my) ReadyDr issue, 'cause netgear is cutting services...
when I try to setup a RDR-job from rndp4, running 6.92, to rndp6, runnig 6.whatever (last try: 6.93-rc2), the firmware says there is no RDR-Share on the Pro6. There is one by default, as you know. After creating a new one, one can create the job.
The job won't work.
If I try to create a second job, the software still says there is no RDR-share, even the software and I just created a second one...
Anyone has a clue about this?
I noticed there are many ReadyNas problems connected to space, so here is the pro6 df:
root@Nr4:~# df -h
Filesystem Size Used Avail Use% Mounted on
udev 10M 4.0K 10M 1% /dev
/dev/md0 4.0G 1.2G 2.5G 32% /
tmpfs 494M 0 494M 0% /dev/shm
tmpfs 494M 3.8M 491M 1% /run
tmpfs 247M 1.6M 246M 1% /run/lock
tmpfs 494M 0 494M 0% /sys/fs/cgroup
/dev/md127 2.8T 1.9T 870G 69% /data
/dev/md127 2.8T 1.9T 870G 69% /home
/dev/md127 2.8T 1.9T 870G 69% /apps
tmpfs 50M 0 50M 0% /var/replicate/shm
tmpfs 4.0K 0 4.0K 0% /data/RDR/snapshot
tmpfs 4.0K 0 4.0K 0% /data/ReadyDR/snapshot
Best regards,
Martin
Ps: md0 is quite full, investigating this. But even with quite more space, rdr was not working...
Model: ReadyNAS RNDP6000|ReadyNAS Pro 6 Chassis only
Message 1 of 5
mdgm-ntgr
NETGEAR Employee Retired
Re: ReadyNASOS 6.9.3-RC2 ReadDr not worrking on Pro 6 and Pro4
A full root volume is something to rule out, but 32% full is nothing to be worried about.
What does your initrd.log look like?
Message 2 of 5
Nr4
Hi mdgm!
Thank for your reply.
Pro4: initrd.log:
[2015/05/02 14:53:10] Factory default initiated by button!
[2015/05/02 14:53:16] Defaulting to X-RAID2 mode, RAID level 1
[2015/05/02 14:53:26] Factory default initiated on ReadyNASOS 6.2.4 (ReadyNASOS).
[2015/10/11 12:51:41] Updated from ReadyNASOS 6.2.4 (ReadyNASOS) to 6.4.0 (ReadyNASOS).
[2016/02/02 05:38:08] Updated from ReadyNASOS 6.4.0 (ReadyNASOS) to 6.4.2 (ReadyNASOS).
[2016/05/30 00:33:20] Updated from ReadyNASOS 6.4.2 (ReadyNASOS) to 6.5.0 (ReadyNASOS).
[2016/06/15 11:06:34] Updated from ReadyNASOS 6.5.0 (ReadyNASOS) to 6.5.1 (RC1).
[2016/06/25 09:49:19] Updated from ReadyNASOS 6.5.1 (RC1) to 6.5.1 (ReadyNASOS).
[2016/07/31 11:47:52] Updated from ReadyNASOS 6.5.1 (ReadyNASOS) to 6.5.2-T486 (Beta 1).
[2016/08/09 09:34:52] Updated from ReadyNASOS 6.5.2-T486 (Beta 1) to 6.5.2-T500 (Beta 2).
[2016/09/25 10:19:23] Updated from ReadyNASOS 6.5.2-T500 (Beta 2) to 6.5.2 (ReadyNASOS).
[2016/11/01 12:09:41] Updated from ReadyNASOS 6.5.2 (ReadyNASOS) to 6.6.0 (ReadyNASOS).
[2017/03/23 16:08:28 UTC] OS version mismatch [os: 6.6.0(1474937380) / flash: 6.7.0-T180(1488562669)]
[2017/03/23 16:09:12 UTC] Updated from ReadyNASOS 6.6.0 (ReadyNASOS) to 6.7.0-T180 (Beta 3).
[2017/04/02 16:16:12 UTC] Could not update flash device!
[2017/04/20 22:52:06 UTC] OS version mismatch [os: 6.7.0-T180(1488562669) / flash: 6.7.0(1490745041)]
[2017/04/20 22:52:12 UTC] Update checksum verification failed!  Aborting.
[2017/04/20 22:52:14 UTC] Update image checksum mismatch (c188d145c922f58cd902cf8a5746a968/6af3a6da648f7110b913253efbad01ed)!
[2017/04/21 14:26:25] OS version mismatch [os: 6.7.0-T180(1488562669) / flash: 6.6.1(1482880160)]
[2017/04/21 14:26:25] Update image is too old!
[2017/04/24 11:33:18] OS version mismatch [os: 6.7.0-T180(1488562669) / flash: 6.6.1(1482880160)]
[2017/04/24 11:33:51] Updated from ReadyNASOS 6.7.0-T180 (Beta 3) to 6.6.1 (ReadyNASOS).
[2017/04/24 12:14:13] Updated from ReadyNASOS 6.6.1 (ReadyNASOS) to 6.6.1 (ReadyNASOS).
[2017/04/24 12:25:44] Updated from ReadyNASOS 6.6.1 (ReadyNASOS) to 6.6.1 (ReadyNASOS).
[2017/04/24 12:33:25] Could not update flash device!
[2017/04/24 18:39:29 UTC] Updated from ReadyNASOS 6.6.1 (ReadyNASOS) to 6.7.1-T252 (Beta 2).
[2017/04/28 08:12:52 UTC] Updated from ReadyNASOS 6.7.1-T252 (Beta 2) to 6.7.1 (ReadyNASOS).
[2017/05/26 15:31:50 UTC] Could not update flash device!
[2017/05/26 17:23:45 UTC] OS version mismatch [os: 6.7.1(1493061041) / flash: 6.7.3(1495576950)]
[2017/05/26 17:24:19 UTC] Updated from ReadyNASOS 6.7.1 (ReadyNASOS) to 6.7.3 (ReadyNASOS).
[2017/05/27 17:06:49 UTC] Could not update flash device!
[2017/05/27 17:34:26 UTC] OS version mismatch [os: 6.7.3(1495576950) / flash: 6.7.4(1495750799)]
[2017/05/27 17:34:32 UTC] Update checksum verification failed!  Aborting.
[2017/05/27 17:34:34 UTC] Update image checksum mismatch (9d830f343b0acd2aae61c00fd807569e/0d77177efbc017564cab44b08ccd869f)!
[2017/05/27 17:45:57 UTC] OS version mismatch [os: 6.7.3(1495576950) / flash: 6.7.4(1495750799)]
[2017/05/27 17:46:31 UTC] Updated from ReadyNASOS 6.7.3 (ReadyNASOS) to 6.7.4 (ReadyNASOS).
[2017/08/08 15:51:06 UTC] Could not update flash device!
[2017/08/08 15:56:19 UTC] OS version mismatch [os: 6.7.4(1495750799) / flash: 6.8.0(1501781288)]
[2017/08/08 15:56:55 UTC] Updated from ReadyNASOS 6.7.4 (ReadyNASOS) to 6.8.0 (ReadyNASOS).
[2017/09/30 19:31:39 UTC] Could not update flash device!
[2017/10/01 15:10:36 UTC] OS version mismatch [os: 6.8.0(1501781288) / flash: 6.8.1(1505863013)]
[2017/10/01 15:11:10 UTC] Updated from ReadyNASOS 6.8.0 (ReadyNASOS) to 6.8.1 (ReadyNASOS).
[2017/10/26 20:40:54 UTC] Could not update flash device!
[2017/10/27 13:17:17 UTC] Updated from ReadyNASOS 6.8.1 (ReadyNASOS) to 6.9.0 (ReadyNASOS).
[2017/12/10 19:21:35 UTC] Updated from ReadyNASOS 6.9.0 (ReadyNASOS) to 6.9.0 (ReadyNASOS).
[2018/01/14 19:23:12 UTC] Updated from ReadyNASOS 6.9.0 (ReadyNASOS) to 6.9.0 (ReadyNASOS).
[2018/01/16 16:25:35 UTC] Updated from ReadyNASOS 6.9.0 (ReadyNASOS) to 6.9.2 (ReadyNASOS).
Pro6 initrd.log:
[2015/10/02 10:38:18] OS version mismatch [os: 6.4.0-T147(1442878516) / flash: 6.2.4(1430414564)]
[2015/10/02 10:38:31] Updated from ReadyNASOS 6.4.0-T147 (Beta 6) to 6.2.4 (ReadyNASOS).
[2015/10/02 10:56:00] OS version mismatch [os: 6.2.4(1430414564) / flash: 6.4.0-T147(1442878516)]
[2015/10/02 10:56:06] Update checksum verification failed!  Aborting.
[2015/10/02 11:03:39] OS version mismatch [os: 6.2.4(1430414564) / flash: 6.4.0-T147(1442878516)]
[2015/10/02 11:04:11] Updated from ReadyNASOS 6.2.4 (ReadyNASOS) to 6.4.0-T147 (Beta 6).
[2015/11/24 18:46:59] Updated from ReadyNASOS 6.4.0-T147 (Beta 6) to 6.4.0 (ReadyNASOS).
[2015/12/14 13:04:51] Updated from ReadyNASOS 6.4.0 (ReadyNASOS) to 6.4.1 (ReadyNASOS).
[2016/01/13 04:50:25] Updated from ReadyNASOS 6.4.1 (ReadyNASOS) to 6.4.2-T72 (Beta 2).
[2016/01/17 13:21:21] Updated from ReadyNASOS 6.4.2-T72 (Beta 2) to 6.4.2 (RC1).
[2016/02/02 05:29:02] Updated from ReadyNASOS 6.4.2 (RC1) to 6.4.2 (ReadyNASOS).
[2016/03/21 18:14:44] Updated from ReadyNASOS 6.4.2 (ReadyNASOS) to 6.5.0-T338 (Beta 2).
[2016/04/25 12:13:13] Updated from ReadyNASOS 6.5.0-T338 (Beta 2) to 6.5.0 (RC1).
[2016/05/02 11:49:37] Updated from ReadyNASOS 6.5.0 (RC1) to 6.5.0 (RC2).
[2016/05/07 20:33:44] Updated from ReadyNASOS 6.5.0 (RC2) to 6.5.0 (RC3).
[2016/05/20 05:06:59] Updated from ReadyNASOS 6.5.0 (RC3) to 6.5.0 (ReadyNASOS).
[2016/06/19 12:25:27] Updated from ReadyNASOS 6.5.0 (ReadyNASOS) to 6.5.1 (RC1).
[2016/08/09 09:13:08] Updated from ReadyNASOS 6.5.1 (RC1) to 6.5.2-T500 (Beta 2).
[2016/08/09 11:33:43] Updated from ReadyNASOS 6.5.2-T500 (Beta 2) to 6.6.0-T95 (Beta 1).
[2016/08/24 01:39:54] Updated from ReadyNASOS 6.6.0-T95 (Beta 1) to 6.6.0-T117 (Beta 2).
[2016/09/25 13:29:20] Updated from ReadyNASOS 6.6.0-T117 (Beta 2) to 6.6.0 (RC2).
[2016/10/04 10:40:45] Updated from ReadyNASOS 6.6.0 (RC2) to 6.6.0 (ReadyNASOS).
[2017/01/15 10:17:31] Could not update flash device!
[2017/01/15 10:25:05] OS version mismatch [os: 6.6.0(1474937380) / flash: 6.6.1(1482880160)]
[2017/01/15 10:25:36] Updated from ReadyNASOS 6.6.0 (ReadyNASOS) to 6.6.1 (ReadyNASOS).
[2017/02/25 09:33:14] Could not update flash device!
[2017/02/25 16:50:51 UTC] Updated from ReadyNASOS 6.6.1 (ReadyNASOS) to 6.7.0-T169 (Beta 2).
[2017/03/03 23:50:32 UTC] Could not update flash device!
[2017/03/04 00:06:54 UTC] OS version mismatch [os: 6.7.0-T169(1487803393) / flash: 6.7.0-T180(1488562669)]
[2017/03/04 00:07:38 UTC] Updated from ReadyNASOS 6.7.0-T169 (Beta 2) to 6.7.0-T180 (Beta 3).
[2017/04/24 16:11:44 UTC] Updated from ReadyNASOS 6.7.0-T180 (Beta 3) to 6.7.1-T252 (Beta 2).
[2017/04/28 07:54:45 UTC] Updated from ReadyNASOS 6.7.1-T252 (Beta 2) to 6.7.1 (ReadyNASOS).
[2017/10/02 15:45:13 UTC] Updated from ReadyNASOS 6.7.1 (ReadyNASOS) to 6.9.0-T80 (Beta 3).
[2017/10/26 00:01:50 UTC] Updated from ReadyNASOS 6.9.0-T80 (Beta 3) to 6.9.0 (ReadyNASOS).
[2018/01/14 19:31:26 UTC] Could not properly extract root image!
[2018/01/14 19:31:28 UTC] Updated from ReadyNASOS 6.9.0 (ReadyNASOS) to 6.9.0 (ReadyNASOS).
[2018/01/16 17:28:40 UTC] Could not find update image!
[2018/01/16 17:33:27 UTC] Update image checksum mismatch (81a99d6da014ade17eaa416d1572788a/727a845f701d2a8fcb9e921b69d65870)!
[2018/01/16 17:54:10 UTC] Update image checksum mismatch (81a99d6da014ade17eaa416d1572788a/aa590f8e690c651b4076f185ff8857f8)!
[2018/01/26 16:08:31 UTC] Could not read update image!
[2018/01/26 17:32:24 UTC] Updated from ReadyNASOS 6.9.0 (ReadyNASOS) to 6.9.3-T211 (Beta 1).
[2018/02/04 20:22:59 UTC] Updated from ReadyNASOS 6.9.3-T211 (Beta 1) to 6.9.3-T223 (Beta 2).
[2018/02/17 19:58:12 UTC] Updated from ReadyNASOS 6.9.3-T223 (Beta 2) to 6.9.3 (RC1).
[2018/02/24 17:39:09 UTC] Updated from ReadyNASOS 6.9.3 (RC1) to 6.9.3 (RC2).
Btw:
the Pro4 ist at the moment only via ssh accessible. Even 'reboot now' ist not working:
Welcome to ReadyNASOS 6.9.2
Last login: Thu Mar 1 21:31:40 2018 from 192.168.164.114
reboot now
root@JANA:~# reboot now
Failed to start reboot.target: Connection timed out
See system logs and 'systemctl status reboot.target' for details.
Failed to open /dev/initctl: No such device or address
Failed to talk to init daemon.
root@JANA:/# systemctl status reboot.target
Failed to get properties: Connection timed out
 The display shows:
"unmap_single_vma+a5"
One can also take a look at: https://community.netgear.com/t5/Using-your-ReadyNAS/Rn-PRO-4-6-7-4-free-pages-and-swap-cache-3d-on-... about on going problems.
best regards
Message 3 of 5
mdgm-ntgr
That's a lot of firmware updates including a lot of betas.
The downgrade from 6.4.0 to 6.2.4 was not a supported downgrade either.
There are signs that your root volume was probably full on each systems at different times.
Seeing running OS6 on your system is not supported I think it could be best for you to backup your data, do a factory reset (wipes all data, settings, everything), manually reconfigure your NAS, restore your data from backup and see how ReadyDR goes on a clean install.
Message 4 of 5
Nr4
Thanks for your repley.
I will try this an let you know.
Best regards.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1655 views
  • 0 kudos
  • 2 in conversation
Announcements
