Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Readynas Pro -NOT updating, Pioneer =OK
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-01-18
08:56 AM
2012-01-18
08:56 AM
Hi, I got 2 readynas 6 bay devices.
1 pro pioneer6 with 6x1tb
and
1 pro6 with 6 x 3 tb drives.
Both been working ok. But applying the latest 2 different builds of 4.2.20 only works on the Pro Pioneer box.
( tested with both build 23 and now build 28 )
Updated Pro pioneer, prompted to reboot = everything OK.
Updating the Pro, uploading the file, then "to fast" get a message update complete, please reboot.
Rebooting do NOT work. I previously tested by doing a hard power-off and then power-on again. After that, no system log, etc.
But, scenario is still the same, The pro6 box simply refuses to do anything with the last 2 updates. What I found however
is that when the update doesn't "take" and no reboot can be achieved, I instead re-install the enable SSH again which prompts for a reboot
and DO reboot the unit. Still, the firmware do not update.
Edit; Addition; Both units (when I started) 4.2.20 - t19
and
Message 1 of 8
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-01-18
09:40 AM
2012-01-18
09:40 AM
Re: Readynas Pro -NOT updating, Pioneer =OK
this may be a case of full root. either all space is taken or all inodes are used up.
techsupport should be able to check which is the case.
Message 2 of 8
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-01-18
11:10 AM
2012-01-18
11:10 AM
Actually, the Pro unit is more or less brand new. Updating it was the first thing I did, so it might be true....
Worth noting; both the pro and the pro pioneer was previously "non-beta" versions initially so both succeeded in going from
previous version to the T19 build.
Message 3 of 8
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-01-18
12:39 PM
2012-01-18
12:39 PM
I recommend contacting support. If the units are new see if after a factory default you can apply the update.
Message 4 of 8
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-01-19
06:59 AM
2012-01-19
06:59 AM
Doing a df -h to check space, this is reported;
dev# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/md0 4.0G 3.8G 16M 100% /
tmpfs 16K 0 16K 0% /USB
/dev/c/c 14T 6.5T 7.2T 48% /c
/c/Media2 14T 6.5T 7.2T 48% /home/ftp/Media2
df -BG
Filesystem 1G-blocks Used Available Use% Mounted on
/dev/md0 4G 4G 1G 100% /
tmpfs 1G 0G 1G 0% /USB
/dev/c/c 13885G 6598G 7288G 48% /c
/c/Media2 13885G 6598G 7288G 48% /home/ftp/Media2
dev# df -h
df -BG
Message 5 of 8
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-01-19
07:23 AM
2012-01-19
07:23 AM
Seems there was some "admin download something something...zip" that was 3.5 GB in /tmp
I guess that's NOT by design!
- Removed that file in /tmp, rebooted and retried the fw update = OK again !
Case closed
Case closed
Message 6 of 8
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-01-19
01:37 PM
2012-01-19
01:37 PM
What was that file called? Did you have any add-ons installed?
Message 7 of 8
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-01-19
10:23 PM
2012-01-19
10:23 PM
No add-ons besides SSH access, it was called something like admindownload??????.zip
Message 8 of 8
