× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
rn104 freezes on shutdown
pdasterly
Guide
new firmware now system hangs on shutdown
Message 1 of 14
Accepted Solutions
mdgm-ntgr
NETGEAR Employee Retired
Re: rn104 freezes on shutdown
There is a bit going on this system.
You have four volumes and the system is still looking for a few old volumes you used to have in the NAS.
Also I see you are running the ReadyDLNA and iTunes Server services. Can you check if the system shuts down properly if you disable these?
I can see you have installed some apps e.g. MySQL, Transmission etc. however Transmission doesn't appear to be installed correctly. I'm not seeing the app from Available Apps in the web admin interface or apps.readynas.com installed.
Also you are using some SeaGate 8TB archive disks. These are not on the compatibility list.
Message 11 of 14
All Replies
BrianL2
Hi pdasterly,
Is there a backup job running? Any apps installed or running in your system? Did you shut the unit down using the GUI option or graceful shutdown method?
Looking forward to your response.
Kind regards,
BrianL
NETGEAR Community Team
Message 2 of 14
pdasterly
Guide
no backups, no apps installed. Shutdown using webadmin page
Message 3 of 14
BrianL2
Hi pdasterly,
If you will try to manually shut it down, will you get the same behavior? I'm currently testing it on my own unit and I will post the result afterwards.
Kind regards,
BrianL
Message 4 of 14
pdasterly
Guide
same result when manual shutdown sequence is performed
Message 5 of 14
BrianL2
Hi pdasterly,
How many NICs are active? Is power timer feature enabled?
Kind regards,
BrianL
Message 6 of 14
pdasterly
Guide
if you mean network connection, then 1. I have single cat6 running to my switch. Power timer disabled
Message 7 of 14
BrianL2
Hi pdasterly,
Mine's working just fine, either GUI triggered or graceful shutdown on the main unit. Can you send us a copy of your device logs?
Kind regards,
BrianL
Message 8 of 14
pdasterly
Guide
how do i send logs
Message 9 of 14
mdgm-ntgr
See the Sending Logs link in my sig.
Message 10 of 14
mdgm-ntgr
Message 11 of 14
pdasterly
Guide
disabled both dlna and itunes now system shutsdown correctly
Message 12 of 14
mdgm-ntgr
O.K. So it could be that one of those services was preventing it from shutting down correctly. You try enabling one of them then shutting down, then booting again and disabling the service again and enabling the other and seeing if it shuts down correctly with that one enabled.
Message 13 of 14
pdasterly
Guide
disable is ok for me, i don't use either. media player uses lan or nfs
Message 14 of 14
Top Contributors
Discussion stats
  • 13 replies
  • 6789 views
  • 0 kudos
  • 3 in conversation
Announcements
