Orbi WiFi 7 RBE973
Reply
Pioneer Pro upgraded to OS6 cant connect to readycloud.
rklunder
I have a pioneer pro upgraded to OS6 (currently 6.10.3) whose serial number matches eth0 causing issues connecting to ReadyCloud. Is there a solution I can implement to get the serial number corrected? The old posts had an admin correct it, can i still get that done? I would like to have this device show up in ReadyCloud with my ReadyNAS 516. Thank you for your reply.
Model: RNDP600E (ReadyNAS Pro Pioneer Edition)|ReadyNAS Pro Pioneer Edition|EOL
Message 1 of 4
Accepted Solutions
JohnCM_S
NETGEAR Employee Retired
Re: Pioneer Pro upgraded to OS6 cant connect to readycloud.
Hi rklunder,
The fix has been applied. Please check if it has the correct serial number now.
Message 3 of 4
All Replies
JohnCM_S
Hi rklunder,
We can apply the fix for that. You may take a picture first of the sticker that contains the serial number which is found at the rear panel of the chassis, then send it to me via private message.
Message 2 of 4
JohnCM_S
Hi rklunder,
Message 3 of 4
rklunder
Thank you for the prompt and effective response. All is corrected. Stay safe and may you stay free of COVID-19!
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1779 views
  • 2 kudos
  • 2 in conversation
Announcements
