Orbi WiFi 7 RBE973
Reply
RN 104 problem with ReadyCloud registration
Guru
Re: RN 104 problem with ReadyCloud registration
Are you adding routes?  For instance, 8.8.8.8.
8.8.8.8 is a DNS server, the gateway should be your router's IP (192.168.1.1).
Message 26 of 30
bigawplano
Yes, I've added those DNS entries (see attached).  I realized a few mins ago that my hostname had a "_" which is an invalid character.  I changed it to a "-" but it made no difference to my problem.
Message 27 of 30
bigawplano
And I do not have any routes specified.  Should I?
Message 28 of 30
Guru
No.  The IP setup looks correct.
Message 29 of 30
bigawplano
NETGEAR community,
I am at my wits end here.  I've tried a few different things:
  1. I changed a character in my hostname, and this change appeared in my ReadyCloud portal.  To me, this confirms my readynas has internet connectivity and is in communication with the ReadyCloud portal.
  2. I removed my ReadyNAS from the ReadyCloud portal, and it reappears 50 secs later.
  3. I then try to enable ReadyCloud on my ReadyNAS to no avail.
I've attached screenshots for all these.
  • It sure looks like something is broken with the ReadyCloud portal if it wont allow me to unregister my ReadyNAS.
  • Something is also amiss with the ReadyNAS because it does show "Internet Available" indicator.
Any ideas?
Message 30 of 30
Top Contributors
Discussion stats
  • 29 replies
  • 4966 views
  • 0 kudos
  • 4 in conversation
Announcements
