Orbi WiFi 7 RBE973
Reply
ReadyCloud Firewall Settings
tailorbmw
Hi All
Wondering if you could give me some information that our Firewall company is after. We have a ReadyNAS unit which we use Ready cloud on. At the moment ReadyCloud is setup on the Readynas and has been working but a firmware update on the firewall has cause this to disconnect now and the firewall company want settings ports/IPs that they need to open up so we can access our files via ReadyCloud.
Does anyone have these details?
Thanks
Message 1 of 7
Guru
Re: ReadyCloud Firewall Settings
It uses port 6300.
The cloud servers are hosted by amazon cloudfront - not sure what IP addresses are used for the VPN servers though.
Message 2 of 7
tailorbmw
is there anyway of find out?
Message 3 of 7
jak0lantash
Mentor
Port mirroring + Wireshark...
Or tcpdump on the NAS if you're more adventurous and not afraid to void your Support entitlement.
Message 4 of 7
Guru
I wouldn't assume that the IP addresses are immutable.
It'd be better to publish the DNS name[s] of the traversal servers.
Message 5 of 7
tailorbmw
Do you know what the DNS servers are?
Message 6 of 7
Guru
I think you mean the NAT traversal servers.  I don't know their URLs.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 3812 views
  • 0 kudos
  • 3 in conversation
Announcements
