- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyCloud v2.0.1(today updated) but seems it doesn't work
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi anyone,
Do you update to the latest version ReadyCloud v2.0.1 (iPhone 7+), but seems it doesn't work.
Just start the app and nothing happens, does anyone have the same issue?
Can't logout or select in the left upper menu!
I can't see the device also, before the update it was possible!
@netgear: Did Netgear check carefully the latest version before updating?
Do you have recomments what further to do for all customers how have the same issue?
Klaus
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello all
I uploaded patch files(fix 409 conflict issue) to ReadyCLOUD,please download them at
for X86 device
https://readycloud.netgear.com/client/dllink.html#t=002jm6o5pm6/readynasos_6.9.3%2B3_amd64.deb
for ARM device
https://readycloud.netgear.com/client/dllink.html#t=07g704laopx/readynasos_6.9.3%2B3_armel.deb
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyCloud v2.0.1(today updated) but seems it doesn't work
Suggestion for all,
Reboot your iPhone and wait a while! (10 min.)
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can logout, yeah....!
Login again and try to upload my pictures >9000 (pictues), but no luck today!
Anyway the latest update doesn't solve the earlier issue (reported last year 2017): "Error Request faild: 409 - conflict (in ReadyCloud)".
Error Request faild: 409 - conflict (in ReadyCloud) - this problem is still there!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Kmalin15
Did you backup photos in your home network(LAN mode)?I don't see such error when backing up 4000+ photos to ReadyNAS.
can you change destination folder to see if it can fix the issue?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
Last year 2017 reported and Netgear knows the issue (please see in a previous chapter of it), but seems still not working after the latest update. ReadyCloud v2.0.1 (iPhone 7+)
All works fine till the latest OS (6.9.3) update!
In between I need to backup more than > 9000 picture!
LAN: there is or was nothing changed. Even when a new directory is created the issue is still there.
Do you have recommends what further to do for all customers how have the same issue?
Actually I curious what happens behind the screen to solve this issue sinds 2017?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
My I asked Netgear why I didn't get any reply on my topic?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Agreed. ReadyCloud v2.0.1 does not work on iOS 11.3. Just tried it again and it still does not work.
Reinstalled the app and still does not work. Get "Error - Network Error occured" after selecting my ReadyNAS unit
Netgear - Any update on a fix?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello greispe
I cannot reproduce "Network error occur" issue when browsing NAS share,my Iphone is 11.3,can you PM me with your account to check the issue?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
CPU: Intel Xeon X3230, Memory: 4 GB, HDD: 4x Hitachi 2TB, System Fan: Noctua 120x25mm NF-F12 Industrial PPC-2000, 71.5 CFM, 2000 rpm, 29.7 dBA, CPU Fan: Delta 80x15mm PWM EFC0812DB ,48.8 CFM, 3800 RPM, 41 dBA
- Mark as New
- Bookmark
- Subscribe
- Permalink
There is clearly a problem with the latest release of Readycloud on the latest iOS release. I have the same issue on my iPhone and several iPads.
I tried it on my older iPad mini with iOS 9 and ReadyCloud 2.0.0 and it works fine, so it might not be a problem with the ReadyNAS O/S.
- Mark as New
- Bookmark
- Subscribe
- Permalink
NETGEAR, the problem clearly lies with the iOS ReadyCLOUD app not being able to use the local LAN when there is one available (unless that is by design and can only get to the NAS through the Internet).
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I confirmed the exact same behavior as Walshlink. The app is definitely flakey. Works on cell connection, doesn't work Local LAN.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi all,
Do you have the same problem as me with ReadyCloud (v2.0.1) on a iPhone (iOS11.3)?
I have a small update:
Netgear provided me today an higher version (v2.0.2) for testing it. It seems that this version also isn't working!
(Even I created a new directory! It's not working)
Netgear is on the moment busy to find the root cause.
When they have found it they will solve it with a new relase!
So keep in touche, I will update this Topic in here when it is solved!
Klaus
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi all,
Netgear provides me a patch update for RedayCloud NAS OS6.9.3.
It seems it works fine, but I need to check my destination directory for more than >9000 pictures.
This coast a lot of time to verify it.... and I need to scedule it...
Netgear will update this topic soon!
Klaus
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any update on the patch for ReadyCloud on iOS?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi all,
Happy to share with you!
To install package,please login admin UI and go to Apps>Upload
I asked Netgear to share both files, beacuse I can't share with you! (I'm sorry)
- AMD64 is for x86 based NAS
- Armel is for ARM
409 conflict issue is caused by an IOS software issue,so after the update issue of your NAS should be resolved.
When the 2 files are added I will close this topic, happy end!
Klaus
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello all
for X86 device
for ARM device
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, just installed the patch on my ReadyNAS 516. Rebooted the NAS, then rebooted my iPhone and started up ReadyCloud. Logged in to my Netgear account. It shows my ReadyNAS box but as soon as I click on it I still have the same error message:
Error
Network error occured
This is on the my home network. When I try the same thing while connected to the cell network, I can log in and see my shares on the ReadyNAS.
Am I missing a step?
