Orbi WiFi 7 RBE973
Reply
ReadyNAS RN104 won't stay connected
drhamad
So I'm struggling on every level with my RN104 (I previously had an X6 for many years).
I've solved a couple of problems, but one big one keeps cropping up - the machine will not stay connected to the network. It'll come on for brief periods after being rebooted, then drops off again. It doesn't show up in ReadyCloud or RAIDar, either, and I cannot access it by IP (and cannot access the admin page).
In addition, when this happens, the screen on the device itself still shows the IP (at least, this time) but pressing the power button or backup button does nothing - it seems locked up.
RN10400
OS 6.2.2
3x4 TB drives
Gigabit ethernet
It's just setup to be a backup device (Time Machine from a Mac mini). I'm starting to get worried as it has been a while since the backup has worked.
Edit: Also, this has been happening since well before 6.2.2
Message 1 of 12
RX
Luminary
Luminary
Re: ReadyNAS RN104 won't stay connected
Have you tried connecting your NAS directly to a PC and check if same problem will occur?
Have you tried doing OS reinstall? Check this link:
http://kb.netgear.com/app/answers/detai ... xlbQ%3D%3D
Do you have a backup of all data stored in your NAS?
Message 2 of 12
drhamad
The NAS is the backup, not the primary data, so it's not a big deal if I lose it on any given day... but day in and day out is a problem.
I didn't know you could connect a ReadyNAS directly to a computer... just USB to the computer?
I have reset the system before... I'm not sure if I've done an OS reinstall though.
Edit: I'm letting it re-sync right now. I'm expecting that'll take all night and then some (it has only done 9% in the last 3 hours).
Message 3 of 12
RX
Luminary
Luminary
You can connect your NAS directly to a PC using an ethernet cable NOT USB cable.
Message 4 of 12
drhamad
Interesting. Good to know. Next time it fails I'll have to try that.
Message 5 of 12
drhamad
And it just crashed again.
Message 6 of 12
drhamad
So to add to this, when I try to reset (not that I think that's going to make anything different), it won't let me scroll through the boot menu options... it only let's me choose normal.
Message 7 of 12
drhamad
I just got it reset... and it froze again when finished.
Message 8 of 12
mdgm-ntgr
NETGEAR Employee Retired
Can you try 6.2.3 Beta?: http://www.readynas.com/forum/viewtopic.php?f=154&t=78866
Can you send me your logs (see the Sending Logs link in my sig)?
Message 9 of 12
drhamad
Logs sent and I'll try 6.2.3 in just a few minutes!
Message 10 of 12
drhamad
This is fun... it's frozen on "Installing FW X-RAID2 Mode" during my last reset... haven't even gotten to being able to install 6.2.3 yet.
Message 11 of 12
drhamad
So I tested each drive individually, wiping them all, and got rid of a drive that might have been problematic, inserting a brand new drive in its place.
I then did a factory reset.
Resync still only made it to 13.20%
Edit:
After redoing everything again, i actually managed to upload the 6.2.3 beta to it... but it never was able to reboot.
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 4348 views
  • 0 kudos
  • 3 in conversation
Announcements
