Orbi WiFi 7 RBE973
Reply
Readycloud not working properly
slavicgrip
Follower
Hey all!
So I have my USB hard drive connected to my R7000 and set up a ready cloud account. It shows my USB hard drive connected to it but when I click browse to view the files it doesn't show them at all in the web browser. It just flips me back to the R7000 icon instead of showing me a directory listing of what is on my USB hard drive. I checked to see if it works on the apple mobile app and I can browse all the files on my USB hard drive perfectly fine. Is anyone else having this issue?
Thanks!
Message 1 of 10
chappcc
Tutor
Re: Readycloud not working properly
I have the same problem. I have a USB hard drive attached to the R7000. I can add files from either Mac or Windows machines, but cannot see files when logging in through ready cloud.netgear.com
Message 2 of 10
Fairytail
Virtuoso
Let me try this if I get the same problem but before doing it may I know web browser did you use or have you tried all browsers?
Message 3 of 10
chappcc
Tutor
The behavior is the same on Safari, Firefox, Chrome in OS X 10.10.3 and IE in Windows 8.1
Message 4 of 10
chappcc
Tutor
After reading about hdd format for Readycloud, I re-formatted my hdd to a single ext4 partition with GPT. It now appears to be working properly with Readycloud. If the situation changes i will update.
Message 5 of 10
Fairytail
Virtuoso
What was the format of your HD which did not work?
Message 6 of 10
chappcc
Tutor
Previously I had two partitions: HFS and FAT32. The hdd was partitioned using my Mac.
The new partition was created using gparted.
Message 7 of 10
chappcc
Tutor
After a month, Readycloud now shows I have no USB drive attached. I can only see the R7000 icon. I can access my USB attached drive directly from my computer (Mac) without issue. Any help is appreciated.
Message 8 of 10
chappcc
Tutor
Reboot (power cycle) and firmware update got me back to Readycloud access.
Message 9 of 10
mondenath
Prodigy
Yes try to update to .30 firmware it does show any no of partion
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 8445 views
  • 0 kudos
  • 4 in conversation
Announcements
