- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Readynas Pro with os6 will not connect to Readycloud
- Mark as New
- Bookmark
- Subscribe
- Permalink
i have an old readynas pro 6 with os6 installed. It won't connect to Readycloud because the nas spits out the mac address on eth0 as the serial number.
i have seen posts on a work around, just nothing current.
thanks
tim
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
The fix has been applied and the NAS has been rebooted to Normal mode. It should have the proper serial number now.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Readynas Pro with os6 will not connect to Readycloud
Hi tdaters,
Can you enable SDM (Secure Diagnostic Mode) on the NAS? We will try apply a fix for that problem. Please PM me the 5-digit port number after enabling it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the same problem
After Update to 9.4. and change the network DNS to 8.8.8.8 and restart the serialnumer change to NONE000200000.
I cannot use READYCLOUD.
It was changed before from stephenB and i could use Readycloud.
But after a restart i got again NONE and no connection to READYCLOUD
with best wishes
Jochen
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Retired_Member
Your NAS has a different cause on why it cannot connect to ReadyCLOUD. L3 tried accessing it remotely but it is unreachable. Please re-enable SDM so we can check again the issue on your NAS.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have re-enabled sdm
Same port number
Thanks
Tim
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am taking the nas off line to replace the power supply.
Will send you a note when it’s back up.
Thanks for you help.
Tim
- Mark as New
- Bookmark
- Subscribe
- Permalink
New power supply is back in. The unit is back in sdm with same number.
thanks
tim
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks so much for helping out on this!!!!
Is there anyway to back this up so that if i get zapped i can take care of it myself?
thanks
tim
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi tdaters,
There is no means to backup the fix done on the NAS but, it was already set to be persistent even if factory reset is done on the NAS.
