- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Remote or readyCloud
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sort of new, setup my NAS several months ago, have access and all mostly works - having some remote connection issues with readyCloud but connect fine with readyNAS remote. I have an idea of the issue and once I return I will investigate further. Back on topic, I still do not fully understand the difference between readyNAS remote and readyCloud. Can someone explain?
Thank You.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello JennC,
I was on a trip and had no access to try anything until recent. Here is what I had to do.
- Logged into Netgear account and remove the NAS
- Logged in to Netgear Remote account and delete it
- Logged back in to Netgear account and search/find my NAS by serial number
- Logged in to my NAS and turn cloud back on and registered with my Netgear account
All is working now. The solution came from Deniro in a private message after reviewing the logs I sent. Apparently, my account did not fully migrate over. Hope this helps someone else if they are having the same issue.
Thank you for your support.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Remote or readyCloud
Hello 4xholic
Welcome to the forum!
ReadyNAS remote is using old P2P account to access ReadyOS4 and ReadyOS5 devices on ReadyNAS Remote utility.to create account you can access website http://remote.readynas.com.
ReadyCLOUD is using MyNETGEAR account(we also call it SSO account) to access ReadyOS6 on ReadyCLOUD client and ReadyCLOUD portal(http://readycloud.netgear.com),
what device are you using?do you have any trouble to access your device remotely?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for the reply Deniro. I have a ReadyNAS 202, guess it's been installed for over a year now (time flies) and it had been working most of the time with little issues. I am running a Macbook Pro (late 2015 - started with late 2010 MBP) and an iPhone 5S, both with the readyCloud app. Most of the time I didn't use the app on the MBP as I have the NAS mapped, so didn't really need the app. I was not regularly using the app on teh iPhone, so I do not know when it actually stopped. But, I first noticed it a couple months ago. When I open the app on my iPhone I see the NAS, click on it and see the root folders. However, when I click on any of those folders I get ERROR, access denied. I hadn't changed anything except software updates on both iPhone and NAS - so don't know what happened, why or how to fix it. When I'm on the MBP and go to readycloud.netgear.com, I can see the NAS, status, etc... but I can not see any folders, not even the root folders. I know it is accessing the NAS becuase while checking everything I perform a update on teh NAS from 6.6.0 to 6.6.1 and it shows I have 6.6.1 installed on readycloud.netgear.com. When I open the readycloud app on the MBP, it indicates the NAS is offline - but I know its on as I can go to finder and access everything. Im not a major network guy, so I'm at a loss here. Logging in to the admin page, I checked and I have permission on all folders, the readycloud setting is "on", again nothing has changed in my settings in over a year. Anything you can provide will be greatly appriciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also - When I try to remove a cloud user or invite a new cloud user from the admin page, it states that the device is connected to readycloud, visit readycloud to... When I go to readycloud.netgear.com, there is NO place to edit, add, remove, etc... cloud users.
I think maybe the issue is when Netgear merged accounts, because from the admin page, the cloud account is tied to the readyNAS remote account. So, I guess maybe I need to break this connection and create a new one??
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello 4xholic
It looks like your remote account has not been migrated to MyNETGEAR account correctly,can you check it again in ReadyCLOUD portal?
to check your ReadyCLOUD acccount binding information,please open ReadyCLOUD portal on your Browser and go to "Sign in"->"Upgrade to a MyNETGEAR Account"-> "Upgrade Your Existing ReadyCLOUD Account"->" (enter your old ReadyCLOUD account credential here)
- Mark as New
- Bookmark
- Subscribe
- Permalink
It states it has already been upgraded. I was reading another post and they mentioned logging in to teh admin account via web - how is this done? As far as I know I only have 1 account. The email address associated with the old account is now the address on the myNetgear account. When I log into readycloud via the web I use this email/pw. However, will this conflict if one of the users on the NAS has the same email?
==[more]===
Here are the account setups now:
myNetgear: email1@...
NAS: Admin: no email, access when connect to same network via IP address
Acc1: email1
Acc2: email2
Cloud: email1
Tried changing email on Acc1, still cannot access. However, now readycloud says unit is offline - not sure the email change had anything to do with it or not.
Regarding the readyNAS remote, should I delete this??
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello 4xholic,
ReadyNAS Remote is for legacy units such as ReadyNAS OS4 and OS5 units. You are using ReadyNAS 202 which is a ReadyNAS OS6. So, you would not be needing this ReadyNAS Remote.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello 4xholic,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
- Mark as New
- Bookmark
- Subscribe
- Permalink
T
rying to get his onto ReadyCloud. Pre-owned and registered. I find it a sad state of affairs that there is no way to update the registration of this Netgear product. It ends up a useless as a Drobo.
Pissed in Alabama,
Frank
ReadyNAS Ultra 6 [X-RAID2] | |
Serial: | 2EE40CRB002B9 |
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello webmesh,
If you have OS6 running on your ReadyNAS Ultra 6, you may use ReadyCloud. But if that is using the original OS4 that came with it then it should be ReadyNAS Remote.
Registering to Netgear support for warranty cannot be done when you have purchased a pre-owned unit unless it is not yet registered to Netgear support portal yet and you have the original proof of purchase, that may work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello JennC,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello 4xholic,
I am glad it works now with the help of Deniro. We appreciate your patience in solving this. To close the topic, please mark the most appropriate post that helped you solved the concern you have raised as the accepted solution or you may also mark your post that has the summary of what you did.
Please feel free to post any comments, questions and suggestins.
