Orbi WiFi 7 RBE973
Reply
Sharing with remote users - Readyshare Share Button Not Visible
mckaycomm
Follower
Hi. I'm using Windows 10 and the Nighthawk AC2300. I've updated the firmware on the Nighthawk so it is up-to-date. I've also set up Readyshare and everything seems in order except...
  • When I follow the FAQ for How do I use ReadyCLOUD to allow or remove share access for remote users? | Answer | NETGEAR Support, I've done everything as instructed up to the subhead "To invite a remote user:".
  • Step 3 says "Hover your mouse over the share you want to invite a user to." and Step 4 says "Click the blue icon with the + sign.".
  • As you can see from the following screengrab, I'm not seeing any "blue icon with the + sign". I've been working on this for a couple of hours and searched the forums/community and have come up empty. readycloud.JPG
Does anyone know where I'm going wrong?
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 4
Sandshark
Sensei
Re: Sharing with remote users - Readyshare Share Button Not Visible
This area is for ReadyCloud running on ReadyNAS devices, not routers.  You will probably have better luck getting answers in the proper forum area.
Message 2 of 4
theClaw56
Did anyone ever give a useful answer to this question?  I am experiencing the exact same behavior.  Is this something that doesn't work with the R7000?
Message 3 of 4
JohnCM_S
NETGEAR Employee Retired
Hi theClaw56,
Welcome to the Community!
The feature of inviting other ReadyCLOUD users to access the folder is only available on ReadyNAS devices. It is not available on the routers.
You can also share a folder by creating a web link. You can accomplish that by right-clicking a specific folder then select the 'Create Web Link'.
Message 4 of 4
Discussion stats
  • 3 replies
  • 1594 views
  • 0 kudos
  • 4 in conversation
Announcements
