- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
readynas error code 6001010106 since firmware 6.5.2
- Mark as New
- Bookmark
- Subscribe
- Permalink
The ReadyNAS is finally on-line after updating to firmware 6.5.2 but I now no longer can logon to the admin page and readynas error code 6001010106 is displayed in a dialogue box. Password reset is not enabled. Has the password been reset to a default value?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
The ReadyCLOUD admin was missing from the group it needed to be in. So adding it to that group from the backend resolved the issue.
Useful links: Sending Logs|My ReadyNAS Gear|FAQ|Hardware Compatibility List|Docs: Setup Guide, Manual|Downloads|Unofficial Tips|GPL|MDGM on Twitter|MDGM's Unofficial Guides
NB: A ReadyNas is not an excuse not to have a backup. Fire, theft, multiple disk failures, other hardware failure, floods, user negligence etc. can all result in loss of data.
How to contact NETGEAR Technical Support | Australia: 1300 361 254 / Other Numbers|Online Submission
Unofficial Guide for Moving from Sparc ReadyNAS to x86 ReadyNAS|Using Gmail with the ReadyNAS|XRAID Volume Size Calculator
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: readynas error code 6001010106 since firmware 6.5.2
Also now displays notification stating that I have to be on the same network as the ReadyNAS to access the admin page. I'm on the same network and initially I would be prompted with the logon dialogue box but now I just get the warning about having to be on the same network and no logon prompt.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just found out that the system was rebooted with the default username and password for access to the admin page.
Username : admin
PW : password
- Mark as New
- Bookmark
- Subscribe
- Permalink
So is it working now?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Appears to be finallyworking but I haven't given it a thorough testing. I logged out and logged back in using ReadyCloud and the 6001010106 error code still comes up. What does this code mean?
I also wanted to set up the password recovery option but that isn't straight forward. 😞
- Mark as New
- Bookmark
- Subscribe
- Permalink
It seems you've run into an issue that can be encountered when the system was initially setup on very old firmware. I've sent you a PM.
- Mark as New
- Bookmark
- Subscribe
- Permalink
