Reply
4TB compatibility
Another question about hard drives!
The official HCL lists Hitachi 3TB and 4TB Ultrastar as compatible with the new (and indeed old) readynas devices - ie the 102/4 etc.
Does that mean that the 3TB and 4TB Deskstar drives by Hitachi are likely to function OK as well?
I am reluctant to use Barracudas in part due to their poor rep in larger sizes but also their limited 1 year warranty. I plan to run the new 104 with 2 drives initially, either 3 or 4TB each and expand the array to the full 4 discs using the same one initially selected.
Any tips?
NETGEAR Moderator
Re: 4TB compatibility
It's possible that other drives may work. However so note that NetGear can and will deny support if you use drives that are outside the compatibility list.
Is there any reason why drives are on the HCL for the Ultra 6 but not for the newer models?
Guru
If there is, Netgear hasn't said so.
Unfortunately, they don't publish a list of drives that they tested and are known not to work.
Discussion Stats
  • 3 replies
  • 974 views
  • 0 kudos
  • 3 in conversation
Top Contributors
