Reply
Corsair VS1GSDS333 1GB
I'm using this in my NV+ and it works fine. Completed a few memtests.
Re: Corsair VS1GSDS333 1GB
I'm also using it without any problems, in a Duo.
Confirmed with 2 memory test on my DUO
bhf Aspirant
Upgraded my NV+ and ran 4 memory tests, OK.
Original: NV+ RND4250 (Jun 2009)
RAIDiator: 4.1.5, 256GB RAM,
2X ST31000322CS
Upgrade:
RAIDiator: 4.1.6
2X ST31000322CS (Feb 2010)
1GB RAM (Corsair VS1GSDS333) (Jul 2011)
NETGEAR Moderator
You need to update your sig (original section). 256GB RAM? I think you meant 256MB RAM
I just put this in my DUO and ran 2 memory test. Everything is A.O.K!
Decided to snag one of these from Amazon. Can anyone tell a noob how to do the memory test?
My module came in from Amazon, went right in and works perfectly.
Finally got around to slapping it into the Duo today. Seems to be working fine. I still haven't found out how to do the memory test. Can anyone help me out?
Tutor
faq.php#Is_there_a_way_I_can_verify_if_my_memory_is_good%3F
I replaced the 256MB SODIMM for a Corsair VS1GSDS333 1GB without problems.
However, the anticipated performance boost in Frontview and NFS transfers is barely noticeable. Smiley Sad
NETGEAR Moderator
Can I use faster memory in my NV+?
The listing indicated 3200 is possible.
http://www.readynas.com/forum/faq.php#Where_can_I_find_the_ReadyNAS_memory_specification%3F
I got a block of this RAM (Corsair VS1GSDS333) so I tried to put it in my readynas NV+ after reading this, but when I try to boot, the nas just hang and the blue power light blink. I try leaving it for about 20 min. but it still just hang. Any one that can tell me why it want boot?
Tutor
Try removing & re-seating it. If it fails to boot, try re-installing the original RAM. If it boots, it's likely that the RAM is incompatible. It's been posted a few times in the forums that some RAM vendors change the memory specs but keep the same part number.
Thx for fast reply Smiley Happy well i re-installed it and try boot it up again a few times. but no luck. put in the original ram and it boot just fine. well i most go buy a new ram-block Smiley Happy
After a Patriot Signature 1 GB SODIMM PSD1G33316S failed to boot my NV+, I went with the Corsair. It works fine - no problems.
3 Corsair 1 GB modules were tried in one NV and two NV+. One module immediately failed in both the NV and in the NV+ while it worked in a 1.3 GHz Powerbook, so the memory itself was not faulty. The other two modules worked in the NV and in one NV+. The other NV+ was only satisfied with Kingston 1024 MB [2.5-3-3-7] memory, also from the hardware compatibility list.
DOA Aspirant
I just tried a Corsair VS1GSDS33 in my NV+. Two passes of memory test, but no boot.
Original 256 MB is back in and running fine. Hopefully I can try another manufacturer.
How long should the NV+ take to boot? We could sure use a sticky with approximate wait times.
We have the information, just not in readily addressable format. I realize that different drive sizes and speed will change that end of things so specific drives will have to be listed, but a RAM change out should be fairly consistent after a couple of passed RAM tests.
Ultra 4, Ultra 6
Movies, must have more movies!
DOA Aspirant
Update:
Tried Patriot PSD1G33316S but the description at Fry's said "Hybrid" would not pass ram test
Tried Kingston, would not pass ram test
Another stick of Corsair - passed test like first one but I did NOT shut off the NV+. Instead I hit the power button quickly and it went into a 10 minute successful boot. 3 more power off boots went fine, down to about 5 mins to boot and it is more responsive.
My two cents - keep trying different Corsair sticks.
Ultra 4, Ultra 6
I just finished memory tests on a brand new VS1GSDS400. No joy.
Tests passed but not boot.
Nas: NV+
Just wanted to report that I successfully upgraded my NV+ to 1GB RAM with a Corsair VS1GSDS333 stick.
Two memory tests passed and it boots fine.
I was surprised to find that the preinstalled RAM was DDR 400. I was considering exchanging the DDR 333 memory that I bought for a DDR 400 stick. I'm glad I found this thread.
Sorry to hear about your trouble with DDR 400 memory erupter, but you saved me some hassle. Thanks for that!
Discussion Stats
Top Contributors
