Reply
Follower
SO-DIMM 1GB DDR PC2700 333MHZ CRUCIAL
Hello
Installed this today SO-DIMM 1GB DDR PC2700 333MHZ CRUCIAL FOR READYNAS DUO NV+ and its running fine in my Readynas Duo RND200.
Re: SO-DIMM 1GB DDR PC2700 333MHZ CRUCIAL
Spooky , did exactly the same thing today in my DUO too, and so far so good
(is it me, but I could of sworn there used to be a list on the comparability section for memory, which is where I found this model/spec of RAM a few months ago, but seems Netgear have stepped back from assisting with memory upgrades and want to leave it to us)
CRUCIAL 1GB RAM 200PIN DDR SODIMM 128MX64.
I tried to install a "SO-DIMM 1GB DDR PC2700 333MHZ CRUCIAL" CT12864X335 yesturday, but my DUO wont boot up. It just keeps flashing the blue powerled.
Hi neo25, I've the same problem with my NV+. Installed a new RAM, but it didn't work. Switched back and installed the old modul but it just keeps flashing the blue power LED and nothing else. Did you solve your problem in the meantime? Any solution for this?
same issue as neo.. id even got memory switch at the store, but, still the same, blue led keep flash and not found by raidAR Smiley Sad
Gentlemen, this is exactly while there is no longer an HCL list for memory, and memory upgrades are not recommended. I did try a memory upgrade on my NV+ years ago, using a 1GB memory module (circa 2006) out of an old HP laptop. It worked fine, and never had a problem, but there was no appreciable increase in file transfer rates. A few months later when I needed the laptop back, I swapped the memory back and my NV+ now still has the original memory in it.
Memory manufacturers caused this issue when they changed the physical number of chips on the module and the chips themselves at time which upset the timing. They did not change the model numbers, so the 2006 module that worked and the 2011 module that doesn't have the same model numbers. If you have swapped back to the original memory and the NAS still won't boot, and you don't have current and complete backup, your only recourse is to contact Tech Support via an on line ticket (unless you have had the unit less than 90 days and qualify for free telephone support). If you have a current and complete backup, you can try a factory default (which will wipe the data and set up the unit as if it were new).
Remember - the NAS is not a backup plan.
Backup = Good, No Backup = Bad
Hi I had the same problem on my Duo v1. RAM ordered direct from Crucial:
CT12864X335.K16FY
(1GB 200-PIN SODIMM 128Mx64 DDR PC2700 Pb-Free)
Duo wouldn't boot up. Can someone recommend another RAM module that is known to work?
Thanks.
I recommend that you reread all the discussions and the comments that point out that NETGEAR DOES NOT SUPPORT AFTERMARKET MEMORY UPGRADES. Unless you are running a lot of add on applications, a memory increase is unlikely to make a noticeable improvement in the performance of either the NV+ or Duo models.
PB I have read here that Rsync backups (alone) benefit significantly from increased RAM. Do you disagree?
ReadyNAS NV+ V1 RND4410 [X-RAID], RAIDiator 4.1.9 [1.00a043]
Four Seagate 7200.12 ST31000528AS 1TB drives Firmware: CC49 updated from CC38 (Netgear RND4410 original)
NETGEAR Moderator
While things like that can benefit from a RAM upgrade, it's unsupported. Memory manufacturers update memory modules rendering them incompatible but keeping the same module number. It's not worth upgrading the RAM imo.
I understand what "unsupported" means! That was not my interest re: Rsync.
Well, it is hard to say if the CPU is the bottleneck in Sparc based units or the memory. I have an NV+ on which I run several rsync backups pulling from an NVX. On average a share that backs up from NAS1 to NAS2 (both NVX units) that takes 30 seconds will take about 60 seconds going from NAS2 to NAS3 (my NV+). I have never been overly concerned on the time any of my rsync backups take since they generally happen I am asleep or in the background. NAS1 is my primary unit, and the NAS1 to NAS2 backups occur starting at 12:05AM. The NAS2 to NAS3 (again the NV+) start at 12:05PM, but since I am not normally using files on those machines, it doesn't affect me. The longest I ever remember a share taking to back up via rsync was about 15 minutes, but I had added about 50GB of video files to the share.
In any regards, I don't think it would be a significant difference with the increased memory, or Netgear would have done it long ago after the price of memory dropped. The one time I did have 1GB of ram in my NV+, I could not notice any file transfer difference. But that was in copy/paste to a PC, not NFS or rsync. I am extremely committed between now and next week, so I will try to time some controlled experiments next week to see what the impact actually is.
OK. Well, thanks PB. I can't put my finger on the posts I read where folks said it made a significant difference--maybe indeed it was speculation on their part and not tested/proven, or was based on an assumption involving Rsync and its memory requirements.
I was merely challenging your statement that a memory upgrade was only needed if lotsa apps were being run--didn't mean to make any further work for you! Smiley Wink
Well, it is probably something that needs to be documented one way or another. It will just have to wait for now. The no significant improvement was also my impression from the performance, not actual timing of file transfers.
Has anybody used the recent batch of CT12864X335 from Crucial?
I understand this but I am trying to use the DLNA and iTunes service the performance is terrible. The iTunes service won't even start correctly most of the time and I cannot access it's web interface. I fully understand the unsupported statement, however I'm just asking the community if they know of any current RAM modules that work - the risk from that point forward is my own Smiley Very Happy
NETGEAR Moderator
drazic19 what version of RAIDiator are you running? There are performance issues with 4.1.8. If running that you may find updating to 4.1.9 beta (http://www.readynas.com/forum/viewtopic.php?f=17&t=59222) resolves your problem.
Discussion Stats
  • 17 replies
  • 1753 views
  • 0 kudos
  • 10 in conversation
Top Contributors
