Reply
will 4TB drives be compatible with readynas nvx and if so wh
I am maxed out with 4 3TB drives and would like to know if 4TB drives will be compatible and if so when?
This way I can compensate until larger drives are or are not accepted.
Virtuoso
Re: will 4TB drives be compatible with readynas nvx and if s
viewtopic.php?f=83&t=58447
I'm not sure there are any other limitations specific to nvx (because its 32bit), but 4tb definately work on ultra4/probis.
ReadyNAS 528X, Pro 6, ProBusiness, Ultra 4, NV+
thx teknojnky Smiley Happy it looks like 4tb is not supported with the nvx but hopefully that will change with the next fw upgrade.
Virtuoso
Why do you say that?
i did not see a 4tb drives listed on the compatibility list
http://www.readynas.com/?page_id=82
Guide
Perhaps you should investigate just how many bare 4TB drives are actually available right now...
NAS: Ultra-4, NV+ & Duo v2 :: ST31500341AS & HDS723020BLA642 Drives
Network: Netgear GS108Tv2 / DM111P :: Airport Extreme / Express & Time Capsule
Clients: OS X 10.6 - 10.8 :: Ubuntu 11.x :: Win 7 + SP#1
UPS: APC ES-550
Virtuoso
zero, the only 4tb single drive is linked above
i understand that. my question was regarding information on a future hardware/software release not what is available today.
Guide
Drives are added to the compatibility list when tested. Drives are tested once available... You are not going to get any guarantees before testing is done, but there is currently no reason or any form of indication that 4TB or even larger drives cannot be supported
UPS: APC ES-550
NETGEAR Moderator
First NetGear has to wait for a bare 4TB drive to be released.
Then it has to purchase a large quantity of the drives (need to allow for disk failures) to test in multiple units (may not be easy particularly as drive availability becomes very constrained due to the ongoing effects from the Thailand floods)
Testing will likely begin with the newer ReadyNAS models (as NetGear may wish to move to selling some models semi-populated or fully-populated with 4TB disks) and then later move onto the NVX.
If NetGear encounters problems it will then need to work on a fix and redo its testing (possibly requiring purchase of more drives). It's an expensive process and can take a while, but they understand the importance of doing their testing thoroughly.
I can't see any reason why 4TB drives wouldn't work either, but NetGear will want to make sure they work fine before adding them to the compatibility list.
If and when they are released and you feel the urge to experiment on the bleeding edge of the new technology, I would recommend that you choose a model that is an expansion of an existing 3TB drive that is compatible. That will give you a better chance of success. But do keep in mind that with unsupported drives, tech support will not assist. Keep a good backup and it is never advised to use experimental drives or beta firmware on an NAS in operational use.
Remember - the NAS is not a backup plan.
Backup = Good, No Backup = Bad
Discussion Stats
  • 10 replies
  • 1212 views
  • 0 kudos
  • 5 in conversation
Top Contributors
