× NETGEAR will be terminating ReadyCLOUD service by April 1st, 2023. For more details click here.
Reply
Change target disc when using Readycloud
JoGo
HI!
Any updates regarding the errand below? Is it now possible to change disc?
BR / Joergen
Change target folder or disc when using ready loud
How do I change disc Folder for ready loud target? It just creates a folder in one of the discs installed in my NAS.
Br/Jorg
Model: RN10200|ReadyNAS 100 Series 2- Bay (Diskless)
Message 1 of 3
ACCEPTED SOLUTIONS
NETGEAR Moderator
Re: Change target folder or disc when using ready loud
@JoGo
Welcome to the Community!
What would you like to change? Is it the volume on your NAS? right now there's no way you can change the default volume the NAS will be using when creating a share for syncing a Windows PC or MAC OS folder to the NAS. It automatically creates a share on the first volume when a folder is synced through ReadyCloud app.
You may want to post your Idea on the Ideas Exchange board for ReadyNAS. Getting enough Kudos can help engineers to add it as a feature/function.
If this is not the case, kindly send a screenshot of what you are trying to do so we can better assist you.
HTH
Regards
Marc_V
NETGEAR Community Team
It's what you do that defines you
NETGEAR Community User Guidelines
Message 2 of 3
Message 1 of 2
Marc_V
NETGEAR Employee Retired
Re: Change target disc when using Readycloud
@JoGo
I don't think this is already implemented. You may want to check the request on the Ideas Exchanged board
https://community.netgear.com/t5/ReadyNAS-Idea-Exchange/windows-readycloud-app-select-destination-fo...
Marc_V
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 599 views
  • 0 kudos
  • 2 in conversation
Announcements
