× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Deleting snapshots that are not showing
Darkyputz
Hello Community...
I was a silent reader so far and learned and got a lot out of here so far.
But now i have a problem that i cannot resolve with the answers i found so far.
About my issue:
I have this Pro 6 with 6 1TB drives in X-Raid (Raid 6)
I also updated it to OS6 and i am on the latest beta1 right now...(not sure why they dont offer official upgrade to it, so much better and everything is functional)
I dont have any snapshots enabled nor does the webpage show any snapshots in the shares view, but my Volume view says i am using 600+ gig od snapshots and my available space is also lowered by that amount
Now i was cruising up and down the solutions about this issue and even tried the command below, but nothing helped.
Is there a command or such that shows me where these snapshots live, so that i can get rid of them?
Unfortunate i have to much data on the NAS to store anywere else in interim to just wipe the whole thing as mentioned in one of the solutions
Any ideas?
Thx,...and i send logs when needed...just let me know what you need
# touch /.force_snapshots_upgrade
# systemctl restart readynasd
Model: RNDP6350|ReadyNAS Pro 6 1.5TB (3 x 500GB Enterprise)
Message 1 of 7
Guru
Re: Deleting snapshots that are not showing
When did you convert to OS-6?  Do you recall what firmware was running back then?
Have you ever tried doing a balance?
Message 2 of 7
Darkyputz
Hello...
Thx for answering...
The firmware was the latest 4.2.31 one.
I did balance and scrubbing and the command i was reporting earlier...
Tried to navigate through the nas with winscp to find hidden /.snapshot folders in my shares but so far no luck
is there a linux command for searching those snapsot folders?
Message 3 of 7
Guru
Sorry - I meant the first OS 6 firmware version you installed.
Yes.
# btrfs subvolume list -s /data
will show you all the snapshots in the data volume.  If you are using FlexRaid, you'll need to replace /data with the volume name(s) you configured when you created the volume(s).
Message 4 of 7
Darkyputz
Hello...and thx for the quick reply again...
I did the command you posted and it showed a good amunt of snapshot folders that i am not able to see in winscp
Prob my lack of BTRFS knowledge pays into that
How could i easiest get rid of them now?
is there a proven wildcard rm command or do i have to delete one by one?
Please advise
Message 5 of 7
Guru
You can't use rm at all.  These are BTRFS subvolumes, and not ordinary folders.  rm will simply fail.
You can remove them one at a time with
# btrfs subvolume delete -c /path
using the full pathname of each subvolume in the list instead of /path.  The -c option stands for "commit-after".  The command won't return until the subvolume is fully removed.  It will go faster if you leave out the -c, but I suggest using it anyway.
Make sure you are logging in as root (NOT admin).  Use the admin password though.
You could probably sort out a way to script this, but I won't attempt to do that here.
Message 6 of 7
Darkyputz
You are my hero...
I was able to test that and it works...freed up some space already...
Will go through the list and see that i get it all out...
Will post if i run into issues
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1501 views
  • 0 kudos
  • 2 in conversation
Announcements
