- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
How to disable readycloud
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have accidentally turned on ReadyCloud sync with my office PC and that effectively chewed up all my Office PC SSD storage. How do I pause or stop the sync so I can clear HDD space on my office PC? I fear by deleting files now in the Office PC I will also delete the actual files in my NAS, which is what I do not want.
Thanks for helping.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Welcome to the Community!
Make sure that you have backup first of what you intend to delete then turn off ReadyCloud on your NAS. It is under the Cloud tab of the Web GUI, you just need to toggle the On/Off Slider.
If you don't want to stop the service of your ReadyCloud then just click on the Folder that is syncing on the ReadyCloud client app and stop/pause the sync. Alternatively, uninstalling the app should do the job as well,.
HTH
Regards
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
HTH
Regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
