× The readycloud.netgear.com login issue with the Chrome browser is now fixed. We are actively working on resolving a similar issue with the Safari browser and recommend you use an alternate browser until this error has been resolved.
Reply
More on CPU specs of the ReadyNAS Pro
Hibtek
Re: More on CPU specs of the ReadyNAS Pro
:-) I ran the cat /dev/urandom > /dev/null and it only did one processor, never though its as simple as just opening two sessions :-)
Ran it on both, and temp climbed up to 34c, left it for 5 mins and it reached 36c, stopped them and it dropped by 10c by the time I refreshed frontview :-)
Fan did not appear to change from 928 rpm though, but I guess its not getting hot enough to speed it up?
Thanks
ReadyNAS Ultra 6 Plus :: 6x Seagate/WD Drives (7.4TB) in X-RAID2 :: 4096 MB :: JFSmiley SurprisedFF :: CPU:E5300 :: 4.2.27
ReadyNAS Pro :: Seagate and WD Drives :: 4096 MB :: JFSmiley SurprisedFF :: CPU:E5300 :: 4.2.26
ReadyNAS Pro :: 5x Seagate Drives 4TB (14.54 TB) in X-RAID2 :: 1024 MB :: JFSmiley SurprisedFF :: CPU:5300 :: OS6.5.0-T388
ReadyNAS Ultra 4 Plus :: 4x1TB Hitachi : 6.4.2
Router :: Virgin Super Hub
Switch :: Netgear GS724
Desktop :: Core i7 4820k @3.70Ghz : 32GB Ram : HDD 256GB San Disk SSD : NIC Intel(R) 82579V Gigabit : Windows 10 Enterprise 64bit :
UPS :: APC Smart-UPS 1500
Retired:
ReadyNAS NV+
ReadyNAS Duo v1
ReadyNAS Ultra 2
ReadyNAS NV+ V2
Message 226 of 285
Campus
Apprentice
Let it run for at least 30 minutes to get enough heat into the case to really stress test everything. Both fans should run at max speed then.
Message 227 of 285
Hibtek
Well, after about 30 mins, no fan change and the processor is 36.5!, is there anyway the NAS could read the processor wrong?, a bit late to mention, but I am running RAIDiator 4.2.25
Device Description Status
Disk 1 Seagate ST31000528AS 931 GB , 36 C / 96 F , Write-cache ON OK
Disk 2 SAMSUNG HD103UJ 931 GB , 34 C / 93 F , Write-cache ON OK
Fan SYS 902 RPM OK
Fan CPU 2109 RPM OK
Temp SYS 58 C / 136 F [Normal 0-65 C / 32-149 F] OK
Temp CPU 36.5 C / 97 F [Normal 0-60 C / 32-140 F] OK
UPS 1 Not present NA
Top
top - 23:18:00 up 22:54, 3 users, load average: 2.09, 2.05, 1.83
Tasks: 88 total, 3 running, 85 sleeping, 0 stopped, 0 zombie
Cpu(s): 0.0%us,100.0%sy, 0.0%ni, 0.0%id, 0.0%wa, 0.0%hi, 0.0%si, 0.0%st
Mem: 2053780k total, 1916756k used, 137024k free, 28432k buffers
Swap: 524272k total, 0k used, 524272k free, 1664440k cached
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
1546 root 20 0 3760 496 412 R 100 0.0 30:33.90 cat
1547 root 20 0 3760 496 412 R 100 0.0 30:30.10 cat
29875 root 20 0 2328 1020 788 R 0 0.0 0:02.98 top
I will reapply the firmware and see how it goes
Retired:
ReadyNAS NV+
ReadyNAS Duo v1
ReadyNAS Ultra 2
ReadyNAS NV+ V2
Message 228 of 285
Campus
Apprentice
Here are my numbers:
Idle:
Fan SYS 942 RPM OK
Fan CPU 1622 RPM OK
Temp SYS 56 C [Normal 0-65 C / 32-149 F] OK
Temp CPU 24 C [Normal 0-60 C / 32-140 F] OK
With stress load:
Fan SYS 998 RPM OK
Fan CPU 2960 RPM OK
Temp SYS 59 C [Normal 0-65 C / 32-149 F] OK
Temp CPU 48 C [Normal 0-60 C / 32-140 F] OK
Message 229 of 285
Hibtek
Thanks for the reply, it makes me feel better that its similar to others, I have not seen a processor at 16c for a long time! :-)
I did the old finger test as well, when I first saw it so low, and the heat sink was cold or cool to the touch.
Retired:
ReadyNAS NV+
ReadyNAS Duo v1
ReadyNAS Ultra 2
ReadyNAS NV+ V2
Message 230 of 285
dhl
Luminary
Luminary
Hi All,
Been reading this thread with great interest. I have two ReadyNAS Pro Pioneer systems that were purchased in 2010. We're about to do a complete disk swap with new 4TB drives to get higher capacity and dual redundancy. I'm thinking this might be a great time to breath new life into the systems with a CPU swap as well. Prices on eBay are dirt cheap and since these machines are at the end of their warranty life, I'm temped to go for it!
A few questions:
Seems like motherboard version makes a big difference in what CPUs will work. Is there an easy way to find out what my motherboard rev# is without opening the case?
For a 2010 Pro, is there any consensus on what processor will work best? I have one main goal - maximum speed without increasing temperatures while keeping all stock cooling (fans and heatsinks). My current system typically reports:
Fan SYS 897 RPM
Fan CPU 1917 RPM
Temp SYS 56 C / 132 F [Normal 0-65 C / 32-149 F]
Temp CPU 37.5 C / 99 F [Normal 0-85 C / 32-185 F]
I'd like it to stay at this level or cooler after the upgrade.
The E6400, E6600 or E6700 seem solid. Or maybe the E7400 or e7600? Or…?
Our systems have 4GB RAM (HCL compatible) and are running the latest BIOS (07/26/2010 FLAME6-MB V2.0)
Any advice/recommendations/gotchas?
Thanks!
Message 231 of 285
fastfwd
Virtuoso
E6600 will give you that, especially if you get the right S-Spec number (SL9ZL, not SL9S8).
2 × Pro 6 [Main & Backup] – XRAID2 Dual-Redundant (RAID6): 14.53TB (110MB/s Write, 123MB/s Read)
  • CPU: 2.4GHz E6600 SL9ZL - RAM: 8GB (PSD28G800K) - BIOS: 07/26/2010 - OS: 6.10.3 w/ custom kernel - Drives: 6 × ST4000VN000 / ST4000VN008
    Fans: Noctua NF-S12A FLX (Case), NF-R8 PWM (CPU), NF-R8 w/LNA (Power Supply) - USB: STGY8000400 - UPS: APC BR1000G
Ultra 2 Plus [for experimentation and testing] – JBOD: 8TB (110MB/s Write, 123MB/s Read)
  • CPU: Standard 1.8GHz Atom D525 - RAM: 2GB (CT25664BC1067) - BIOS: 11/02/2011 - OS: 4.2.31 - Drives: 2 × ST4000VN000 - Fan: Noctua NF-B9 - USB: ST31000340
Message 232 of 285
dhl
Luminary
Luminary
Great, I'm seeing a bunch of them on eBay, many >$20 Smiley Very Happy
So is this essentially a plug and play operation - i.e. no firmware hacks or cooling mods needed, just swap and go?
Message 233 of 285
dsm1212
Apprentice
Have some fresh thermal paste on hand and while you are in there blow out the fan thoroughly. I actually saw my temps drop a bit but I think it was because of the cleaning :-). I'm using an e7600 I bought on ebay. That processor was frequently removed from a mac and updated so there are quite a few used around.
steve
Message 234 of 285
dhl
Luminary
Luminary
@dsm1212
Yes, will do on the thermal paste. Really great that you're seeing *cooler* temps! Do you know the S-Spec number number for your e7600? Really great that you're seeing *cooler* temps!
Message 235 of 285
dsm1212
Apprentice
SLGTD was the E7600 spec variant. My results are on page 10 of this topic. Wasn't hugely cooler, about 3 degrees.
Message 236 of 285
spiderman1
Tutor
Hi guys,
I would like to do a cpu mod on my Readynas Pro Business Edition (BIOS 07/26/2010 FLAME6-MB V2.0). Sticker on mobo is FA5.
Has anyone tried a q6600 and e7600? Which one should I opt for? I would like to do video transcoding using Plex or AirVideo preferably.
Thanks.
NAS Product 1: ReadyNAS Pro 6 8192 MB [6-6-6-18 DDR2]
RAIDiator Version: RAIDiator-x86 Version: 6.2.4
RAID Configuration: RAID Level X-RAID (Single Redundancy)
Hard Disk Brand, Model, Capacity & Number: Seagate ST31000524NS 1TB x 6
ReadyNAS Security Mode: User
NAS Product 2: ReadyNAS Pro 3968 MB [4-5-5-15 DDR2]
RAID Configuration: RAID Level X-RAID2 (Single Redundant)
Hard Disk Brand, Model, Capacity & Number: Seagate ST31000528AS 1TB x 6
Network Router/Switch/UPS: Nighthawk R7000, Netgear GS108T, APC Back-UPS RS 1200 LCD
Computers: Sony VAIO VPCF11C53-FZ21Z/Core i7 Q720 1.6 GHZ/8 gb ram/500gb Seagate/Windows 7 Ultimate
Shuttle XPC SX58J3/Core i7 980x Extreme Edition 3.33 GHZ /16 gb ram/256gb SSD OCZ/Windows 7
Macbook Pro 15" Retina/Core i7 4850-HQ 2.3 GHz/16gb ram/512gb SSD PCIe/OSX Mavericks
"I don't suppose I could convince you to come up here and fight like a spider?" - Spider Man
Message 237 of 285
sander11
I just took the plunge and upgraded (again!) to a q6600 from an original upgrade to an e7400. After upgrading the enclosure.db it appears to be working normally, albeit a little hotter and noisier than it did before.
I'm still digging around to see if this is something where I messed up somewhere or this is the new normal. I was initially very reticent about the procedure, but modern cpu switching is pretty painless. From my experience the e series upgrade is generally a drop in which will run cooler, whereas the q chip requires editing some configuration files and, so far, does run hotter.
Message 238 of 285
spiderman1
Tutor
How is the overall performance of the q6600 in terms of file copying and transcoding of 1080p movies?
Thanks
Message 239 of 285
spiderman1
Tutor
I have now upgraded my Readynas Pro with a Q6600 and it screams. I can transcode blu-ray at 5120 kbits/s using the Air Video without any jittering or interruptions whatsoever.
Here are how my temp and fan readings while idle:
Fan SYS 856 RPM OK
Fan CPU 1854 RPM OK
Temp SYS 54 C / 129 F [Normal 0-65 C / 32-149 F] OK
Temp CPU 27 C / 80 F [Normal 0-85 C / 32-185 F] OK
Here are how my temp and fan readings while transcoding one stream at 5120:
Fan SYS 922 RPM OK
Fan CPU 3182 RPM OK
Temp CPU 45 C / 113 F [Normal 0-85 C / 32-185 F] OK
hdparm -t -T /dev/c/c
/dev/c/c:
Timing cached reads: 8410 MB in 2.00 seconds = 4211.72 MB/sec
Timing buffered disk reads: 1208 MB in 3.00 seconds = 402.16 MB/sec
HTOP
1 [||||||||||||||||############################96.7%] Tasks: 64, 56 thr; 6 running
2 [||||||||||||||||||||||||||##################91.4%] Load average: 3.36 1.19 0.89
3 [||||||||||||||##############################94.0%] Uptime: 03:24:04
4 [||||||||||||||||||||||||####################96.7%]
Mem[|||||||||||||||#**********************1164/3956MB]
Swp[ 0/2047MB]
I hope this helps any of you who are toying with the idea of upgrading your Readynas Pro to a Q6600. For $70 from ebay, it's sweet indeed!
Message 240 of 285
dhl
Luminary
Luminary
Well that was easy! Smiley Very Happy
Dropped in a E6700 SL9ZF purchased on eBay for $23. Took about 2 minutes (I spent more time cleaning the enclosure).
BEFORE CPU:
ReadyNAS_Pro:/# cat /proc/cpuinfo
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 15
model name : Intel(R) Pentium(R) Dual CPU E2160 @ 1.80GHz
stepping : 13
cpu MHz : 1795.269
cache size : 1024 KB
AFTER CPU:
processor : 0
cpu family : 6
model : 15
model name : Intel(R) Core(TM)2 CPU 6700 @ 2.66GHz
stepping : 6
cpu MHz : 2660.311
cache size : 4096 KB
BEFORE - timed reads (best of 10)
ReadyNAS_Pro:/# hdparm -t -T /dev/c/c
/dev/c/c:
Timing cached reads: 2520 MB in 2.00 seconds = 1260.87 MB/sec
Timing buffered disk reads: 396 MB in 3.00 seconds = 131.91 MB/sec
AFTER - timed reads (best of 10)
/dev/c/c:
Timing cached reads: 9502 MB in 2.00 seconds = 4759.45 MB/sec
Timing buffered disk reads: 436 MB in 3.03 seconds = 143.73 MB/sec
BEFORE - temperatures and fans
Fan SYS	897 RPM		OK
Fan CPU 1971 RPM OK
Temp SYS 56 C / 132 F [Normal 0-65 C / 32-149 F] OK
Temp CPU 38.5 C / 101 F [Normal 0-85 C / 32-185 F] OK
AFTER - temperatures and fans
Fan SYS	932 RPM		OK
Fan CPU 2083 RPM OK
Maybe it's my imagination but Frontview seems much snappier. So does connecting and viewing files in the Finder.
Great upgrade - totally worth it and recommended! Thanks everyone, for your help! :woot:
Message 241 of 285
dsm1212
Apprentice
Good results. I've never gotten to the bottom of why my e7600 system does so poorly at the hdparm test. I'm getting:
/dev/c/c:
Timing cached reads: 3692 MB in 2.00 seconds = 1846.18 MB/sec
Timing buffered disk reads: ^[[A776 MB in 3.01 seconds = 258.22 MB/sec
warehouse6:/c/home/admin# hdparm -t -T /dev/c/c
I'm definitely using inexpensive 4TB drives (unsupported) but it seems like these results are off by 2-3x. Not that I'm complaining. I've got the box doing a lot of stuff and having no issues. Just seems like something is wrong. No uncorrectable reads on any drives or errors in /var/log. System looks mostly idle when I ran the above command several times. It makes me wonder if have a performance setting I should change. I think I have them all enabled in frontview (I've got a ups). Any suggestions?
steve
Message 242 of 285
Xaver
Well,
I have a E7600 now with this stats:
processor       : 0
cpu family : 6
model : 23
model name : Intel(R) Core(TM)2 Duo CPU E7600 @ 3.06GHz
stepping : 10
cpu MHz : 3059.458
cache size : 3072 KB
and
/dev/c/c:
Timing cached reads: 3824 MB in 2.00 seconds = 1912.23 MB/sec
Timing buffered disk reads: 1330 MB in 3.00 seconds = 442.90 MB/sec
I can't complain but if you find some tweaks please let me know.
Message 243 of 285
fastfwd
Virtuoso
Yeah, the variation from machine to machine is pretty odd; dsm1212 and I discussed that briefly on pages 10 and 11 of this thread.
My CPU is still a 2.4GHz E6600:
NAS1:~# cat /proc/cpuinfo
processor : 0
cpu family : 6
model : 15
model name : Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz
stepping : 6
cpu MHz : 1596.000
And my current speeds (best cached of 10 and best direct of 10 shown below) are still higher than those reported for Pros with 3GHz E7600 CPUs:
NAS1:~# hdparm -t -T /dev/c/c
/dev/c/c:
Timing cached reads: 8154 MB in 2.00 seconds = 4086.48 MB/sec
Timing buffered disk reads: 1500 MB in 3.00 seconds = 499.84 MB/sec
/dev/c/c:
Timing cached reads: 7380 MB in 2.00 seconds = 3697.88 MB/sec
Timing buffered disk reads: 1606 MB in 3.00 seconds = 535.15 MB/sec
Message 244 of 285
dsm1212
Apprentice
Feel like I've done this before...
It's tempting to think it must be something with the drives, but the first result from hdparm is just reading from disk cache in memory. That leads me to think my memory might be running slow and then when I tried to investigate that I couldn't find any way to get the machine to tell me the speed the memory was running at. I still think it could be an issue with memory speed. It's the 8GB Patriot DIMM that a number of others here bought, but I'm suspicious.
steve
Message 245 of 285
dsm1212
Apprentice
There are some differences in our disk configuration so it's the first numbers for "Timing cached reads" that I'm more interested in. I downloaded some software called ramspeed and it shows my system getting about the same 4GB/s that fastfwd gets from hdparm. Near as I can tell that seems to be the right number for 800MHz DDR2. So whatever is going on in my system it seems to be specific to running hdparm.
Message 246 of 285
hoogends1
Just wanted to add that i upgraded my RNDP600E (ReadyNAS Pro Pioneer) with an E7600 CPU.
Thanks to this thread all went well !!
Smiley Happy
Message 247 of 285
menkelis
Tutor
I just installed a E7600 in my Ready-NAS PRO.
Simple, fast, and the best $20.00 upgrade.
Message 248 of 285
sander11
I haven't been keeping up on the OS 6 thread to see if anyone has upgraded to OS6 after replacing the cpu and if the unsupported OS6 is as hackable as the older OSes. I wouldn't mind being on a newer kernel where I could use KVM.
Of course the other deal breaker is the factory reset, but that sounds unavoidable.
OS6 with replaced cpus and maybe fans, would be the ultimate frankenas!
Message 249 of 285
Sandshark
Sensei
Some certainly have and I think I'm about to. I only went to the E6600 since I already had one I had pulled from a Windoze machine that I went quad on, but I'm about to get another and may go to E6700. I don't do transcoding, so the E6600 was more than enough boost for me.
My take on OS6 is that it's more hackable because it's based on a more up-to-date kernel, so there is more that's compatible. I'm not a Linux guru and have stuck mostly with the pre-compiled install packages for RAIDiator, so I'm going in deeper with OS6.
Message 250 of 285
Top Contributors
Announcements
