Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
More on CPU specs of the ReadyNAS Pro
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2013-03-02
06:48 PM
2013-03-02
06:48 PM
Re: More on CPU specs of the ReadyNAS Pro
Are your four drives in dual redundancy? Mine are so it's really a three drive config. Maybe a drive cache size difference?
Steve
Steve
Message 151 of 285
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2013-03-02
10:18 PM
2013-03-02
10:18 PM
dsm1212 wrote: Are your four drives in dual redundancy? Mine are so it's really a three drive config. Maybe a drive cache size difference?
Single redundancy for me. The "-T" test reads from the portion of your main RAM that Linux uses as a disk buffer; it just tests how fast Linux's disk-cache algorithm running on your CPU can read data from your RAM. The drive isn't even accessed during the timed portion of the test, so nothing about the drive's performance -- including the size of the drive's onboard cache -- should affect the result of the "-T" cached-read test.
2 × Pro 6 [Main & Backup] – XRAID2 Dual-Redundant (RAID6): 14.53TB (110MB/s Write, 123MB/s Read)
- CPU: 2.4GHz E6600 SL9ZL - RAM: 8GB (PSD28G800K) - BIOS: 07/26/2010 - OS: 6.10.3 w/ custom kernel - Drives: 6 × ST4000VN000 / ST4000VN008
Fans: Noctua NF-S12A FLX (Case), NF-R8 PWM (CPU), NF-R8 w/LNA (Power Supply) - USB: STGY8000400 - UPS: APC BR1000G
- CPU: Standard 1.8GHz Atom D525 - RAM: 2GB (CT25664BC1067) - BIOS: 11/02/2011 - OS: 4.2.31 - Drives: 2 × ST4000VN000 - Fan: Noctua NF-B9 - USB: ST31000340
Message 152 of 285
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2013-03-03
10:24 AM
2013-03-03
10:24 AM
Mmh i tried it with a Q6600 (4Core) in After the BIOS Update the ReadyNAS 6 worked perfekt. So i went an took my ReadyNAS PRO with the Q6600 i get this (Even After the BIOS Update).
Sat Mar 2 18:58:21 CET 2013 System is up.
Sat Mar 2 18:14:26 CET 2013 System is up.
Sat Mar 2 18:01:01 CET 2013 VBAT power is out of normal range [expected: 3.30 current: -0.00].
Sat Mar 2 18:01:01 CET 2013 3VDUAL power is out of normal range [expected: 3.30 current: -0.00].
Sat Mar 2 18:01:01 CET 2013 VCC1_05 power is out of normal range [expected: 1.04 current: -0.00].
Sat Mar 2 18:01:00 CET 2013 VCC1_5 power is out of normal range [expected: 1.50 current: -0.00].
Sat Mar 2 18:01:00 CET 2013 VCC1_25 power is out of normal range [expected: 1.25 current: -0.00].
Sat Mar 2 18:01:00 CET 2013 VCC3 power is out of normal range [expected: 3.30 current: -0.00].
Sat Mar 2 18:01:00 CET 2013 AVCC power is out of normal range [expected: 3.30 current: -0.00].
Sat Mar 2 18:01:00 CET 2013 DDB18 power is out of normal range [expected: 1.80 current: -0.00].
Sat Mar 2 18:00:40 CET 2013 Gerät fährt herunter
Sat Mar 2 18:00:40 CET 2013 Bitte schließen Sie diese Browsersitzung und melden Sie sich nach dem Neustart mit RAIDar wieder an. Das System fährt jetzt herunter...
Sat Mar 2 18:00:33 CET 2013 Fan 1 has failed (SYS -1 rpm).
Sat Mar 2 18:00:33 CET 2013 VBAT power is out of normal range [expected: 3.30 current: -0.00].
Sat Mar 2 18:00:33 CET 2013 3VDUAL power is out of normal range [expected: 3.30 current: -0.00].
Sat Mar 2 18:00:33 CET 2013 VCC1_05 power is out of normal range [expected: 1.04 current: -0.00].
Sat Mar 2 18:00:33 CET 2013 VCC1_5 power is out of normal range [expected: 1.50 current: -0.00].
Sat Mar 2 18:00:33 CET 2013 VCC1_25 power is out of normal range [expected: 1.25 current: -0.00].
Sat Mar 2 18:00:33 CET 2013 VCC3 power is out of normal range [expected: 3.30 current: -0.00].
Sat Mar 2 18:00:33 CET 2013 AVCC power is out of normal range [expected: 3.30 current: -0.00].
Sat Mar 2 18:00:33 CET 2013 DDB18 power is out of normal range [expected: 1.80 current: -0.00].
Message 153 of 285
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2013-03-03
10:29 AM
2013-03-03
10:29 AM
Now i put back in my E6600 and it Works with no error Messages but Lot slower (put still faster as the Org. CPU). Is there a change to get it to work with the Q6600? What are These error Messages mean? How i cut fix that?
Thx 4 your help
Thx 4 your help
Message 154 of 285
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2013-03-03
05:29 PM
2013-03-03
05:29 PM
Weird. I though those were read off the board, they are power voltages. Maybe the chipset doesn't work well with that CPU, causing some issues.
If the system appears to work otherwise when you see those errors, I can provide a boot script work around, to have the system not log those errors.
Jedi Council Alumni | See my profile About page for my ReadyNAS history (2004-2012) |
https://twitter.com/chirpah/status/852389882764840960/photo/1
Message 155 of 285
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2013-03-03
05:37 PM
2013-03-03
05:37 PM
On boot up, RAIDiator firmware looks at the system type, and builds a layout for monitor_enclosure (health check program, adjusts fans, sends alerts). Easiest way to deal with your logs is to modify that layout (saved in ramdisk) and restart moitor_enclosure. I haven't tested this out, but it should hopefully work, maybe needing a few tweaks:
I had to do a similar boot script for my retro-fitted Repertoire. I replaced the Sparc board with x86 (Ultra4 board). Since the Repertoire chassis has no fans, the system would complain that the fan has failed. The script I used there would tell the system there was no fans to monitor (over the default Ultra4 layout), so no more alerts would occur.
# cat /etc/rc2.d/S02readynas_enclosureThis removes the voltage lines from the layout, then restarts the service. So it won't know to read the voltages, causing logs/email alerts. If you look at /ramfs/enclosure.cfg, you can also see references for the temp/fan sensors.
#!/bin/bash
sed '/^vol/d' /ramfs/enclosure.cfg > /tmp/enc.$$$
mv /tmp/enc.$$$ /ramfs/enclosure.cfg
killall monitor_enclosure
sleep 1
/frontview/bin/monitor_enclosure
Message 156 of 285
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2013-03-04
08:06 PM
2013-03-04
08:06 PM
Well 4 drives should do a little better than 3 and one of my drives is a cool model (an odd 5900rpm I believe), but it seems hard to believe that is all of the difference. Could you post the output of hdparm -i /dev/sda? I'd like to see if there is anything special your drive can do. Maybe the fact that I have 3 different drive models triggers some poor md behavior due to cache size mismatches or something.
One thing odd I noticed is that when I run the test of /dev/c/c my USB drives all wake up. I've got 4 of them attached to a USB hub. Maybe I should try disconnecting them all?
steve
Message 157 of 285
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2013-03-04
11:58 PM
2013-03-04
11:58 PM
chirpa wrote: There may be even newer BIOS now, but I don't work there anymore to know that.
You can try running this add-on (install in FrontView, don't need USB boot anymore), which will update to the latest I had at the time: http://www.readynas.com/download/addons ... .5-x86.bin
That v0.5 add-on provides these BIOS versions:
- Ultra2/ReadyNAS-ProUltra2 (1102/v1.8)
- Ultra4/ReadyNAS-NVX-V2 (0823/v1.1)
- Ultra6/FLAME6-2 (0610/v1.1)
- Pro(6)/FLAME6-MB (0726/v2.0)
Sorry if that is a old Question, but How i can see that the Firmware is Installed?
Thx
Message 158 of 285
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2013-03-05
08:23 AM
2013-03-05
08:23 AM
Check bios_ver.log in the System Logs download.
Message 159 of 285
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2013-03-05
04:14 PM
2013-03-05
04:14 PM
dsm1212 wrote:
fastfwd wrote: The "-T" test reads from the portion of your main RAM that Linux uses as a disk buffer; it just tests how fast Linux's disk-cache algorithm running on your CPU can read data from your RAM. The drive isn't even accessed during the timed portion of the test, so nothing about the drive's performance -- including the size of the drive's onboard cache -- should affect the result of the "-T" cached-read test.
Right, your drive performance is none of the difference in the -T cached-read test, since that test only measures the speed at which data travels between the NAS's RAM and the NAS's CPU.
Message 160 of 285
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2013-03-06
08:40 AM
2013-03-06
08:40 AM
Well, it seems like hdparm is not very accurate. I ran a more simple test and I get similar IO rates to the drive, but the reads from the linux cache are much higher than what hdparm reports. I'm still suspicious as what the heck hdparm does with my USB drives.
This is what I did:
# First create a 1GB file:
dd if=/dev/zero of=gigfile bs=1M count=1000
# Flush the file to disk
sync
# purge the cache
echo 3 | sudo tee /proc/sys/vm/drop_caches
# see the cache is mostly empty
free -m
# time the physical read case
time cat gigfile > /dev/null
# see that the big file is now in cache
free -m
# time the cache read
If I divide 1000 / by the elapsed time I get a physical read number similar to hdparm. For me about 300MB/sec. I think the difference there is probably the drives I'm using. But for the cached read I get over 4000MB/s so I don't understand why hdparm reports only 1900MB/s.
By the way fastfwd, what os rev are you running? I'm running 4.2.21.
thanks,
steve
This is what I did:
sync
# purge the cache
free -m
free -m
thanks,
steve
Message 161 of 285
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2013-03-06
09:46 AM
2013-03-06
09:46 AM
dsm1212 wrote: Well, it seems like hdparm is not very accurate.
Yeah. The throughput tests should be run only when the system is idle, and they should be run a few times; the fastest result is the most accurate one. I usually do a series of ten runs over a couple minutes, and I often see a 2:1 range of speeds.
dsm1212 wrote: By the way fastfwd, what os rev are you running? I'm running 4.2.21.
4.2.22, with the 07/26/2010 BIOS (which Netgear calls 2.0 and AMI calls 8.14).
Message 162 of 285
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2013-03-08
10:18 AM
2013-03-08
10:18 AM
Hi guys,
Actually I have the original ReadyNAS Pro Pioneer Edition (bought in 2009) with this bios revision :
07/26/2010 FLAME6-MB V2.0 (Thanks to chirpa's bios_update addon).
It's actually running a Core 2 Duo E6700 @2.66GHz and 2x2Gigs DDR2 PC6400 Crucial and I would like to know if i can upgrade the CPU, because I find that the E6700 is powerful but hot.
Thank you
Thank you
Message 163 of 285
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2013-03-08
01:37 PM
2013-03-08
01:37 PM
bzhpedro wrote: I have the original ReadyNAS Pro Pioneer Edition (bought in 2009) with this bios revision :
Do you happen to remember your processor's SSPEC number? The SL9S7's idle current consumption is approximately double that of the SL9ZF, and since your processor spends most of its time idle, this is a significant factor in chip temperature. If you have an SL9S7, swapping it for an SL9ZF would probably help a lot.
One data point, possibly helpful: In my Pro Pioneer, a 2.4GHz E6600 SL9ZL (with the same low-power optimizations as the E6700 SL9ZF), runs cooler than the standard 1.8GHz E2160.
Message 164 of 285
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2013-03-10
11:23 PM
2013-03-10
11:23 PM
Hi guys,
I'm thinking of getting a ReadyNAS Pro Business Edition, RNDP6610.
I want to upgrade the CPU in this puppy, so I've browsed trough the topic and I've seen various CPU models being mentioned. However I am unsure which ones are compatible with the RNDP6610...
Could someone please tell me which CPU models are compatible with the RNDP6610?
I am looking to do some 'heavy' transcoding, so I'm looking at all CPU power that I can get.
Thanks!
Thanks!
Message 165 of 285
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2013-03-11
03:51 AM
2013-03-11
03:51 AM
it always depends on your Board Version, and the Firmware. I have a first Gen. ReadyNAS Business and the best what i can use in it is a Intel E6600 (2x 2.6 GHz / 4 Cache / Bus 1066MHz). In a second ReadyNAS PRO Business, but much newer, a Intel Q6600 (4x 2.6 GHz / 8 Cache / Bus 1066MHz) is runing just perfekt AND COOLER! Always check the TEMP on your CPU under full load.
But you cut put practically any CPU that fits this Profile: 1.) the Socket LGA775 2.) Busspeed max. 1066MHz
and i think in some Mainbordversions only Max TDP 65W but this is variable you have to find out.
(as far i found out, more Cache on the CPU is better than more GHz)
Like these
E6600 or E6700 (runs hotter)
http://ark.intel.com/products/27251/Int ... 66-MHz-FSB
some say the E7600 is the fastes
http://ark.intel.com/products/41495/Int ... 66-MHz-FSB
or Q6600 (i think the Best)
http://ark.intel.com/products/29765/Int ... 66-MHz-FSB
or Q6700 (runs hotter)
http://ark.intel.com/products/30790/Int ... 66-MHz-FSB
Oder ev. X6800 (runs hotter)
http://ark.intel.com/products/27258/Int ... 66-MHz-FSB
or ev. QX6700 (runs hotter)
http://ark.intel.com/products/28028/Int ... 66-MHz-FSB
and don't forget:
Like these
and don't forget:
You can try running this add-on (install in FrontView, don't need USB boot anymore), which will update to the latest I had at the time: http://www.readynas.com/download/addons ... .5-x86.bin (Link Fixed)
Message 166 of 285
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2013-03-11
05:19 AM
2013-03-11
05:19 AM
Thanks for your quick and detailed reply!
I'm not sure what version the ReadyNas Business Pro I am planning to buy is, but I do know that it is 4 years old.
So if I understand it correctly, the first Gen does not support quad-core CPUs but your second gen supports quadcore CPUs, right?
I am mainly interested in the E7600 because it's TDP is the same as the original CPU and should suffice for my needs.
The link in the last quote to he BIOS is broken
Thanks!
soremaniac wrote: it always depends on your Board Version, and the Firmware. I have a first Gen. ReadyNAS Business and the best what i can use in it is a Intel E6600 (2x 2.6 GHz / 4 Cache / Bus 1066MHz). In a second ReadyNAS PRO Business, but much newer, a Intel Q6600 (4x 2.6 GHz / 8 Cache / Bus 1066MHz) is runing just perfekt AND COOLER! Always check the TEMP on your CPU under full load.
Thanks!
Message 167 of 285
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2013-03-11
07:07 AM
2013-03-11
07:07 AM
Thank you for your answer but I am already with a SL9ZF ;-)
But I am using transcoding a lot with AirVideo for streaming on my iPad and iPhone.
Message 168 of 285
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2013-03-11
10:43 AM
2013-03-11
10:43 AM
When I did my CPU swap, I went from an E2160 to E6400. The same clock speed, but has VT-d and more cache. Was using it for AirVideo transcoding and VirtualBox use. I believe the E6400 is what the 3200 came with at one point.
Message 169 of 285
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2013-03-11
11:46 AM
2013-03-11
11:46 AM
It's possible. I really like the Pro with the E6700 but I do not find a better cooler which can fit in the ReadyNAS to cool this great CPU the way it should be cooled.
Chirpa, do you have any idea if a third party cooler could fit ?
Thank you
Thank you
Message 170 of 285
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2013-03-11
11:49 AM
2013-03-11
11:49 AM
Ya, but has to be the right low profile to fit in the case. Thought I saw someone add a larger one, and void warranty by chopping up the side panel.. Thread somewhere?
Message 171 of 285
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2013-03-11
11:52 AM
2013-03-11
11:52 AM
Thank uou Chripa, I already found a link for a cooler (http://www.coolmod.com/product/3765/0/0 ... -Cobre.htm) but i do not find it anywhere in stock. That's why I am asking, and i do not want to do anything on the panel.
I would like to find a 3rd party fit to fit replacement ;-)
I am pretty sure it does not exist, but I will never know if I do not ask
Message 172 of 285
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2013-03-11
11:54 AM
2013-03-11
11:54 AM
That one may fit, need to measure height in the chassis. Stick a paperclip through the vent holes on the Pro, to the existing heatsink, see how much space is still available.
Message 173 of 285
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2013-03-11
12:06 PM
2013-03-11
12:06 PM
I will check when I get home.
Thank you chirpa
Thank you chirpa
Message 174 of 285
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2013-03-11
04:39 PM
2013-03-11
04:39 PM
bzhpedro wrote: Thank uou Chripa, I already found a link for a cooler (http://www.coolmod.com/product/3765/0/0 ... -Cobre.htm) but i do not find it anywhere in stock. That's why I am asking, and i do not want to do anything on the panel.
I don't know, but i think this will not work, becouse the fan on the ReadyNAS is fixed to the Board with scrus, the fan on the pic has some kind of clip like the orginal intel fan's and i cut not mout this fan with these "clip-system" to the readynas board.
http://www.coolmod.com/images/product/1/large/pl_1_4_3765.jpg
i may be wrong but, then tell me how...
Message 175 of 285
