- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NFS "Read-only file system" and odd folder ownership
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
So I'm trying to mount a share via NFS, and I've done this so many times, but for some reason this share when mounted says "NFS "Read-only file system" when I try to perform any actions on it.
The ownership of the folder is also odd:
0 drwxrwxrwx 1 systemd-resolve 98 168 Jan 3 10:35
NFS settings are correct allowing access to my IP, File Access settings I don't quite understand because there is no login like SMB, but my user and the share owner has read/write + admin access set.
type nfs4 (rw,relatime,vers=4.2,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=192.168.1.65,local_lock=none,addr=192.168.1.99)
Any help appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: NFS "Read-only file system" and odd folder ownership
Check the UID of the systemd-resolve on your local system, and see what UID that matches on the NAS.
I'm thinking that the read-only issue might also be a result of not matching the UID and GIDs on the account you are using to mount the folder.
