× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Reply
Not able to install Portainer after upgrade to 6.10.2
NT_2112
Follower
Running 6.10.2 on a ReadyNas 424.  After trying to install Portainer, the install fails and the ReadyNas admin login page appears.  Portainer is not installed.
I downloaded the logs via the web admin and saw this in the install_debpkg.log.
Any ideas on how to get this installed?
Install app portainer
fv-app-install-utils.c:101(info) [portainer](0%) prepare
fv-app-install-utils.c:111(info) Installing [portainer](50%) Running dpkg
fv-app-install-utils.c:111(info) Installing [portainer](50%) Installing portainer
fv-app-install-utils.c:111(info) Installing [portainer](58%) Preparing portainer
fv-app-install-utils.c:111(info) Installing [portainer](67%) Unpacking portainer
fv-app-install-utils.c:111(info) Installing [portainer](75%) Preparing to configure portainer
fv-app-install-utils.c:111(info) Installing [portainer](75%) Running dpkg
fv-app-install-utils.c:111(info) Installing [portainer](75%) Configuring portainer
fv-app-install-utils.c:111(info) Installing [portainer](83%) Configuring portainer
fv-app-install.c:345(error) Error: file[portainer] message: subprocess installed post-installation script returned error exit status 1
fv-app-install.c:674(error) fv-app-install (portainer): error code [100]: Reading package lists...
Building dependency tree...
Reading state information...
The following NEW packages will be installed:
portainer
debconf: delaying package configuration, since apt-utils is not installed
0 upgraded, 1 newly installed, 0 to remove and 31 not upgraded.
Need to get 0 B/10.3 kB of archives.
After this operation, 21.5 kB of additional disk space will be used.
Selecting previously unselected package portainer.
(Reading database ... 16759 files and directories currently installed.)
Preparing to unpack .../portainer_1.16.4-ml0_amd64.deb ...
Unpacking portainer (1.16.4-ml0) ...
Setting up portainer (1.16.4-ml0) ...
Error response from daemon: manifest for portainer/portainer:1.16.4 not found
Unable to find image 'portainer/portainer:1.16.4' locally
dpkg: error processing package portainer (--configure):
Errors were encountered while processing:
portainer
E: Sub-process /usr/bin/dpkg returned an error code (1)
fv-app-install-utils.c:121(info) [portainer](0%) abort
Message 1 of 8
tigerten
Luminary
Re: Not able to install Portainer after upgrade to 6.10.2
I have same problem, no solution so far. Have you figured out how to get it running? My porteiner won"t start at all. I have seen this person found a way around. But I have no clue how to do it.
https://community.netgear.com/t5/ReadyNAS-Storage-Apps-Current/addon-updated-version-of-portainer-ap...
Message 2 of 8
givememynamebak
Luminary
Message 3 of 8
givememynamebak
Luminary
Mhynlo just created a release that seems to work for me:   https://github.com/Mhynlo/readynas-portainer/releases/tag/1.16.4-ml1
Message 4 of 8
yoban
Apprentice
Hi there
Not wanting to hijack the thread as it is good to see @Mhynlo create a fix, but was wondering how to update from version 1.16.4-ml0 which is runnign on OS6.9.5?
Will an update be available via "readynas app store"? Or could I load the latest DEB file from his gitub account and install, hoping it will not break any containers.
Thoughts or tips?
Message 5 of 8
Guru
It'd be up to @Mhynlo to provide an updated app in the ReadyNAS app store.
Message 6 of 8
givememynamebak
Luminary
I doubt portainer would break any current containers as it's just a management tool.  You could try to upgrade from new release (https://github.com/Mhynlo/readynas-portainer/releases/tag/1.16.4-ml1), and if that fails - just re-install the old one and you should be back to where you are now I would think.  I'm not sure what versions the new one is compatible with but it might just work.  If it were me, I'd always try the latest version before I try an older version.
Message 7 of 8
givememynamebak
Luminary
For what it's worth:  I installed the deb file and it worked fine.  Not the one in the app store, and I have no idea if he's planning to update that.
Message 8 of 8
Discussion stats
  • 7 replies
  • 2961 views
  • 2 kudos
  • 5 in conversation
Announcements
