- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
OwnCloud 8.0.4
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OwnCloud 8.0.4
On ReadyNAS OS 6 there is no need to install a separate PHP package for ownCloud. Those files are meant for older ReadyNAS systems and can only be installed through their web interface. I'll have a look into your problem but it would help if you could send me the log file that can be found in /var/log/readynasd/install_debpkg.log.
-Stefan
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OwnCloud 8.0.4
I sent you the log on a message. did you get it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OwnCloud 8.0.4
Yup, got it. To me it looks like the OS partition of your ReadyNAS has run out of space. Can you please check by running "df -kh" in an ssh shell?
-Stefan
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OwnCloud 8.0.4
here it is:
Welcome to ReadyNASOS 6.6.0 Last login: Fri Dec 30 16:28:04 2016 from 192.168.0.110 root@NASPON:~# df -kh Filesystem Size Used Avail Use% Mounted on udev 10M 4.0K 10M 1% /dev /dev/md0 4.0G 1010M 2.8G 27% / tmpfs 249M 4.0K 249M 1% /dev/shm tmpfs 249M 476K 248M 1% /run tmpfs 125M 0 125M 0% /run/lock tmpfs 249M 0 249M 0% /sys/fs/cgroup /dev/md127 2.8T 971G 1.8T 35% /data /dev/md127 2.8T 971G 1.8T 35% /home /dev/md127 2.8T 971G 1.8T 35% /apps
it would be strange for me that there is no space. i do not have installed any app.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OwnCloud 8.0.4
Hi osilvab,
Does seem that you have space on your OS partition. Let's wait for a feedback from WhoCares_.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OwnCloud 8.0.4
yes. thank you for your help.
and happy new year!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OwnCloud 8.0.4
I have tried differnt things but no luck yet.
here is the log:
START(/tmp/C:\Users\osilv\Downloads\owncloud_9.1.1-rnx1_all.deb): Tue Jan 3 10:05:32 CET 2017
Ign http://dl.bintray.com wheezy InRelease
Get:1 http://dl.bintray.com wheezy Release.gpg [821 B]
Hit http://security.debian.org jessie/updates InRelease
Hit http://egnyte-cdn.egnyte.com 6.6 InRelease
Get:2 http://dl.bintray.com wheezy Release [1,839 B]
Hit http://apt.readynas.com 6.6.0 InRelease
Hit http://security.debian.org jessie/updates/main armel Packages
Hit http://egnyte-cdn.egnyte.com 6.6/egnyte armel Packages
Hit http://security.debian.org jessie/updates/main armhf Packages
Hit http://egnyte-cdn.egnyte.com 6.6/egnyte armhf Packages
Get:3 http://apt.readynas.com 6.6.0/updates armel Packages [2,197 B]
Get:4 http://apt.readynas.com 6.6.0/apps armel Packages [32.5 kB]
Get:5 http://apt.readynas.com 6.6.0/main armel Packages [149 kB]
Ign http://mirrors.kernel.org jessie InRelease
Hit http://mirrors.kernel.org jessie Release.gpg
Get:6 http://apt.readynas.com 6.6.0/updates armhf Packages [520 B]
Get:7 http://apt.readynas.com 6.6.0/apps armhf Packages [21.8 kB]
Get:8 http://apt.readynas.com 6.6.0/main armhf Packages [56.1 kB]
Hit http://mirrors.kernel.org jessie/main armel Packages
Hit http://mirrors.kernel.org jessie/main armhf Packages
Fetched 265 kB in 18s (14.6 kB/s)
Reading package lists...
Building dependency tree...
Reading state information...
0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
fv-dpkginstall.awk: error 0
Successfully installed dependencies for /tmp/C:\Users\osilv\Downloads\owncloud_9.1.1-rnx1_all.deb
dpkg: error processing archive /tmp/C:UsersosilvDownloadsowncloud_9.1.1-rnx1_all.deb (--install):
cannot access archive: No such file or directory
Errors were encountered while processing:
DONE(5): Tue Jan 3 10:06:17 CET 2017
spooler returns spool_status=5 outbuf=(null) errbuf=(null) is_localapp=1 name=C:\Users\osilv\Downloads\owncloud_9.1.1-rnx1_all.deb pkgname=owncloud
any other help??
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OwnCloud 8.0.4
I have tried differnt things but still no luck.
I can not post the log here becasue then its filtered as spam
if someone else can help me i can send it by PM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OwnCloud 8.0.4
You can send it to info@rnxtras.com if you want.
-Stefan
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OwnCloud 8.0.4
whocares assisted me. the problem seem to be related to the broswer i was using (edge) as soon as I try another one it worked perfectly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OwnCloud 8.0.4
Note to moderators: As it seems Edge is sending not just the filename but the complete path instead when uploading a file. So instead of receiving for example "owncloud_9.1.3-rnx1_all.deb" the ReadyNAS will get a filename like "C:\Users\username\Downloads\owncloud_9.1.3-rnx1_all.deb". This will make the install procedure fail when trying to actually install the package using dpkg. Solution for now is to recommend using a different browser to the users, a better solution would be to find a workaround that can be implemented server side.
-Stefan
- « Previous
- 1
- 2
- Next »
