- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
OwnCloud and php addon doesn't work on ReadyNAS Duo v1
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
in the frist of all: sorry for my english.
I will install the actualy versions of owncloud, php5 and phpmyadmin - addons by RNXtras.com on my ReadyNAS Duo v1 (sparc).
The NAS is on factory setting.
That's was my install-history:
Delete the ReadyNASphoto-addon (it wasn't installed)
restart
Install MysqlOn - addon (the icon is green)
restart
Install EnableSSH addon
restart necessary by addon
install PHP 5.4.45 (R4Sparc) addon
restart
- I will activate the PHP5 modules (mysql.ini.dpkg & mysqli.ini.dpkg)
- message "Changes in PHP's mdoule configuartion were saved successfully"
- in Frontview I can't see whether the modules are enabled
install phpMyAdmin 4.2.2 addon
restart
install OwnCloud 9 (R4Sparc) - addon
restart
All addons are enable (the green lights are on)
Now I will "Access your OwnCloud", new Tab open: https://theipofmynas/owncloud/index.php
on the website see folow errors:
- Keine Datendanktreiber (SQLite, MYSQL oder PostgreSQL) installiert.
- PHP-Modul GD nicht installiert.
- PHP-Modul cURL nicht installiert.
- PHP-Module wurden installiert, werden aber noch als fehlend gelistet?
When I will "Use PhpMyAdmin", open the local website with the error:
- Die Erweiterung mysqli|mysql fehlt. Bitte die PHP-Konfiguration überprüfen. Siehe...
Please help me, thank you very much.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OwnCloud and php addon doesn't work on ReadyNAS Duo v1
It's probably best if you connect with @WhoCares_ (author of the add-on you are using). You can try PMing him here if he doesn't respond on this thread.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Betreff: OwnCloud and php addon doesn't work on ReadyNAS Duo v1
Hello,
I have exactly the same problem, I activate the modules but after clicking save they are disabled.
Did you find a solution for the problem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Betreff: OwnCloud and php addon doesn't work on ReadyNAS Duo v1
Hello SebS,
Please also update the firmware if you haven't updated yet.
@christian_henke if you are using a different model number and version, please create a new topic
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello JennC,
Thank you for your answer.
I use the Netgear ReadyNas duo v1 too.
My Firmeware is 4.1.15 I think it is currently the newst for this modul or?
