× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Problems with Backup to USB HDD
KennyRobb
OK in order to hep fix another problem with my RN104 I am trying to backup everything to a USB external HD.
RN104
Firmware 6.10.3
4x 2TB WD Red Drives (Raid 5)
external HD WD My Passport (1TB)
1. Plug external Drive into front USB port
2. Wait for it to be recognised
3. Format Drive as EXT4 (saw recommendation somewhere else on forum)
4. Create Backup Job to backup directory onto drive
5. Run Job
Backup Job Name: job_001
Backup Job Type: Incremental
Protocol: local
Backup Source: [Documents]/
Backup Destination: [USB_HDD_3]/Test
Backup Start Time: Wed May 27 2020  7:40:58 AM
Backup Finish Time: Wed May 27 2020  7:52:56 AM
Backup Status: Fail: Destination is read-only or files/folders could not be created. Check if these files or folders meet the destination file system limitation.
Cannot create file '/media/USB_HDD_3/Test/Books/Battletech/BattleTech 10977 Field Manual - Mercenaries (Rev).pdf' (error: Read-only file system)!
Other things I have tried...remove external hard drive and format NTFS....same result, failure
Here was me thinking this would be easy.
Any
suggestions
Kenny
Model: RN104|ReadyNAS 100 Series 4- Bay
Message 1 of 8
Marc_V
NETGEAR Employee Retired
Re: Problems with Backup to USB HDD
@KennyRobb
This usually happen when the drive was not properly unmounted or ejected.
You may want to check this link and perform the steps recommended and see if it will help.
https://kb.netgear.com/29402/ReadyNAS-OS-6-USB-drive-is-mounted-as-read-only
HTH
Message 2 of 8
Guru
A backup you can't access on another computer isn't worth very much.
EXT4 formatting is fine if you have other linux systems.  But if you have don't, then NTFS is a better choice.
Message 3 of 8
KennyRobb
I have followed the instruction in the post and still no luck.
1. Plug HD inot PC and reformat as NTFS
2. Made sure to eject drive
3. Put drive inot front port on RN104
4. Create new backup job pointiung backup at front USB port
5. Job Runs then Fails
Backup Job Type: Full
Protocol: local
Backup Destination: [USB Front]/
Backup Start Time: Wed May 27 2020 10:16:16 AM
Backup Finish Time: Wed May 27 2020 10:37:31 AM
Cannot create file '/media/USB_HDD_4/Books/Battletech/BattleTech 1709 - The Clans, Warriors of Kerensky.pdf' (error: Input/output error)!
Cannot create file '/media/USB_HDD_4/Books/Battletech/BattleTech 1710 - Twilight of the Clans.pdf' (error: Input/output error)!
Cannot create file '/media/USB_HDD_4/Books/Battletech/BattleTech 1711 - Field Manual, Warden Clans .pdf' (error: Input/output error)!
Cannot create file '/media/USB_HDD_4/Books/Battletech/BattleTech 1712 - Shattered Sphere.pdf' (error: Input/output error)!
Cannot create file '/media/USB_HDD_4/Books/Battletech/BattleTech 1713 - Operation Stiletto.pdf' (error: Input/output error)!
Cannot create file '/media/USB_HDD_4/Books/Battletech/BattleTech 1714 - Field Manual, Comstar.pdf' (error: Input/output error)!
Cannot create file '/media/USB_HDD_4/Books/Battletech/BattleTech 1715 - MechWarrior 3rd Edition - Character Sheet-DONE.pdf' (error: Input/output error)!
Cannot create file '/media/USB_HDD_4/Books/Battletech/BattleTech 1716 - MechWarrior Guide to Solaris VII.pdf' (error: Input/output error)!
Cannot create file '/media/USB_HDD_4/Books/Battletech/BattleTech 1717 - Capellan Confederation.pdf' (error: Input/output error)!
Cannot create file '/media/USB_HDD_4/Books/Battletech/BattleTech 1718 - Aerotech 2.pdf' (error: Input/output error)!
Cannot create file '/media/USB_HDD_4/Books/Battletech/BattleTech 1725 - Mechwarrior's Guide to the Clans.pdf' (error: Input/output error)!
Cannot create file '/media/USB_HDD_4/Books/Battletech/Battlelist.txt' (error: Input/output error)!
Cannot create file '/media/USB_HDD_4/Books/Battletech/Thumbs.db' (error: Input/output error)!
Cannot create directory Books/Grey Hat Stuff!
Cannot create directory Books/Star.Wars.Millennium.Falcon.Owner's.Manuel!
Cannot create directory Clan Wolf Web Site!
Cannot create directory Document Archive!
Cannot create directory Documents Backup November 2018!
Cannot create directory Documents backup March 2018!
Cannot create directory Downloads!
Cannot create directory Fonts!
Cannot create directory Installables!
Cannot create directory The Ancible Backup!
Copy Folder  .1567577503
Copy Folder  .1567577503/._ngcloudignore_download
Copy File  .DS_Store
Copy File  ._.DS_Store
Copy Folder  Books
Copy Folder  Books/Battletech
Copy File  Books/Battletech/BattleTech - Aerotech 2  Fighter - Record Sheet - FASA.pdf
Copy File  Books/Battletech/BattleTech - Book of Mechs - RS.pdf
Copy File  Books/Battletech/BattleTech - Complete Classic Universe .pdf
Copy File  Books/Battletech/BattleTech - Deckplans - Dropship - Pioneer X.pdf
Copy File  Books/Battletech/BattleTech - Ground Vehicle & Vtol - Record Sheet - Level 3.pdf
Copy File  Books/Battletech/BattleTech - Ground Vehicle Record Sheet.pdf
Copy File  Books/Battletech/BattleTech - Infantry Record Sheet.pdf
Copy File  Books/Battletech/BattleTech - Inner Sphere Cicra 3040 .pdf
Copy File  Books/Battletech/BattleTech - Inner Sphere Map Jumpship Paths 3062.pdf
Copy File  Books/Battletech/BattleTech - Large Craft Record Sheet.pdf
Copy File  Books/Battletech/BattleTech - Magazine - BattleTechnology # 001.pdf
Copy File  Books/Battletech/BattleTech - Magazine - BattleTechnology # 002.pdf
Copy File  Books/Battletech/BattleTech - Magazine - BattleTechnology # 003.pdf
Copy File  Books/Battletech/BattleTech - Magazine - BattleTechnology # 004.pdf
Copy File  Books/Battletech/BattleTech - Magazine - BattleTechnology # 005.pdf
Copy File  Books/Battletech/BattleTech - Magazine - BattleTechnology # 007.pdf
Copy File  Books/Battletech/BattleTech - Magazine - BattleTechnology # 015.pdf
Copy File  Books/Battletech/BattleTech - Magazine - BattleTechnology # 021.pdf
Copy File  Books/Battletech/BattleTech - Magazine - Commander Quarterly, Issue 3067 - (WizKids Product).pdf
Copy File  Books/Battletech/BattleTech - Magazine - The Tech Factory 04.pdf
Copy File  Books/Battletech/BattleTech - Magazine - The Tech Factory 05.pdf
Copy File  Books/Battletech/BattleTech - Map IS Circa 2750.pdf
Copy File  Books/Battletech/BattleTech - Map IS and Clan Circa 3063.pdf
Copy File  Books/Battletech/BattleTech - Map Jumpship Paths 3025-DONE.pdf
Copy File  Books/Battletech/BattleTech - Mech Record Sheets - FASA 3025.pdf
Copy File  Books/Battletech/BattleTech - Mechwarrior 3rd - Occupational Fields List-DONE.pdf
Copy File  Books/Battletech/BattleTech - Mechwarrior 3rd Edition - Lifepaths - Master Document.pdf
Copy File  Books/Battletech/BattleTech - Mechwarrior III Battle Armor Design Rules.pdf
Copy File  Books/Battletech/BattleTech - Protomech - Record Sheet.pdf
Copy File  Books/Battletech/BattleTech - Quad Battlemech - Record Sheet - FASA.pdf
Copy File  Books/Battletech/BattleTech - Terrain Maps.pdf
Copy File  Books/Battletech/BattleTech 10970 - Technical Readout 3067.pdf
Copy File  Books/Battletech/BattleTech 10972 - Battletech Classic Map Set Compilation.pdf
Copy File  Books/Battletech/BattleTech 10974 - Fedcom Civil War.pdf
Copy File  Books/Battletech/BattleTech 10975 - Classic Battletech Companion.pdf
Copy File  Books/Battletech/BattleTech 10976 - Field Manual Update.pdf
Copy File  Books/Battletech/BattleTech 10977 Field Manual - Mercenaries (Rev).pdf
Copy File  Books/Battletech/BattleTech 10979 - Combat Operations.pdf
Copy File  Books/Battletech/BattleTech 10981 - Classic BattleTech Miniatures Rules.pdf
Copy File  Books/Battletech/BattleTech 10982 - Field Manual, Periphery.pdf
Copy File  Books/Battletech/BattleTech 10990 - Classic BattleTech Map Set Compilation 1.pdf
Copy File  Books/Battletech/BattleTech 10991 - Technical Readout, Project Phoenix.pdf
Copy File  Books/Battletech/BattleTech 10992 - Technical Readout 3026 (Revised).pdf
Copy File  Books/Battletech/BattleTech 11000 - Classic Universe.pdf
Copy File  Books/Battletech/BattleTech 1500 - Aerotech & Mechwarrior - Dropships & Jumpships.pdf
Copy File  Books/Battletech/BattleTech 1500 - Areotech & Mechwarrior -  Dropships & Jumpships - Design Rules.pdf
Copy File  Books/Battletech/BattleTech 1604 - 4th Edition Boxed Set - Mech Sheets and Tables.pdf
Copy File  Books/Battletech/BattleTech 1604 - Battletech, 4th Edition Rulebook.pdf
Copy File  Books/Battletech/BattleTech 1605 - Tales of the Black Widow.pdf
Copy File  Books/Battletech/BattleTech 1606 - The Fox's Teeth.pdf
Copy File  Books/Battletech/BattleTech 1607 - Mechwarrior, 1st Edition Rulebook.pdf
Copy File  Books/Battletech/BattleTech 1608 - CityTech 2nd Edition.pdf
Copy File  Books/Battletech/BattleTech 1608 - Citytech (1st).pdf
Copy File  Books/Battletech/BattleTech 1609 - Aerotech.pdf
Copy File  Books/Battletech/BattleTech 1610 - Map Set #1.pdf
Copy File  Books/Battletech/BattleTech 1611 - BattleForce.pdf
Copy File  Books/Battletech/BattleTech 1612 - Succession Wars.pdf
Copy File  Books/Battletech/BattleTech 1612b - Succession Wars - Counter Sheet 1.pdf
Copy File  Books/Battletech/BattleTech 1612c - Succession Wars - Counter Sheet 2.pdf
Copy File  Books/Battletech/BattleTech 1612d - Succession Wars - Counter Set 3.pdf
Copy File  Books/Battletech/BattleTech 1613 - Galtor Campaign.pdf
Copy File  Books/Battletech/BattleTech 1614 - Cranston Snords Irregulars.pdf
Copy File  Books/Battletech/BattleTech 1615a Loki Technical Blueprint.jpg
Copy File  Books/Battletech/BattleTech 1615b MadCat Technical Blueprint.jpg
Copy File  Books/Battletech/BattleTech 1616 - The Mercenary's Handbook.pdf
Copy File  Books/Battletech/BattleTech 1617 - Gray Death Legion.pdf
Copy File  Books/Battletech/BattleTech 1619 - Dropships and Jumpships.pdf
Copy File  Books/Battletech/BattleTech 1620 - House Kurita, The Draconis Combine.pdf
Copy File  Books/Battletech/BattleTech 1621 - House Steiner, The Lyran Commonwealth.pdf
Copy File  Books/Battletech/BattleTech 1622 - House Marik, The Free Worlds League.pdf
Copy File  Books/Battletech/BattleTech 1623 - House Davion, The Federated Suns(auto full screens).pdf
Copy File  Books/Battletech/BattleTech 1624 - House Liao, The Capellan Confederation.pdf
Copy File  Books/Battletech/BattleTech 1625A - Battletech Reinforcements RS 3025.pdf
Copy File  Books/Battletech/BattleTech 1626 - The Rules of Warfare.pdf
Copy File  Books/Battletech/BattleTech 1627 - Sorensons Sabres.pdf
Copy File  Books/Battletech/BattleTech 1629 - The Periphery.pdf
Copy File  Books/Battletech/BattleTech 1630 - Star League.pdf
Copy File  Books/Battletech/BattleTech 1631 - Wolf's Dragoons.pdf
Copy File  Books/Battletech/BattleTech 1632 - Camo Specs.pdf
Copy File  Books/Battletech/BattleTech 1634 - NAIS 4th Succession War Military Atlas Vol 1.pdf
Copy File  Books/Battletech/BattleTech 1635 - NAIS 4th Succession War Military Atlas Vol 2.pdf
Copy File  Books/Battletech/BattleTech 1637 - Battletroops.pdf
Copy File  Books/Battletech/BattleTech 1638 - Map Set #3.pdf
Copy File  Books/Battletech/BattleTech 1639 - 20 Year Update.pdf
Copy File  Books/Battletech/BattleTech 1640 - The Battletech Compendium.pdf
Copy File  Books/Battletech/BattleTech 1642 - Wolf Clan.pdf
Copy File  Books/Battletech/BattleTech 1643 - Rhondas Irregulars.pdf
Copy File  Books/Battletech/BattleTech 1644 - Jade Falcon.pdf
Copy File  Books/Battletech/BattleTech 1645 - Invading Clans Sourcebook.pdf
Copy File  Books/Battletech/BattleTech 1646 - Living Legends, Star League.pdf
Copy File  Books/Battletech/BattleTech 1647 - Record Sheets Volume 1.pdf
Copy File  Books/Battletech/BattleTech 1648 - Medium Mechs Record Sheets 3025.pdf
Copy File  Books/Battletech/BattleTech 1649 - Heavy Mechs Record Sheets 3025.pdf
Copy File  Books/Battletech/BattleTech 1650 - Assault Mechs Record Sheets 3025.pdf
Copy File  Books/Battletech/BattleTech 1651 - Rolling Thunder.pdf
Copy File  Books/Battletech/BattleTech 1652 - Kell Hounds.pdf
Copy File  Books/Battletech/BattleTech 1653 - Battleforce, Battle Of Twycross.pdf
Copy File  Books/Battletech/BattleTech 1654 - Fourth Succession War Scenarios Vol 1.pdf
Copy File  Books/Battletech/BattleTech 1655 - Comstar (original).pdf
Copy File  Books/Battletech/BattleTech 1656 - Unbound.pdf
Copy File  Books/Battletech/BattleTech 1657 - More Tales of the Black Widow.pdf
Copy File  Books/Battletech/BattleTech 1659 - Solaris, The Reaches.pdf
Copy File  Books/Battletech/BattleTech 1660 - Gamemaster s Book.pdf
Copy File  Books/Battletech/BattleTech 1660 - Players Book.pdf
Copy File  Books/Battletech/BattleTech 1660 - Solaris VII Maps.pdf
Copy File  Books/Battletech/BattleTech 1663 - Map Set #4.pdf
Copy File  Books/Battletech/BattleTech 1664 - Clantroops.pdf
Copy File  Books/Battletech/BattleTech 1665 - Mechwarrior, Objective Raids.pdf
Copy File  Books/Battletech/BattleTech 1666 - Bloodright.pdf
Copy File  Books/Battletech/BattleTech 1667 - Record Sheets, Volume Five Vehicles.pdf
Copy File  Books/Battletech/BattleTech 1669 - Mccarrons Armored Cavalry.pdf
Copy File  Books/Battletech/BattleTech 1670 - Mercenary Handbook 3055.pdf
Copy File  Books/Battletech/BattleTech 1671 - MechWarrior Companion.pdf
Copy File  Books/Battletech/BattleTech 1672 - Null Set.pdf
Copy File  Books/Battletech/BattleTech 1673 - Intelligence Operations Handbook.pdf
Copy File  Books/Battletech/BattleTech 1676 - Royalty and Rogues.pdf
Copy File  Books/Battletech/BattleTech 1677 - Day of Heroes.pdf
Copy File  Books/Battletech/BattleTech 1678 - Luthien.pdf
Copy File  Books/Battletech/BattleTech 1679  Hot Spots, Contracts .pdf
Copy File  Books/Battletech/BattleTech 1679 - Hot Spots.pdf
Copy File  Books/Battletech/BattleTech 1680 - Battlespace.pdf.7j0j9lz.partial
Copy File  Books/Battletech/BattleTech 1681 - Explorer Corps.pdf
Copy File  Books/Battletech/BattleTech 1684 - The Fall Of Terra.pdf
Copy File  Books/Battletech/BattleTech 1685 - Tukayyid.pdf
Copy File  Books/Battletech/BattleTech 1686 - Black Thorns.pdf
Copy File  Books/Battletech/BattleTech 1687 - 1st Somerset Strikers.pdf
Copy File  Books/Battletech/BattleTech 1688 - Chaos March.pdf
Copy File  Books/Battletech/BattleTech 1689 - The Falcon and the Wolf.pdf
Copy File  Books/Battletech/BattleTech 1691 - BattleTech Compendium (Softcover) - RoW.pdf
Copy File  Books/Battletech/BattleTech 1692 - The Periphery.pdf
Copy File  Books/Battletech/BattleTech 1693 - Battle of Coventry.pdf
Copy File  Books/Battletech/BattleTech 1695 - Record Sheets 3025 & 3026.pdf
Copy File  Books/Battletech/BattleTech 1697 - First Strike.pdf
Copy File  Books/Battletech/BattleTech 1698 - Draconis Combine.pdf
Copy File  Books/Battletech/BattleTech 1699 - Free Worlds League.pdf
Copy File  Books/Battletech/BattleTech 1700 - Maximum Tech (Revised).pdf
Copy File  Books/Battletech/BattleTech 1701 - Field Manual, Mercenaries.pdf
Copy File  Books/Battletech/BattleTech 1702 - Northwind Highlanders.pdf
Copy File  Books/Battletech/BattleTech 1703 - Battleforce 2, Battletech Warfare on a Grand Scale.pdf
Copy File  Books/Battletech/BattleTech 1704 - The Dragon Roars.pdf
Copy File  Books/Battletech/BattleTech 1705 - Fourth Succession War.pdf
Copy File  Books/Battletech/BattleTech 1706 - Field Manual, Crusader Clans.pdf
when I look at the drive on my PC it needs a scan and a fix but there are some files that have been written as per the log.
Maybe its time to get a new NAS
Kenny
Model: ReadySHARE Vault|Backup your files on your PC
Message 4 of 8
Guru
Did you eject the drive before you removed it from the NAS?  Windows and Mac PCs don't require that step any more, but the NAS does.
When the PC gives that prompt, then the NAS will mount the drive read-only.  So run that scan.
I'm thinking it's more likely that you need a new USB hard drive.
You can test it with vendor tools in the PC (seatools for seagate or lifeguard for western digitial).
You can also try backing up the full share from the PC, using drag-and-drop, or possible a tool like teracopy or free file sync.
Message 5 of 8
KennyRobb
Made sure that USB drive is/was ejected properly from each machine it was connected to.
The USB drive in question is about 4 weeks old, however to illiminate that I have opened a brand new 4TB external USB HD and am tying that right now.
Kenny
Message 6 of 8
KennyRobb
This is related to the other issue I have open at the moment about the performance of the NAS, it will take a long time to backup all the files doing it accross the NW.
Kenny
Message 7 of 8
KennyRobb
Update: I tried a backup of another part of the file system and it seemed to go without any errors.
Went back and looked at the error and it looks like it might be one of the files causing a problem.
Doing some final checks but it seem to be working now.
Thanks for all the help
Kenny
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1680 views
  • 0 kudos
  • 3 in conversation
Announcements
