× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNAS 516 cannot mount RAID volume
adomenicus
Good afternoon! I am trying to access data on my ReadyNAS 516, using firmware 6.10.8. It has 6 drives of 4TB each, running in a RAID 5 configuration. After a batch of storm-caused power interruptions, disk 1 failed. I replaced it with a similar one, and the system started rebuilding. The morning after, I woke up to see that the system could not mount the RAID volume. RAIDair shows the following:
The admin page shows the following:
The latest log shows the following:
Looking at the logs it seems that volume 1 was resynced, but then there was a fault in disk 6 and as a consequence the RAID volume could not be assembled. I would like to recover the data, but I am not able at this time to spend the cost of Netgear level 3 support. So I tried to ssh from my windows PC, using Putty, reassemble the array using mdadm and then mount the BTRFS volume. However, when I SSH using the admin account and password, I get the message:
Could not chdir to home directory /home/admin: No such file or directory
and the connection is closed.
I would appreciate any help you can provide to me, as DIY is as far as I see the only way to get the data back. I also understand that I should have had a backup, and I had, but I am ashamed to admit that it was not updated, at all.
My bad!!
Message 1 of 4
Accepted Solutions
adomenicus
Re: ReadyNAS 516 cannot mount RAID volume
Thanks to StephenB I was able to mount the volume using
mdadm --assemble --really-force /dev/md127 /dev/sd[abcdef]3
and then painfully copy all folders and files onto spare external drives. I say painfully because the NAS was trying to rebuild the RAID drive while doing so, and performance was a dismay. While I am sure there is a way to safely prevent that, I did not try as data recovery was priority #1.
So now I can say that all data has been recovered, and I have ordered the disks to start brand new and build a new RAID drive to dump the restored data into. I have also ordered a large drive to make a regular backup ... just in case.
Thanks to StephenB and the community. You rock!!
Message 4 of 4
All Replies
Guru
@adomenicus wrote:
when I SSH using the admin account and password, ...
You need to log in as root using the NAS admin password.
I am thinking that the resync might not have been fully completed (perhaps the volume was vertically expanded in the past?).  Download the full log zip file, and take a look there.
If you like, I could take a look.  If you are interested, put the zip into cloud storage and PM me a download link (using the envelope icon in the upper right of the forum page).  Make sure the permissions are set so anyone with the link can download.
Message 2 of 4
adomenicus
Thank you so much! Dumb of me I did not realize I had to log in as root. I PMed you the link to the log file. Truly appreciate any help!
Message 3 of 4
adomenicus
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2085 views
  • 0 kudos
  • 2 in conversation
Announcements
