- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS Pro Pioneer Edition web-console not accessable.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm having problems accessing the device by network(139/445 NetBIOS) and web(80,443, FrontView web-console). The mentioned TCP ports do not respond. The only tool that sees the NAS is RAIDar and it reports the device is operating well green lights. Also it's okay when I ping it.
Is there a way to get it back online or maybe get the data from the black box? It was configured with RAID-6, if this helps. I saw some multiple posts with similar problems but solution was provided in PM.
Any ideas or guidance would be welcome.
Thanks,
Max
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNAS Pro Pioneer Edition web-console not accessable.
Windows file explorer doesn't work? (but did before)?
Are there other file protocols enabled on the NAS (for instance FTP)?
Is ssh enabled?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any router changes? RAIDar will see a NAS on a different subnet than the computer it's running on, but the other protocols won't. If you assigned a static address to the NAS and then changed subnets (usually due to a router change), that can cause your problem.
