× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNas Issues
Turtle3656
Follower
ReadyNas Issues
My router died. My network changed from 192.168.1.1 to 192.168.0.1. Both Nas had static Ip addresses. How can I access them to change the ip addresses.
Message 1 of 2
Sandshark
Sensei
Re: ReadyNas Issues
Obvious easy answer is to change the router configuration to use the old subnet.
Connecting a computer directly and setting it to an appropriate IP address is another.
And finally, there is doing an OS re-install, which will reset the unit to use DHCP as well as the admin password back to the default.
And once you do get access, don't just change it to another static IP.  Reserve the IP address in your router so next time you'll just have to figure out (using RAIDar or the NAS display) what address DHCP assigned and change it in that router.
Message 2 of 2
Discussion stats
  • 1 reply
  • 458 views
  • 0 kudos
  • 2 in conversation
Announcements
