× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Rsync over SSH - cannot connect to remote
Jubin3
Hi,
I have been trying to get some clear information regarding setting up a backup job using rSync over SSH and i've had little sucsess with finding information or getting this working and the error "Unable to connect to host"
Setup
  • Ubuntu Server 16.04
    Running KVM server
  • ReadyNAS 3312 (i'm aware this is not the same modle as listed)
    Firmware 6.9.4 HOTFIX 1
I have checked that SSH is enabled on the ReadyNAS in the sysem menu and also within the user. issues that i'm having is been able to export the ssh-key form ubuntu and get it imported into the Ready NAS.
Any advise of help with this would be grately apreciated and any other information that might be needed let me know.
Thanks
Model: ReadyNAS-4200|ReadyNAS 4200
Message 1 of 5
JohnCM_S
NETGEAR Employee Retired
Re: Rsync over SSH - cannot connect to remote
Hi Jubin3,
Welcome to the Community!
If you are trying to import the ssh-key to the ReadyNAS, you can follow these steps:
1. Go to Account > Users.
2. Click the User click Settings then under the SSH tab click Import Public Key.
3. Click Browse, then select the public key (Note: The public key must be a text file). Once it is selected, you can just click Upload.
You may also visit this link for the steps.
Message 2 of 5
JohnCM_S
Hi Jubin3,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The NETGEAR community looks forward to hearing from you and being a helpful resource in the future!
Message 3 of 5
Jubin3
Hi,
I have gone thought this, but my current issue is not so much imporanting the key but getting a key from Ubuntu 16.04 Server and it does not appear in the dir that is shown in the link. I have logged into SSH on the ReadyNAS and then SSH'd back into my Ubuntu server in the hope this would pull the key but with no sucsess.
Been looking for any information on collecting the SSH key from my Ubuntu Server in sevral differnt ways.
Kind Regards
Message 4 of 5
Guru
Did you try generating one?  https://www.digitalocean.com/community/tutorials/how-to-set-up-ssh-keys-on-ubuntu-1604
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1840 views
  • 0 kudos
  • 3 in conversation
Announcements
