Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Running VirtualBox VM host on ReadyNAS Pro
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-06-24
10:35 AM
2009-06-24
10:35 AM
Re: Running VirtualBox VM host on ReadyNAS Pro
🙂 Glad to hear. I'm still using my VM as my daily system, with a laptop being a "thin client" to it, works great.
muggsy wrote: but with the great instructions, very painless
Message 76 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-06-24
01:36 PM
2009-06-24
01:36 PM
Chirpa, I used your instructions to load my VM up at startup. But it doesn't seem to be working. The script is fine coz I can load it that way. Any ideas? Windows 7 seems to be working a treat on it, so appreciate the thread a lot.
Message 77 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-06-24
01:40 PM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-06-24
03:41 PM
2009-06-24
03:41 PM
chirpa wrote: Referring to this?
I will need to test it out. The script works manually, so its probably a path/environment when running it from the automated system control.
yeah that's the one. Any logs I can check? Other than that it works great. Got my 4GB upgrade for me PRO, and I'll pop an Win 2K3 server on there as well.
Message 79 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-06-24
04:05 PM
2009-06-24
04:05 PM
On the VBox lines, try adding "> /tmp/vbox.log" and see what it outputs.
Message 80 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-07-01
12:57 AM
2009-07-01
12:57 AM
VirtualBox 3.0 is out, I will be installing it tomorrow probably.
VirtualBox 3.0.0 (released 2009-06-30)
This version is a major update. The following major new features were added:
Windows guests: ability to use Direct3D 8/9 applications / games
Support for OpenGL 2.0 for Windows, Linux and Solaris guests
Message 81 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-07-17
11:00 PM
2009-07-17
11:00 PM
VirtualBox 3.0.2 (released 2009-07-10)
This is a maintenance release. The following items were fixed and/or added:
VMM: fixed network regressions (guest hangs during network IO) (bug #4343)
VMM: guest SMP performance improvements
VMM: fixed hangs and poor performance with Kaspersky Internet Security (VT-x/AMD-V only; bug #1778)
VMM: fixed crashes when executing certain Linux guests (software virtualization only; bugs #2696 & #3868)
ACPI: fixed Windows 2000 kernel hangs with IO-APIC enabled (bug #4348)
APIC: fixed high idle load for certain Linux guests (3.0 regression)
BIOS: properly handle Ctrl-Alt-Del in real mode
iSCSI: fixed configuration parsing (bug #4236)
OVF: fix potential confusion when exporting networks
OVF: compatibility fix (bug #4452)
NAT: fixed crashes under certain circumstances (bug #4330)
3D support: fixed dynamic linking on Solaris/OpenSolaris guests (bug #4399)
3D support: fixed incorrect context/window tracking for multithreaded apps
Shared Folders: fixed loading from saved state (bug #1595)
Shared Folders: host file permissions set to 0400 with Windows guest (bug #4381)
X11 host and guest clipboard: fixed a number of issues, including bug #4380 and #4344
X11 Additions: fixed some issues with seamless windows in X11 guests (bug #3727)
Windows Additions: added VBoxServiceNT for NT4 guests (for time synchronization and guest properties)
Windows Additions: fixed version lookup
Linux hosts: workaround for buggy graphics drivers showing a black VM window on recent distributions (bug #4335)
Linux hosts: fixed typo in kernel module startup script (bug #4388)
Installer: support Pardus Linux
Solaris hosts: several installer fixes
Solaris host: fixed a preemption issue causing VMs to never start on Solaris 10 (bug #4328).
Solaris guest: fixed mouse integration for OpenSolaris 2009.06 (bug #4365)
Windows hosts: fixed high CPU usage after resuming the host (bug #2978)
OVF: accept ovf:/disk/ specifiers with a single slash in addition to ovf://disk/ (bug #4452)
Fixed a settings file conversion bug which sometimes caused hardware acceleration to be enabled for virtual machines that had no explicit configuration in the XML.
Message 82 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-07-19
05:04 PM
2009-07-19
05:04 PM
I upgraded to Virtualbox 3.0 via apt-get and seems to work fine
Message 83 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-08-02
03:25 AM
2009-08-02
03:25 AM
I have been following the instructions in the first post but get the following dependency errors:
I am running firmware 4.2.5. Any ideas how I fix this? Thanks.
# apt-get update && apt-get install build-essential
The following packages have unmet dependencies:
build-essential: Depends: libc6-dev but it is not going to be installed or
libc-dev
Depends: g++ (>= 4:4.1.1) but it is not going to be installed
# apt-get install libc6-dev
libc6-dev: Depends: libc6 (= 2.7-18) but 2.3.6.ds1-13etch9+b1 is to be installed
Depends: linux-libc-dev but it is not installable
Message 84 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-08-02
05:03 AM
2009-08-02
05:03 AM
I have managed to fix it by removing the following line from my sources.list file:
deb http://www.readynas.com/packages readynas-x86/
Message 85 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-08-07
08:28 AM
2009-08-07
08:28 AM
hi,
Just installed the virtualbox 3.0.4 🙂
changelog :
changelog :
* VMM: 64 bits guest stability fixes (AMD-V only; bugs #3923 & #3666)
* VMM: SMP stability fixes (AMD-V only)
* VMM: SMP performance improvement (esp. for Solaris guests)
* VMM: eliminated several bugs which could lead to a host reboot
* VMM: fixed OS/2 ACP2 boot floppy hang (VT-x only)
* VMM: small performance improvement for OpenSolaris guests (AMD-V only)
* VMM: fixed CentOS/Xen reboot (software virtualization only; bug #4509)
* SATA: fixed hangs / BSOD during Windows XP installation (bug #4342)
* SATA: mark the ports as non hotpluggable (bug #3920)
* 3D support: fix deadlocks and context/window tracking for multithreaded applications (bug #3922)
* 3D support: fix memory leaks when terminating OpenGL guest applications
* 3D support: fix crash in Call of Duty
* NAT: using two or more NAT adapters in one VM was broken (3.0.0 regression)
* NAT: fixed network communication corruptions (bugs #4499, #4540, #4591, #4604)
* NAT: fixed passive ftp access to host server (bug #4427)
* iSCSI: fixed cloning to/from iSCSI disks
* GUI: fixed path separator handling for the OVF export on Windows (bug #4354)
* GUI: the mini toolbar was only shown on the first host display (bug #4654)
* GUI: added a VM option to display the mini toolbar on top
* GUI: don’t crash when adding plus configuring host-only network interfaces
* Shared Folders: fixed selection of a drive root directory as a shared folder host path in VirtualBox (Windows host only)
* USB: fixed a bug that may have rendered USB devicefilter settings inactive (3.0.2 regression, bug #4668)
* Guest Additions: report the Guest Additions version to the guest properties (bug #3415)
* Mac OS X hosts: fix creation of VMDK files giving raw partition access (bug #1461)
* Mac OS X hosts: improved support for Snow Leopard
* Linux hosts: fixed problems leading to wrong colors or transparency in host windows with some graphics drivers (bug #3095)
* Linux hosts: hardware detection fallbacks if the hal service fails to find any DVD drives.
* Linux and Solaris hosts: Work around color handling problems in Qt (bug #4353)
* Solaris hosts: fixed memory leaks in host-only networking
* Solaris Installer: fixed incorrect netmask for Host-only interface (bug #4590)
* Solaris Installer: added package dependency for Python and Python-devel (bug #4570)
* X11 guests: prevent windows from being skipped in seamless mode KDE guests (bugs #1681 and #3574)
* X11 guests: fixed screen corruption in X11 guests when large amounts of video RAM were allocated (bug #4430)
* X11 guests: some fixes when switching between host and guest-drawn mouse pointers.
* X11 guests: fixed an issue which caused seamless mode to stop working as it should (the main issue listed in bug #2238).
Message 86 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-08-11
10:40 AM
2009-08-11
10:40 AM
I'm running 3.0.4 as well 🙂
Message 87 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-08-20
10:29 AM
2009-08-20
10:29 AM
hello,
I'm trying to install Virtualbox on a NVX but I've a problem at the end of this command :
# apt-get install virtualbox-3.0
I've this message in vbox-install.log
I've the 4.2.5 firmware and I use 4.2.5 sources
I follow Chirpa's instructions......
Anyone have an idea?
Thx
** Compiling vboxdrv
Makefile:150: Warning: using /usr/src/linux as the source directory of your Linux kernel. If this is not correct, specify KERN_DIR=<directory> and run Make again.
Makefile:158: *** Error: /usr/src/linux (version 2.6.27.6.RNx86.2.1) does not match the current kernel (version 2.6.27.6.RNx86.1.1). Stop.
Thx
Message 88 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-08-20
04:37 PM
2009-08-20
04:37 PM
Any chance of a VB add on? Super are you game? 😄
BigBearf
BigBearf
Message 89 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-08-20
11:52 PM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-08-21
12:25 PM
2009-08-21
12:25 PM
thx a lot .
I've tried but I've a different error now :
perhaps I miss something ......
Reading package lists... Done
Building dependency tree... Done
Recommended packages:
libsdl-ttf2.0-0 linux-headers libhal1 pdf-viewer libgl1 python-central
The following NEW packages will be installed:
virtualbox-3.0
0 upgraded, 1 newly installed, 0 to remove and 5 not upgraded.
Need to get 0B/50.2MB of archives.
After unpacking 102MB of additional disk space will be used.
Preconfiguring packages ...
(Reading database ... 22370 files and directories currently installed.)
Unpacking virtualbox-3.0 (from .../virtualbox-3.0_3.0.4-50677%5fDebian%5fetch_i386.deb) ...
dpkg: error processing /var/cache/apt/archives/virtualbox-3.0_3.0.4-50677%5fDebian%5fetch_i386.deb (--unpack):
subprocess pre-installation script returned error exit status 123
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
Message 91 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-08-21
01:11 PM
2009-08-21
01:11 PM
Try:
# wget http://download.virtualbox.org/virtualbox/3.0.4/VirtualBox-3.0.4-50677-Linux_x86.runinstead of the Debian package.
# chmod +x VirtualBox-3.0.4-50677-Linux_x86.run
# ./VirtualBox-3.0.4-50677-Linux_x86.run
Message 92 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-08-21
01:31 PM
2009-08-21
01:31 PM
I've the same first error (RNx86.1.1 instead of RNx86.2.1)
may I uncheck some option in menuconfig?
thx again
thx again
Message 93 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-08-21
03:29 PM
2009-08-21
03:29 PM
Copy the defconfig as noted in my other thread. Then do a 'make clean;make all' in the kernel sources, then try installing VirtualBox again. Should work.
Message 94 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-08-22
06:15 AM
2009-08-22
06:15 AM
same thing
here is exactly what I've done :
during vbox install I've this message :
# echo "deb http://download.virtualbox.org/virtualbox/debian etch non-free" >> /etc/apt/sources.list
# wget -q http://download.virtualbox.org/virtualbox/debian/sun_vbox.asc -O- | apt-key add -
# wget -q http://www.readynas.com/download/GPL/RNDP6xxx_4.2.5_WW_src.zip
# unzip -q RNDP6xxx_4.2.5_WW_src.zip -d ./GPL
# cd GPL/linux-x86-2.6/
# cp arch/x86/configs/tolapai_defconfig arch/x86/configs/i386_defconfig
# make menuconfig (I do this otherwise I've this error : (missing kernel .config file))
# make clean;make all
# ln -s /c/backup/GPL/linux-x86-2.6/ /usr/src/linux
# KERN_DIR=/usr/src/linux
Python found: python, installing bindings...
/bin/bash: python: command not found
Building the VirtualBox vboxdrv kernel module
Failed to build the vboxdrv kernel module.
Message 95 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-08-25
12:46 AM
2009-08-25
12:46 AM
a Chirpa's advice? :wink:
Message 96 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-08-26
12:35 AM
2009-08-26
12:35 AM
I'll try and do a quick setup of it on an NVX in the office, and get back to you.
Last tried it on an NVX back in ~March with 4.2.4 (viewtopic.php?f=52&t=26922). Will give it a try with 4.2.5 in the next few days.
Message 97 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-08-26
09:50 AM
2009-08-26
09:50 AM
thx Chirpa,
with the topic concerning NVx, it works.
I replace the
by
perhpas you could merge it with this one.
but thx a lot for your great help
I replace the
by
cp arch/x86/configs/tolapai_Makefile Makefile
cp arch/x86/configs/tolapai_defconfig .config
Message 98 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-09-02
02:44 AM
2009-09-02
02:44 AM
VirtualBox 3.0.6 Beta 1 released
changelog here : http://forums.virtualbox.org/viewtopic.php?f=1&t=21920
Message 99 of 442
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-09-10
12:08 PM
2009-09-10
12:08 PM
Virtualbox 3.0.6 final is out
changelog here : http://www.virtualbox.org/wiki/Changelog
install successful on my Pro
Message 100 of 442
