Orbi WiFi 7 RBE973
Reply
Transmission 3.00.8 Permission denied
xupaaki
Tutor
Hi,
I cant find a way to make transmission working on my rn102 with 6.2.5 or 6.4 firmware... previous version of transmission used to work great, but since I factory reseted the NAS first installing the 6,2.5 firmware, and now with the 6.4 I get permission denied just about few moments I start a download.
I tried to change the donwload path using the remote GUI, and I already did another factory reset to the NAS but still happening the same error... If anyone coul help me would be great.
thanks in advance
Message 1 of 3
JennC
NETGEAR Employee Retired
Re: Transmission 3.00.8 Permission denied
Hello xupaaki,
Can you try adding 8.8.8.8 as DNS server?
Go to admin page of NAS, then Network, click settings for the Ethernet it is using then DNS.
Once done, check the Transmission again.
Message 2 of 3
xupaaki
Tutor
tried that...but didn´t work...anyway I found a solution...
I did once again a factory reset, but just with one hdd inside...
I had to use raidar after that because I was unable to acess the GUI.... Raidar was able to acess the NAS but told I had to format the HDD...so I did...reinstalled all the apps and the second HDD....magicaly now everything is working....3 factory reset later!!!
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 4396 views
  • 0 kudos
  • 2 in conversation
Announcements
