× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Trying to install iDrive on ReadyNAS Pro 6 running 6.10.9
Greg00001
Star
I have a ReadyNas Pro 6 running (unsupported) 6.10.8.  I did a factory reset on it a month or so ago and setup some shares.  The other day I downloaded Plex from Plex and was able to install and configure that and is running fine.  I downloaded the latest idrive file from idrive and tried to install and only get an error window "Cannot install application idrive".  I then went to the app page in the readynas and tried to install the older version listed there and get the same error.  I then went to the Netgear firmware page and found 6.10.9 and upgraded.  Firmware upgrade worked fine.  I then tried to install idrive again with the same generic error. Any suggestions appreciated on how I could get this installed.
Message 1 of 2
Guru
Re: Trying to install iDrive on ReadyNAS Pro 6 running 6.10.9
Try making the changes in the first post here:
Use 6.10.9 on the first one (not 6.10.8).
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1450 views
  • 2 kudos
  • 2 in conversation
Announcements
