- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Help adding a OK disk with SMART warnings
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a HDD that got the SMART Raw Read Error Rate value set to 148 and Multi Zone Error Rate set to 1 after removing it from a secure data overwrite device without disabling the port first. It is a Western Digital WD30EFRX with about 9 months on time, but out of warranty due to it beeing a unused spare HDD for a few years.
I have done extensive testing by connecting it to PC's, servers and devices and the drive is operating correctly with no errors. I have checked it with WD's tool and it shows as OK. The Status / Health in the admin interface of the ReadyNAS 2100 v2 menu shows the drive as OK, but when connecting it to the ReadyNAS the log after a while shows "Newly added disk has failed SMART test. Please check disk 4.". I have however not found a way to clear this warning in the log and so it will not add the HDD to the volume.
I do not want to throw the disk out as it is working fine. There is currently no data on the NAS while I'm working on this.
Any ideas?
SMART Attribute | |
Raw Read Error Rate | 148 |
Spin Up Time | 6008 |
Start Stop Count | 18 |
Reallocated Sector Count | 0 |
Seek Error Rate | 0 |
Power On Hours | 6579 |
Spin Retry Count | 0 |
Calibration Retry Count | 0 |
Power Cycle Count | 18 |
Power-Off Retract Count | 10 |
Load Cycle Count | 87 |
Temperature Celsius | 27 |
Reallocated Event Count | 0 |
Current Pending Sector | 0 |
Offline Uncorrectable | 0 |
UDMA CRC Error Count | 0 |
Multi Zone Error Rate | 1 |
ATA Error Count | 0 |
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
A SMART test isn't just reading SMART stats. If the disk is failing the SMART test then you shouldn't use the disk.
As you have the 2100 v2 (I assume that's what shows on the homepage of Frontview) and you have no data on the unit you might wish to consider putting OS6 on the unit.
The 2100 v2 can run OS6 (though unsupported) whereas the v1 cannot as the v1 has a 32-bit x86 CPU.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Help adding a OK disk with SMART warnings
@mdgm wrote:A SMART test isn't just reading SMART stats. If the disk is failing the SMART test then you shouldn't use the disk.
Well, the SMART status of the drive is OK and these parameters are generally not considered critical so this HDD should be fine to use for non-critical storage. If only ReadyNAS would let me. If it was increasing reallocated sectors counts or something like that, it would be a completely different thing.
But OS6 sounds like an interesting idea. Maybe that would work. I'll give it a try unless someone here thinks otherwise.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I upgraded to OS6 and so far it looks really good. It is currently syncing. It seems OS6 have better handling of SMART.
I will update here when the sync is completed and I have done some tests.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well, OS6 was the solution to the SMART-issue, but it introduced instability. The NAS becomes unresponsive if it is doing more than just simple file shares, like a backup job, and requires power cycling. Maybe it is a low RAM issue, so I'll see if I have some suitable spare RAM modules.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Originally 1 GB was enough, but the memory footprint as grown over the years. Several shipping NAS have 2 GB, so add at least one 1 GB.
I don't recall seeing much here on upgrading RAM in the 2100v2. With legacy desktop models, compatible 4 GB DDR2 modules are both hard to find and expensive. 2 GB DDR2 works well and is much cheaper.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@StephenB wrote:
@DuBa wrote:Maybe it is a low RAM issue, so I'll see if I have some suitable spare RAM modules.
I had a couple compatible 4 GB modules in my old RAM box. That box have saved me many times. And now one more time. With 4 GB RAM the 2100v2 runs flawlessly.
