- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Missing /bin folder (ReadyNAS 600 Pro+ RNDP600U)
- Mark as New
- Bookmark
- Subscribe
- Permalink
While connected via ssh and performing an rsync backup I managed to delete the /bin folder on from the device rather than from the external HDD, however the copy on the external HDD is available.
How can I copy get a copy of the /bin folder back onto the device.
Notes:
- The external HDD is connected to one of the USB ports on the rear of the device
- I have ssh sessions open on as root, 2 from a Windows 10 station, and one from a linux box running linuxlite 3.8
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Performing the OS reinstall from the boot menu worked, now the admin menu is reporting a drive in predictive failure (it wasn't before and I only knew via email alert). My understanding it that the drive is hot swappable, please correct me if I am wrong as I do have a replacement on hand.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Missing /bin folder (ReadyNAS 600 Pro+ RNDP600U)
You could of course copy the files with the cp command (or use rsync in the reverse direction).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Currently the ssh prompt is at the external HDD, so the correct command to execute is?
"cp -a ./bin/. /"
- Mark as New
- Bookmark
- Subscribe
- Permalink
Apparently the not all the contents of the /bin/ were copied over to the external hdd as originally thought, there were only links:
lrwxrwxrwx ed
lrwxrwxrwx ip
lrwxrwxrwx ipaddr
lrwxrwxrwx iplink
lrwxrwxrwx iproute
lrwxrwxrwx iprule
lrwxrwxrwx iptunnel
lrwxrwxrwx lsmod.modutils
lrwxrwxrwx lspci
lrwxrwxrwx mt
lrwxrwxrwx pidof
lrwxrwxrwx rbash
lrwxrwxrwx setpci
lrwxrwxrwx sh
lrwxrwxrwx usleep
lrwxrwxrwx vi
Suppose the only thing to do now is:
- factory reset the unit
- reconfigure it
- restore all the data
Mistakes were made, lesson learned...
- Mark as New
- Bookmark
- Subscribe
- Permalink
You could try
# touch /.os_update
or
# echo > /.os_update
Then reboot the NAS
Or do an OS Re-install using the boot menu. This should recreate the /bin folder.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Doesn't touch reside within the /bin/ folder or am I mistaken?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hmmm. Good point.
In that case you may need to use the boot menu to do an OS Re-install. Though depending how much the system is messed up doing a factory reset and restoring from backup may still be the best way forward.
Though you just need to do anything that creates the /.os_update file (it can be empty)
Even something like
1 > /.os_update
might work. It'd give an error but it'd probably still create the file.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Where is this file to reside, I would want to verify the file creation using:
rsync --list-only -v
I am assuming a reboot of the device would then be necessary to complete the process or will this happen or is tht not the case.
In the process of validting my backup copy to the external USB hdd before I loose the ability to mount devices.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The file would reside in / as indicated by the command I gave. It can be empty and will automatically get removed as part of the OS Re-install (to avoid triggering it again on each subsequent reboot).
The path for that file is deliberately pretty much as simple as it gets. We know that we should always be able to write to that location unless the root volume has somehow gone read-only or has some other equally serious problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Apologies, I should have known that. I am not a linux expert and doing my best, I am also as you can imagine tired/stressed, am very appreciative of your quick responses and assistance in helping me.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Verification of backup is complete.
Have since lost my SSH sessions due to an unexpected reboot and therefore unable to complete your request of generating the os_update file unless there is another way.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@mdgm-ntgr also suggested doing an OS reinstall from the boot menu, which should do the same thing. Have you tried that?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Great.
If you are using XRAID with at least two drives, or a FlexRAID mode with redundancy then you can hot swap the drive, and it should resync.
It'd be good to update your backup (at least of critical data), since the array is unprotected during the resync.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Great.
Running X-RAID2
I REALLY appreciate all the help and support, thank you all so very much!
I had backed up all the data to an external drive connnected to one of the rear USB ports, althought the degraded array made that process a lot slower than I would have liked.
