- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NAS 104 slow or hangs
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have just started to us my RN104 as my music library store...
Up to date everything worked well .. and all latest updates installed
The system is accessable by several W10 PC ... both ethernet and WIFI
It seems to take a long time .. 10 seconds or so to load a file if I havent used the player recently
and often hangs at 99.89% or even 100% when I edit or update music track information.
Any suggestions to improve this situation ?
I am using AIMP software .. but seems the same using other software.
Many thanks in advance
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: NAS 104 slow or hangs
Do you have drive spin-down enabled? That can slow initial response.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for the reply
SPIN DOWN was on ... have now turned it off but really dont notice any difference.
A
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you have strict sync enabled for the NAS share, try turning it off.
Are you seeing a more normal speed when you browse to the NAS share using file explorer?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you Boh for the support and suggestions... strict sync was on .. turned off but dont see and improvement.
Things seems ok accessing via a browser.
These suggestions have taken me into new areas in the config.. so thought should post a pic of the setup incase that shows a cue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What firmware are you running?
Turning off strict sync will speed up writes, but not reads.
Perhaps try running NasTester on one of the PCs, and let us know what read/write performance you are seeing. http://www.808.dk/?code-csharp-nas-performance
Broadly speaking, directory browsing using SMB is much slower than reading/writing large files. So if the application on the PC is wading through a lot of files (or subfolders), it will be be slow. Similarly, accessing a database on the NAS over the network can be slow. Options to improve performance include
- using ReadyDLNA on the NAS itself (which will give you less features)
- using Plex on the NAS (not sure how the features would compare)
- using PC software that has a database on the PC, so the software doesn't search as much
- upgrading to a more powerful NAS
- using SSDs instead of mechanical disks
- Mark as New
- Bookmark
- Subscribe
- Permalink
More new areas ... I did the test .. and attached the results.. are they good or bad ?
Is READYDLNA the DLNA button in the settings?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Southernwave wrote:Is READYDLNA the DLNA button in the settings?
Yes.
They are not particularly good. Is the PC using WiFi or ethernet?
FWIW, this is what I see on an RN102 running RAID-1 with Seagate 1 TB Ironwolf drives:
Running a 400MB file write on \\10.0.0.13\Music 5 times... Iteration 1: 71.52 MB/sec Iteration 2: 72.59 MB/sec Iteration 3: 72.84 MB/sec Iteration 4: 75.11 MB/sec Iteration 5: 73.33 MB/sec ----------------------------- Average (W): 73.08 MB/sec ----------------------------- Running a 400MB file read on \\10.0.0.13\Music 5 times... Iteration 1: 46.50 MB/sec Iteration 2: 58.20 MB/sec Iteration 3: 58.24 MB/sec Iteration 4: 58.41 MB/sec Iteration 5: 53.61 MB/sec ----------------------------- Average (R): 54.99 MB/sec -----------------------------
I only use this NAS occasionally for tests - not sure the read speeds are as slow as they are.
