× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Need to reinstall Remote on a Duo
ceez1
I removed the ReadyNAS remote add on from my Duo. Can't seem to find the image for remote in the Downloads section.
Where do I get it?
Message 1 of 2
mdgm-ntgr
NETGEAR Employee Retired
Re: Need to reinstall Remote on a Duo
https://remote.ReadyNAS.com/download.html
Installation is via System > Update > Local. Duo (v1) is Sparc. The x86 and ARM add-ons are not the one you want.
Alternatively do an OS Re-install (see v1 hardware manual: http://www.ReadyNAS.com/docs)
Message 2 of 2
Discussion stats
  • 1 reply
  • 3069 views
  • 0 kudos
  • 2 in conversation
Announcements
