× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
RNDP6000 vith OS6 and readycloud
Archdivan
HI! There is known issue: RNDP6000 with OS 6 has no s/n and numbers are the same with MAC adress of device. that way i can't access to readycloud. also i know that legacy has no support but it seems to easy-solved, so i ask for some help. sorry for my poor english.Cat Embarassed
Model: ReadyNASRNDP600E|ReadyNAS Pro Pioneeer Chassis only
Message 1 of 7
Accepted Solutions
JohnCM_S
NETGEAR Employee Retired
Re: RNDP6000 vith OS6 and readycloud
Hi Archdivan,
The fix has been applied already and the NAS was rebooted afterwards. The unit should have the actual serial number now.
Message 3 of 7
All Replies
JohnCM_S
Hi Archdivan,
Welcome to the Community!
Can you take a picture of the serial number and the MAC address of the NAS? That is usually located at the back or underneath of the chassis. Please PM it to me afterwards.
Message 2 of 7
JohnCM_S
Hi Archdivan,
Message 3 of 7
Archdivan
WOW, It's really great! You're the best!
Message 4 of 7
Archdivan
Wow! It's a magic! 😃 that's why a NETGEAR the best!
Message 5 of 7
computim
Luminary
Good afternoon - Would it be possible to have the same fix for my unit? Readynas RNDP6310-100NAS.
Message 6 of 7
JohnCM_S
@computim
The fix has been applied and the NAS was rebooted to Normal mode again. Please check if it is now showing the actual S/N.
Message 7 of 7
Discussion stats
  • 6 replies
  • 2909 views
  • 2 kudos
  • 3 in conversation
Announcements
