- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS Duo produced 2011, how to upgrade?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello
I have found working very well old stuff (produced in 2011) and when i try to upgrade this very old stuff (RAIDiator 4.1.7 [1.00a043] )
i see only message - please check website. And in website there is no support for this stuff.
Does anybody know some options to do that even this stuff is so old and unsupported?
Thank you in advance for any suggestions.
Best regards, Michal
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNAS Duo produced 2011, how to upgrade?
Current firmware is 4.1.16 and is found here: https://kb.netgear.com/000038792/RAIDiator-Version-4-1-16-Sparc
So if the on-line check for firmware updates doesn't give you anything, you can download the zip file in the above link, and manually install it from Frontview. Note you need to extract the image from the zip - you can't install the zip itself.
Documentation and some other info is here: https://www.netgear.com/support/product/RND2000v1_(ReadyNAS_Duo_v1).aspx#docs
Your NAS is end-of-life, so there will be no more firmware updates for it. In addition to the on-line resources, you can get paid support via my.netgear.com.
