- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS OS6 Apps / Add-ons For Current Hardware/Firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
I could really use an app that is similar to the old (2017) Linux-Dash app that used to be, and is no longer, available
for ReadyNAS.
OS6. See screenshot attached.
I need a way to see process usage, user activity and connection activity, etc.
Does anyone have some suggestion for a similar dashboard type app??
I appreciate some things about Netgear's implementation of a NAS OS, however, tt is clear that Synology and QNAP have more
support for apps on their OSs. and that is disappointing. Also, Netgear is not releasing updated new hardware/features as often.
For Netgear hardware I am running RN526X systems and OS 6.10.7
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@michaeldowns wrote:
That is correct it was uninstalled at one point.
If you would, what would be the procedure to install the Github version using apt-get?
It's not an app I use. Looking at the github, it doesn't seem to use apt-get. https://github.com/afaqurk/linux-dash#readme
You'd want to be careful with the install instructions, as you don't want to over-fill the NAS OS partition. Plus git isn't installed by default on the NAS.
The simplest answer is to reinstall the old version, downloading from @Sandshark's link.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNAS OS6 Apps / Add-ons For Current Hardware/Firmware
Why do you say Linux Dash is unavailable? https://apps.readynas.com/pages/?page_id=9 . Granted, it's an old version, but I'm running it on OS 6.9.6 and I've seen nothing here (save this post) suggesting it's broken under 6.10.x.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks very much for your reply.
Linux-Dash is not shown in the apps listing in the ReadyNAS OS6 UI on the in-house hardware; RN526, RN312, RN102.
(see attached screenshot)
From that I presume there may be some limitation/issue for that app in the current and legacy hardware/firmware.
BTW, the version of Linux-Dash available for ReadyNAS on that link is 0.5.1 -- on Github it is v2.0.
Also notice that there are so few apps compared to alt vendors.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@michaeldowns wrote:Linux-Dash is not shown in the apps listing in the ReadyNAS OS6 UI on the in-house hardware; RN526, RN312, RN102.
It shows up on that screen for me (RN526x) - between Limesurvey and Logitech Media Server.
That particular page only shows the available apps that are not installed on your system. Is Linux-Dash showing up on the "Installed apps page"? If not, did you try to install it at some point.
@Sandshark's link is also "official", and you can download the app, and manually install it from the apps page.
It's up to the app developer to keep it up to date - and Slobberbone chose not to do that. It might be possible to update it it via ssh using apt-get.
True - that is what it is. IMO Netgear didn't provide enough incentives for app developers.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks very much.
I understand about install issues and agree about lack of dev support by Netgear.
