× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Runaway alerts
StuBarrett1
Runaway alerts
OK, replaced my dead power supply on my ReadyNAS Business/Pro model RNDP6000.
I'm now getting this alert once a minute:
3VDUAL power is out of normal range [expected: 3.30 current: 3.04].
AVCC power is out of normal range [expected: 3.30 current: 3.09]
I've turned off my SMTP alerts, but the logs are growing and I keep getting a pop-up notifications when I'm logged into the Admin page.
Two questions:
  - The unit appears to be working fine, so it this a bad problem?
  - If not, then how do I turn off these alerts?
BTW, the new power supply indicates that it provides 3.3v.  The technition thought that it could be due to the old molex connectors.
Thanks, Stu
Message 1 of 13
Sandshark
Sensei
Re: Runaway alerts
Since the 24-pin ATX connectors is not repeatedly connected and re-connected, the fact that it is "old" is unlikely to be the problem.  3,3V is on 4 wires -- the orabge ones.  You could check that they are making good contact, but I suspect you have a power supply that's genuinely supplying out-of-spec voltage.  Did your technician check that voltage under the load of the NAS?
If you've checked and the voltage really is OK, you could edit /etc/sensors.d/system.conf via SSH and change the test limits for the 3.3V.  The lines that control that are:
label in2 "AVCC"
set in2_min 3.3 * 0.90
set in2_max 3.3 * 1.10
label in3 VCC3
set in3_min 3.3 * 0.90
set in3_max 3.3 * 1.10
I hate to say anything derogatory about somebody I've never met, but anyone who thinks that's not a problem and says it "could be" because of old connectors and then does no further investigation does not deserve the title "technician".
Message 2 of 13
StuBarrett1
Re: Runaway alerts
Thanks, for the tip on how to change the voltage threasholds.
As the the technician testing the voltage underload, there was no way in hell that I was going to put my disks in the chassis with him poking around 😉
Stu
Message 3 of 13
Sandshark
Sensei
Re: Runaway alerts
Jusr FYI, the drives put no load on the 3.3V, so powering up without them would be as good a test on the 3.3V as with them.  Of course, the NAS won't boot to the condition where you see if the NAS itself reports the low voltage.  But you could use a scratch disk for that.  It takes very little time for it to initialize a single-drive volums.
Message 4 of 13
YottaByte
Re: Runaway alerts
Sandshark,
I have a legacy ReadyNAS Pro Business RNDP6000 and the same problem as StuBarrett1 after replacing my dead original Seasonic power supply. My ReadyNAS boot_info.log shows min values of 3.12V for both AVCC and 3VDUAL resulting in the runaway alerts for my 3.06V and 3.07V voltages. When I SSH in as root, I don't see the /etc/sensors.d/ directory and can't find the system.conf file. My /etc directory listing has no /sensors.d directory between the /security and /services directories. Any thoughts on this, please?
Thanks,
Karl
Message 5 of 13
tomfrey2320
Re: Runaway alerts
Hi ,
I have same issue with a replaced power supply on a readynas pro6 ... I can ssh to the nas but there is not a file in the same location as you tate above. where do I find the file to edit the warning thresholds?
Tom
Message 6 of 13
Guru
Re: Runaway alerts
@tomfrey2320 wrote:
Hi ,
Tom
What firmware are you running on the NAS?
Message 7 of 13
tomfrey2320
Re: Runaway alerts
HI Sorry about that
RAIDiator 4.2.31
Message 8 of 13
YottaByte
Re: Runaway alerts
Tom,
I was told that the /etc/sensors.d/system.conf file mentioned in an earlier posting is only applicable to OS6, not RAIDiator 4.2.x. The runaway alert problem was due to a bad replacement supply I obtained from an ebay seller. I located a new Seasonic SS-300SFD supply locally which fixed the issue.
Karl
Message 9 of 13
tomfrey2320
Re: Runaway alerts
Hi Karl,
Ok thanks ... where did you get you ss-300sfd from ... I could not locate any and also bought one from a ebay seller that is causing this popup
tom
Message 10 of 13
Guru
Re: Runaway alerts
@tomfrey2320 wrote:
RAIDiator 4.2.31
I think @Sandshark's path is for OS-6.  At least that path doesn't exist on my Pro-6 (also running 4.2.31).
Message 11 of 13
YottaByte
Re: Runaway alerts
Tom,
I purchased Item Number SS-300SFD from Technology Center below. The Seasonic SS-300SFD supply was identical to my original supply, except for a shorter main power harness, for which I got an 8" ATX 24pin extension. I returned the problem power supply to the ebay seller.
Technology Center
1681 Glendale Ave
Sparks, NV 89431
(775) 329-8100
https://www.tcreno.com/
sales@tcreno.com
Message 12 of 13
Sandshark
Sensei
Re: Runaway alerts
Yes, it is OS6 only.  Sorry for the confusion.  I can find no similar path for OS4.2.x.
Message 13 of 13
Discussion stats
  • 12 replies
  • 3693 views
  • 2 kudos
  • 5 in conversation
Announcements
