× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Transmission 2.82 for ReadyNAS DUO v2/NV+ v2 (ARM) – FREE
ssurba
Guide
Hi Everyone,
this is the discussion thread for Transmission 2.82 for ReadyNAS DUO v2/NV+ v2 (ARM) add-on.
Add-on thread is here: http://www.readynas.com/forum/viewtopic.php?f=147&t=70426&p=390784
The latest version is 2.82-0.06.
Happy ReadyNASing! 😄
Sergey.
Message 1 of 59
chirpa
Luminary
Re: Transmission 2.73 for ReadyNAS DUO v2/NV+ v2 (ARM) – FRE
PM OOM-9 about getting moderator access to those forums to list it there.
Message 2 of 59
scrivoluce
YOU ROCKS!
Thanks for you effort buddy, it worked like a charm!!! GREAT REALEASE! 😄
Hope to see more Free portings within this pages!
Merry christmas to all of you.
Message 3 of 59
ssurba
Guide
Enjoy ! 🙂
And happy Merry Christmas to everyone!!!!
Message 4 of 59
phpandsql
thanks a lot Sergey!
just wondering does this work side by side with the transmission provided here by another develiper?
really appreciated your work!
Message 5 of 59
phpandsql
i installed this earlier today, it replaced the old transmissionBT and works absolutely fine!
Message 6 of 59
ricolevengeur
Hello,
I'm a new user. I have install this addon too. But how can i find now my dashboard? I have lost it when i type the ip adress in my internet browser.
Thx.
Rico
Message 7 of 59
keagan
Works great thanks alot
Message 8 of 59
ricolevengeur
I found my mistake. Just need to restart the nas... 😉
Message 9 of 59
dthrevan
Will his work on the Duo v1?
Message 10 of 59
dthrevan
Nevermind I found a newer version on the Sparc.
Message 11 of 59
otivax
Thanks.
It works fine in my Duo V2 😄
Message 12 of 59
ssurba
Guide
Re: Transmission 2.76 for ReadyNAS DUO v2/NV+ v2 (ARM) – FRE
Hi Everyone,
I've posted a new version 0.03 based on Transmission v.2.76.
Build version changes:
Version 0.03
  • Fixed stop.sh script to shutdown Transmission correctly and allow it to save changes to settings.json. (Thanks Gray75)
Version 0.02
  • Fixed FTP access problem with proftpd crash by setting correct permissions on /var/log, also moved Transmission log to /var/log/transmission/transmission.log. (Thanks Torry)
  • Added logrotate.d config for Transmission log files maintenance.
  • Put a link to Transmission's web interface URL on Add-on Manager page. The Add-on Manager page is automatically reconfigured on start of Transmission to reflect changes in IP address of the ReadyNAS and/or Transmission web interface port (9091 by default).
Version 0.01
  • Initial release.
Before installing this version please remove any other builds of Transmission (those not made by me). But you can keep previous version of my build, this version should upgrade it.
Message 13 of 59
danilosi69
Thanks so much Sergey, it works fine for me too!
😄 :rofl:
Message 14 of 59
phpandsql
thanks for the update!
Message 15 of 59
cosmos1
Mate, you are awesome, a zillion thanks!
Message 16 of 59
cosmos1
EDIT: A couple of questions prefetch-enabled and utp-enabled are both set to false in the settings. Any reason we should avoid enabling them? Stability issues perhaps?
Message 17 of 59
cosmos1
Ok some, info on my Duo V2: it is a single disk device and I have not installed XRAID at all. Plain JBOD here.
I made various tests, downloading in all cases the exact same torrent on the Readynas and then deleting it afterwords: http://ca.isohunt.com/download/453683906/anime.torrent
You can see that there are radically different results, depending on the torrent client and preallocation setting.
transmission, preallocation = 1
Filesystem type is: ef53
File size of [Mazui]_Boku_Ha_Tomodachi_Ga_Sukunai_NEXT_-_06_[3947814D].mkv is 246345990 (60144 blocks, blocksize 4096)
ext logical physical expected length flags
0 0 41287680 2972
1 2972 41290652 12
2 2984 41290664 116
3 3100 41290780 12
4 3112 41290792 868
5 3980 41291660 12
6 3992 41291672 16
7 4008 41291688 8
8 4016 41291696 400
9 4416 41292096 12
10 4428 41292108 3052
11 7480 41295160 8
12 7488 41295168 64
13 7552 41295232 4
14 7556 41295236 124
15 7680 41295360 4
16 7684 41295364 16
17 7700 41295380 8
18 7708 41295388 32
19 7740 41295420 4
20 7744 41295424 32
21 7776 41295456 8
22 7784 41295464 920
23 8704 41296384 12
24 8716 41296396 5740
25 14456 41302136 8
26 14464 41302144 2176
27 16640 41304320 64
28 16704 41304384 4
29 16708 41304388 24
30 16732 41304412 8
31 16740 41304420 564
32 17304 41304984 4
33 17308 41304988 28
34 17336 41305016 8
35 17344 41305024 352
36 17696 41305376 8
37 17704 41305384 536
38 18240 41305920 8
39 18248 41305928 12
40 18260 41305940 4
41 18264 41305944 32
42 18296 41305976 8
43 18304 41305984 660
44 18964 41306644 8
45 18972 41306652 32
46 19004 41306684 4
47 19008 41306688 8
48 19016 41306696 8
49 19024 41306704 48
50 19072 41306752 4
51 19076 41306756 972
52 20048 41307728 8
53 20056 41307736 4676
54 24732 41312412 8
55 24740 41312420 16
56 24756 41312436 12
57 24768 41312448 216
58 24984 41312664 4
59 24988 41312668 12
60 25000 41312680 12
61 25012 41312692 812
62 25824 41313504 8
63 25832 41313512 1060
64 26892 41314572 12
65 26904 41314584 1512
66 28416 41316096 8
67 28424 41316104 16
68 28440 41316120 8
69 28448 41316128 24
70 28472 41316152 8
71 28480 41316160 336
72 28816 41316496 8
73 28824 41316504 1696
74 30520 41318200 8
75 30528 41318208 248
76 30776 41318456 8
77 30784 41318464 5196
78 35980 41323660 4
79 35984 41323664 64
80 36048 41323728 8
81 36056 41323736 16
82 36072 41323752 4
83 36076 41323756 16
84 36092 41323772 4
85 36096 41323776 9732
86 45828 41333508 8
87 45836 41333516 4172
88 50008 41337688 8
89 50016 41337696 312
90 50328 41338008 12
91 50340 41338020 604
92 50944 41338624 4
93 50948 41338628 20
94 50968 41338648 12
95 50980 41338660 220
96 51200 41338880 8
97 51208 41338888 56
98 51264 41338944 12
99 51276 41338956 3696
100 54972 41342652 4
101 54976 41342656 52
102 55028 41342708 12
103 55040 41342720 64
104 55104 41342784 12
105 55116 41342796 2420
106 57536 41345216 2608 eof
[Mazui]_Boku_Ha_Tomodachi_Ga_Sukunai_NEXT_-_06_[3947814D].mkv: 1 extent found
transmission, preallocation = 2
0 0 41254912 6720
1 6720 41261632 4
2 6724 41261636 4216
3 10940 41265852 4
4 10944 41265856 464
5 11408 41266320 4
6 11412 41266324 108
7 11520 41266432 12416
8 23936 41278848 12
9 23948 41278860 892
10 24840 41279752 8
11 24848 41279760 28
12 24876 41279788 4
13 24880 41279792 12
14 24892 41279804 4
15 24896 41279808 256
16 25152 41280064 4
17 25156 41280068 4028
18 29184 41284096 52
19 29236 41284148 4
20 29240 41284152 64
21 29304 41284216 8
22 29312 41284224 192
23 29504 41284416 4
24 29508 41284420 20
25 29528 41284440 12
26 29540 41284452 348
27 29888 41284800 2732
28 32620 41287532 4
29 32624 41287536 5584
30 38208 41293120 4
31 38212 41293124 668
32 38880 41293792 12
33 38892 41293804 672
34 39564 41294476 8
35 39572 41294484 544
36 40116 41295028 12
37 40128 41295040 832
38 40960 41295872 12
39 40972 41295884 52
40 41024 41295936 8
41 41032 41295944 120
42 41152 41296064 12
43 41164 41296076 40
44 41204 41296116 12
45 41216 41296128 848
46 42064 41296976 12
47 42076 41296988 1295
48 43371 41298283 1
49 43372 41298284 16
50 43388 41298300 4
51 43392 41298304 80
52 43472 41298384 12
53 43484 41298396 16
54 43500 41298412 8
55 43508 41298420 1032
56 44540 41299452 4
57 44544 41299456 140
58 44684 41299596 4
59 44688 41299600 28
60 44716 41299628 4
61 44720 41299632 208
62 44928 41299840 64
63 44992 41299904 8
64 45000 41299912 2708
65 47708 41302620 12
66 47720 41302632 16
67 47736 41302648 8
68 47744 41302656 60
69 47804 41302716 4
70 47808 41302720 320
71 48128 41303040 4
72 48132 41303044 1064
73 49196 41304108 12
74 49208 41304120 3644
75 52852 41307764 12
76 52864 41307776 1216
77 54080 41308992 4
78 54084 41308996 3596
79 57680 41312592 12
80 57692 41312604 228
81 57920 41312832 4
82 57924 41312836 508
83 58432 41313344 488
84 58920 41313832 4
85 58924 41313836 16
86 58940 41313852 4
87 58944 41313856 512
88 59456 41314368 4
89 59460 41314372 48
90 59508 41314420 8
91 59516 41314428 12
92 59528 41314440 8
93 59536 41314448 40
94 59576 41314488 8
95 59584 41314496 192
96 59776 41314688 4
97 59780 41314692 40
98 59820 41314732 4
99 59824 41314736 320 eof
transmission, preallocation = 4 (did not know that there was a 4)
0 0 41385984 6144
1 6144 41406464 41392127 2048
2 8192 41394176 41408511 8192
3 16384 41408512 41402367 2048
4 18432 41402368 41410559 4096
5 22528 41410560 41406463 8192
6 30720 41451520 41418751 18432
7 49152 41470080 41469951 2048
8 51200 41474048 41472127 4096
9 55296 41478464 41478143 4096
10 59392 41484288 41482559 752 eof
[Mazui]_Boku_Ha_Tomodachi_Ga_Sukunai_NEXT_-_06_[3947814D].mkv: 11 extents found
rtorrent 0.9.1/0.13.1, system.file_allocate.set = yes
0 0 41353216 1056
1 1056 41354272 4
2 1060 41354276 791
3 1851 41355067 5
4 1856 41355072 392
5 2248 41355464 4
6 2252 41355468 397
7 2649 41355865 3
8 2652 41355868 754
9 3406 41356622 2
10 3408 41356624 220
11 3628 41356844 4
12 3632 41356848 900
13 4532 41357748 4
14 4536 41357752 738
15 5274 41358490 2
16 5276 41358492 29
17 5305 41358521 3
18 5308 41358524 428
19 5736 41358952 4
20 5740 41358956 888
21 6628 41359844 4
22 6632 41359848 210
23 6842 41360058 6
24 6848 41360064 172
25 7020 41360236 8
26 7028 41360244 18
27 7046 41360262 2
28 7048 41360264 116
29 7164 41360380 4
30 7168 41360384 212
31 7380 41360596 4
32 7384 41360600 234
33 7618 41360834 6
34 7624 41360840 816
35 8440 41361656 8
36 8448 41361664 329
37 8777 41361993 11
38 8788 41362004 84
39 8872 41362088 7
40 8879 41362095 1
41 8880 41362096 2688
42 11568 41364784 4
43 11572 41364788 572
44 12144 41365360 4
45 12148 41365364 180
46 12328 41365544 4
47 12332 41365548 272
48 12604 41365820 4
49 12608 41365824 344
50 12952 41366168 4
51 12956 41366172 56
52 13012 41366228 8
53 13020 41366236 30
54 13050 41366266 6
55 13056 41366272 59
56 13115 41366331 50
57 13165 41366381 3
58 13168 41366384 172
59 13340 41366556 4
60 13344 41366560 104
61 13448 41366664 4
62 13452 41366668 60
63 13512 41366728 4
64 13516 41366732 152
65 13668 41366884 8
66 13676 41366892 820
67 14496 41367712 4
68 14500 41367716 288
69 14788 41368004 4
70 14792 41368008 21
71 14813 41368029 7
72 14820 41368036 3
73 14823 41368039 1
74 14824 41368040 212
75 15036 41368252 4
76 15040 41368256 85
77 15125 41368341 3
78 15128 41368344 128
79 15256 41368472 12
80 15268 41368484 45
81 15313 41368529 3
82 15316 41368532 36
83 15352 41368568 4
84 15356 41368572 7
85 15363 41368579 9
86 15372 41368588 17
87 15389 41368605 7
88 15396 41368612 1
89 15397 41368613 3
90 15400 41368616 653
91 16053 41369269 11
92 16064 41369280 56
93 16120 41369336 4
94 16124 41369340 28
95 16152 41369368 12
96 16164 41369380 194
97 16358 41369574 10
98 16368 41369584 36
99 16404 41369620 12
100 16416 41369632 1845
101 18261 41371477 3
102 18264 41371480 2250
103 20514 41373730 6
104 20520 41373736 3
105 20523 41373739 1
106 20524 41373740 336
107 20860 41374076 4
108 20864 41374080 64
109 20928 41374144 7
110 20935 41374151 9
111 20944 41374160 6
112 20950 41374166 2
113 20952 41374168 52
114 21004 41374220 4
115 21008 41374224 128
116 21136 41374352 4
117 21140 41374356 28
118 21168 41374384 8
119 21176 41374392 225
120 21401 41374617 7
121 21408 41374624 5
122 21413 41374629 3
123 21416 41374632 16
124 21432 41374648 4
125 21436 41374652 52
126 21488 41374704 8
127 21496 41374712 8
128 21504 41374720 12
129 21516 41374732 36
130 21552 41374768 7
131 21559 41374775 9
132 21568 41374784 64
133 21632 41374848 4
134 21636 41374852 32
135 21668 41374884 4
136 21672 41374888 51
137 21723 41374939 9
138 21732 41374948 128
139 21860 41375076 4
140 21864 41375080 4
141 21868 41375084 12
142 21880 41375096 727
143 22607 41375823 9
144 22616 41375832 1
145 22617 41375833 7
146 22624 41375840 46
147 22670 41375886 14
148 22684 41375900 244
149 22928 41376144 4
150 22932 41376148 10
151 22942 41376158 4
152 22946 41376162 14
153 22960 41376176 191
154 23151 41376367 5
155 23156 41376372 76
156 23232 41376448 8
157 23240 41376456 52
158 23292 41376508 200
159 23492 41376708 8
160 23500 41376716 22
161 23522 41376738 2
162 23524 41376740 18
163 23542 41376758 10
164 23552 41376768 48
165 23600 41376816 4
166 23604 41376820 908
167 24512 41377728 170
168 24682 41377898 10
169 24692 41377908 64
170 24756 41377972 12
171 24768 41377984 18
172 24786 41378002 14
173 24800 41378016 126
174 24926 41378142 6
175 24932 41378148 188
176 25120 41378336 4
177 25124 41378340 7
178 25131 41378347 9
179 25140 41378356 716
180 25856 41379072 12
181 25868 41379084 33
182 25901 41379117 3
183 25904 41379120 816
184 26720 41379936 4
185 26724 41379940 4
186 26728 41379944 4
187 26732 41379948 148
188 26880 41380096 4
189 26884 41380100 26
190 26910 41380126 6
191 26916 41380132 500
192 27416 41380632 6
193 27422 41380638 6
194 27428 41380644 308
195 27736 41380952 12
196 27748 41380964 64
197 27812 41381028 8
198 27820 41381036 212
199 28032 41381248 12
200 28044 41381260 208
201 28252 41381468 8
202 28260 41381476 54
203 28314 41381530 10
204 28324 41381540 95
205 28419 41381635 13
206 28432 41381648 123
207 28555 41381771 9
208 28564 41381780 304
209 28868 41382084 8
210 28876 41382092 124
211 29000 41382216 8
212 29008 41382224 24
213 29032 41382248 4
214 29036 41382252 96
215 29132 41382348 4
216 29136 41382352 44
217 29180 41382396 4
218 29184 41382400 92
219 29276 41382492 8
220 29284 41382500 156
221 29440 41382656 5
222 29445 41382661 11
223 29456 41382672 24
224 29480 41382696 4
225 29484 41382700 116
226 29600 41382816 4
227 29604 41382820 5
228 29609 41382825 7
229 29616 41382832 35
230 29651 41382867 1
231 29652 41382868 52
232 29704 41382920 4
233 29708 41382924 49
234 29757 41382973 3
235 29760 41382976 140
236 29900 41383116 4
237 29904 41383120 370
238 30274 41383490 10
239 30284 41383500 18
240 30302 41383518 2
241 30304 41383520 112
242 30416 41383632 8
243 30424 41383640 128
244 30552 41383768 8
245 30560 41383776 16
246 30576 41383792 12
247 30588 41383804 20
248 30608 41383824 12
249 30620 41383836 356
250 30976 41384192 12
251 30988 41384204 23
252 31011 41384227 5
253 31016 41384232 148
254 31164 41384380 4
255 31168 41384384 635
256 31803 41385019 13
257 31816 41385032 432
258 32248 41385464 12
259 32260 41385476 142
260 32402 41385618 2
261 32404 41385620 104
262 32508 41385724 4
263 32512 41385728 40
264 32552 41385768 6
265 32558 41385774 10
266 32568 41385784 8
267 32576 41385792 4
268 32580 41385796 45
269 32625 41385841 7
270 32632 41385848 252
271 32884 41386100 12
272 32896 41386112 94
273 32990 41386206 6
274 32996 41386212 4
275 33000 41386216 4
276 33004 41386220 4
277 33008 41386224 4
278 33012 41386228 8
279 33020 41386236 4
280 33024 41386240 44
281 33068 41386284 4
282 33072 41386288 143
283 33215 41386431 1
284 33216 41386432 341
285 33557 41386773 3
286 33560 41386776 216
287 33776 41386992 4
288 33780 41386996 220
289 34000 41387216 4
290 34004 41387220 219
291 34223 41387439 1
292 34224 41387440 848
293 35072 41388288 4
294 35076 41388292 4
295 35080 41388296 12
296 35092 41388308 4
297 35096 41388312 8
298 35104 41388320 4
299 35108 41388324 4
300 35112 41388328 17
301 35129 41388345 7
302 35136 41388352 52
303 35188 41388404 8
304 35196 41388412 208
305 35404 41388620 4
306 35408 41388624 45
307 35453 41388669 3
308 35456 41388672 19
309 35475 41388691 5
310 35480 41388696 40
311 35520 41388736 12
312 35532 41388748 20
313 35552 41388768 4
314 35556 41388772 32
315 35588 41388804 4
316 35592 41388808 12
317 35604 41388820 4
318 35608 41388824 32
319 35640 41388856 8
320 35648 41388864 76
321 35724 41388940 8
322 35732 41388948 102
323 35834 41389050 2
324 35836 41389052 174
325 36010 41389226 10
326 36020 41389236 208
327 36228 41389444 8
328 36236 41389452 372
329 36608 41389824 12
330 36620 41389836 28
331 36648 41389864 4
332 36652 41389868 836
333 37488 41390704 4
334 37492 41390708 1040
335 38532 41391748 12
336 38544 41391760 19
337 38563 41391779 13
338 38576 41391792 5
339 38581 41391797 3
340 38584 41391800 182
341 38766 41391982 10
342 38776 41391992 200
343 38976 41392192 8
344 38984 41392200 1113
345 40097 41393313 3
346 40100 41393316 271
347 40371 41393587 13
348 40384 41393600 82
349 40466 41393682 10
350 40476 41393692 31
351 40507 41393723 1
352 40508 41393724 32
353 40540 41393756 8
354 40548 41393764 6
355 40554 41393770 10
356 40564 41393780 9
357 40573 41393789 3
358 40576 41393792 152
359 40728 41393944 8
360 40736 41393952 284
361 41020 41394236 8
362 41028 41394244 15
363 41043 41394259 5
364 41048 41394264 22
365 41070 41394286 6
366 41076 41394292 40
367 41116 41394332 8
368 41124 41394340 3
369 41127 41394343 2
370 41129 41394345 11
371 41140 41394356 3
372 41143 41394359 9
373 41152 41394368 41
374 41193 41394409 3
375 41196 41394412 173
376 41369 41394585 11
377 41380 41394596 80
378 41460 41394676 4
379 41464 41394680 546
380 42010 41395226 34
381 42044 41395260 4
382 42048 41395264 45
383 42093 41395309 7
384 42100 41395316 17
385 42117 41395333 7
386 42124 41395340 33
387 42157 41395373 11
388 42168 41395384 841
389 43009 41396225 3
390 43012 41396228 36
391 43048 41396264 4
392 43052 41396268 168
393 43220 41396436 4
394 43224 41396440 124
395 43348 41396564 5
396 43353 41396569 11
397 43364 41396580 68
398 43432 41396648 4
399 43436 41396652 3
400 43439 41396655 5
401 43444 41396660 56
402 43500 41396716 8
403 43508 41396724 204
404 43712 41396928 8
405 43720 41396936 41
406 43761 41396977 11
407 43772 41396988 160
408 43932 41397148 8
409 43940 41397156 88
410 44028 41397244 8
411 44036 41397252 33
412 44069 41397285 3
413 44072 41397288 82
414 44154 41397370 10
415 44164 41397380 12
416 44176 41397392 8
417 44184 41397400 3
418 44187 41397403 9
419 44196 41397412 220
420 44416 41397632 4
421 44420 41397636 27
422 44447 41397663 5
423 44452 41397668 2
424 44454 41397670 2
425 44456 41397672 43
426 44499 41397715 1
427 44500 41397716 95
428 44595 41397811 9
429 44604 41397820 51
430 44655 41397871 5
431 44660 41397876 68
432 44728 41397944 12
433 44740 41397956 28
434 44768 41397984 4
435 44772 41397988 52
436 44824 41398040 4
437 44828 41398044 369
438 45197 41398413 3
439 45200 41398416 6
440 45206 41398422 6
441 45212 41398428 24
442 45236 41398452 4
443 45240 41398456 165
444 45405 41398621 7
445 45412 41398628 5
446 45417 41398633 3
447 45420 41398636 44
448 45464 41398680 12
449 45476 41398692 59
450 45535 41398751 13
451 45548 41398764 35
452 45583 41398799 5
453 45588 41398804 156
454 45744 41398960 8
455 45752 41398968 176
456 45928 41399144 12
457 45940 41399156 2207
458 48147 41401363 1
459 48148 41401364 16
460 48164 41401380 4
461 48168 41401384 11772
462 59940 41413156 12
463 59952 41413168 72
464 60024 41413240 4
465 60028 41413244 11
466 60039 41413255 1
467 60040 41413256 20
468 60060 41413276 4
469 60064 41413280 80 eof
Finally, running ctorrent (downloaded with apt-get install ctorrent) with the -a (for preallocate) option produced a single file having two extents only! ctorrent was the only case whereas the file was allocated entirely in advance.
There have been vast discussions over the inefficiency of posix_fallocate in the case of small NAS and media player boxes, see https://trac.transmissionbt.com/ticket/849#comment:36 , http://forum.deluge-torrent.org/viewtop ... =8&t=27725
Like I said, I have transmission running on a pop corn hour, with preallocate set to 2 and even though it somewhat freezes when starting a new file, everything works perfect afterwards. Fragmentation is kept to a minimum even if multi file downloads take place. I wonder if transmission could be patched here to zero all space, when a preallocation value of "2" ("Full") is given. Any chance you could try and produce a version with the POSIX_FALLOCATE function "killed" for that purpose?
Message 18 of 59
cosmos1
And another request: I am mostly accessing my netgear over the internet with SSH. Would you please consider adding transmision-remote and/or transmission-remote-cli to your package? I don't need fancy stuff, even transmission-remote would suffice 🙂
Once again THANK YOU for your awesome and FREE package. YOU ROCK!
Message 19 of 59
ssurba
Guide
Hi Cosmos,
thank you for your detailed input.
"prefetch-enabled" and "utp-enabled" config parameters were set to default values and I did not change them.
I'll try to get more info about POSIX_FALLOCATE function and maybe try to disable it, if possible.
But from my point of view, if you are not copying/deleting/moving files on your NAS very often, fragmentation should not be an issue. I would not bother about it at all. 🙂
Your request on including transmission-remote client is accepted, I will include it in next build.
Cheers, Sergey!
Message 20 of 59
cosmos1
ssurba wrote:
Hi Cosmos,
Cheers, Sergey!
Sergey, you are awesome mate, thank you!
IIRC, when running configure, a file should be created that shows the values of the configure values, one per line like POSIX_FALLOCATE=1. Can you please paste here this file? I am very curious on the functions supported by the box.
Message 21 of 59
phpandsql
not sure why, but all the settings e.g. speed limit and download directory do disappear every now and then, and it always goes back to the default.
Message 22 of 59
ssurba
Guide
Re: Transmission 2.77 for ReadyNAS DUO v2/NV+ v2 (ARM) – FRE
Hi phpandsql, this problem should be fixed in latest version, please try it.
Message 23 of 59
cosmos1
Awesome work, can't wait to try it at home mate!
Message 24 of 59
ashani
hello,
i am looking to enable web authentication on my transmission installation as i use port forwarding to access my web GUI remotely
Message 25 of 59
Discussion stats
Announcements
