- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
eth0 goes on and off-line
- Mark as New
- Bookmark
- Subscribe
- Permalink
Every time the network printer turns on, I recieve an error message from my RN31440 NAS saying "System: Bond interface bond0 has slave interface eth0 offline." It re-connects almost immediately, but I fear data loss if this occurs during transfers. The APS this is connected to is the probable cause(I assume?) , as the printers "turning on" may be drawing on the UPS, but I fail to see why ONLY eth0, and not both interfaces in the "Bond0" are affected? Any answers?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Am using the two ethernet ports on the RN314 in bonded mode, using LACP (layer 2 & 3). Both are connected directly to individual ports on a router. The printer, router and NAS are all connected to the same UPS.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: eth0 goes on and off-line
Port trunking/aggregation mode configured on the ReadyNAS?
What switch is the NAS (and probably the printer) connected to?
Any LAG configuration in place on the printer?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Unless this router does support LACP agregation (few higher end Netgears offer aggregation, not all come with 802.3ad LACP) and the two ports are configured accordingly, this reads like an unsupported configuration - as both ends must be configured to 802.3ad LACP agregation/trunking/bondig.
ReadyNAS OS 6.9.3 Software Manual
Configure Bonded Adapters , p.171 ff.
"Teaming Mode Description
IEEE 802.3ad LACP Creates aggregation groups that use the same speed and duplex settings. Utilizes all interfaces in the active aggregator according to the 802.3ad specification.You need a switch that supports IEEE 802.3ad dynamic link aggregation."
Needless to say, the switch (resp, the bonded ports) must be also configured acordingly.
Just in case there is no such support on the router or a switch - use Adaptive Load Balancing on the ReadyNAS ... most non-managed switches are fine with this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The router was the AS-RT86U asus router. It doesn't support link aggregation...., and I should have purchased the AS-RT88U. Think I'll just get the Netgear router that supports LACP. It was my purchasing error, so it will be my expense. Thanks to everyone who took the time to assist me!! KUDO's to all!
- Mark as New
- Bookmark
- Subscribe
- Permalink
To set expectations here: NIC bonding can only increase performance if you have multiple devices accessing the NAS simultaneously. In the specific case of LACP, each data flow is assigned to a particular NIC using the "xmit hash".
If you only have two devices using the NAS at the same time, then if two flows end up being assigned to the same NIC, the other NIC is unused - so there can be no performance gain. The odds of a flow being assigned to a specific NIC is of course 50%. If you have two simultaneous flows, the odds of them being assigned to different NICs card is also 50%. If the flows are bi-directional, the odds of both directions of both flows being assigned to different NICs is only 25%.
For most home users, there isn't going to be much (if any) performance gain. And if you want to guarantee that both NICs will be used whenever possible, then you'd need to use a static LAG on the switch and round-robin in the NAS. While some Netgear home routers support LACP, I don't know of any that support static LAG.
If you want to pursue NIC bonding, then I'd suggest purchasing a switch that supports static LAG (and ideally also LACP) - using that instead of a router). You might also consider getting a multi-gig switch, as that would allow you to upgrade the NAS to a model that supports 10 gigabit ethernet (10GBase-T) in the future.
The Netgear GS810EMX has two 10GBase-T ports and supports both static LAG and LACP. So I'd suggest getting that instead of replacing the router. It gives you more options.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That's not a problem, no need to rush for a new router - as I wrote above, just use Adaptive Load Balancing on the ReadyNAS ... most non-managed switches are fine with this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, that is something you can try for free, and it does work with most equipment. If you see misbehaviour, then just turn it off again (and remove the second ethernet cable).
